A few months ago my excellent 20-25 odd year old halfords foot pump decided to stop working. I found the gauges are inaccurate on recent Halfords value pumps.
Got a cheap pump from a supermarket but the gauge was terribly inaccurate and would jump all over the place while pumping.
Decided 'you get what you pay for' and went for a Michelin analogue pump (one of these http://www.halfords.com/motoring-tr...uges/michelin-analogue-single-barrel-footpump). It lasted roughly 3 months and a handful of uses before developing a leak. Also I didn't like having to screw it onto the tyre valves. I prefer a clip. The gauge is great though.
So - I'd like a new one to be
- Well built, reasonably sturdy and reliable (so preferably you'll have used it for a good while).
- Fast, precise and accurate gauge
- Clip on not screw on
- Don't mind single or double barrel.
- Happy to pay for quality if its worth it.
I do have an electronic inflator but I prefer to use a foot pump - so no electric tyre inflators please.
