What do you guys think?
21 Apr 2012
Hi,
So i've been planning this upgrade for few months now and finally have enough budget to go ahead with it, just wanted your opinion on my choices (there are likely to be better options)
My current spec is:
P8H61-MX Asus Motherboard
8GB DDR3 RAM
i5-3450 @ 3.10GHz (not OC'd, obviously)
MSi AMD R9 280x 3GB
Antec VP550P 550W PSU
CM Stryker Full Sized Case
My upgrade choices:
https://www.overclockers.co.uk/showproduct.php?prodid=GX-287-MS
https://www.overclockers.co.uk/showproduct.php?prodid=CP-548-IN
https://www.overclockers.co.uk/showproduct.php?prodid=MB-297-MS
https://www.overclockers.co.uk/showproduct.php?prodid=HD-183-SA
https://www.overclockers.co.uk/showproduct.php?prodid=CA-195-CS
https://www.overclockers.co.uk/showproduct.php?prodid=MY-408-CS
The reason I'm going for a larger PSU is because my end game is to SLI that 980Ti, although looking at it now, I could probably get a cheaper one. I'm not very knowledgeable about the actual RAM so do you guys think the option I've gone for is ok? In terms of all of it, any better choices I could go with?
Thanks for all the input
P.S. Sorry - i tried to link all this using the chrome extension add-in but it doesn't seem to show up on my address bar when I'm actually viewing my basket..
Yeah, fans under and blowing through and up and out, or fans on top of rad and blowing down into the case (but also bringing in dust).
I believe that the stryker has some sort of dust filters/protectors at the bottom of the case, so fans blowing inwards might not the too bad of an idea.
