- 8 Jun 2015
I'm tempted to just whack 4 SP120 Quiets on it in push/pull all running full speed, surely that wouldnt be that loud and would be able to run my I5 4960k at 4.4ghz same as now with decent temps?
SP QEs would be nice and quiet, yes, but other fans would still give far better performance for similar money and at around the same sort of noise levels.I'm tempted to just whack 4 SP120 Quiets on it in push/pull all running full speed, surely that wouldnt be that loud and would be able to run my I5 4960k at 4.4ghz same as now with decent temps?
Ah, well that makes ALL the difference, then!!Not gonna lie i wanted the SP120s mostly for Aesthetic purposes to match the rest of my corsair kit![]()
The probes only tape to the outside surface of components, like HDD or GPU, so aren't neccesary if you don't want them.Im putting off buying a fan controller because i don't like running in the temperature probes myself,
I'll give that app a look, what fan controllers do you recommend?
