I decided I should fiddle around with voltages to see what the max clocks I could get with max 90c temps on SLI 980ti ACX SC cards from EVGA. Somehow I managed 1575mhz core stable on both cards running games hahaha!!!
Got my EVGA 980Ti Superclocked ACX 2.0+ (the one without the backplate).
I have read reviews stating it gets anything from 68c - 76c at load. Yet mine is hitting 80c after only 5 minutes in Heaven 4.0 and 83c in W3.
Seems either these review sites are full of BS or my card is a having problems. Surely it should run much cooler than this? Thinking of RMA the thing to be honest.
Just a quick check, i'm getting just under 15000 in 3dmark Firestrike (normal mode) with my MSI 980Ti gaming. Is this normal? I have a 2700K @ 4.6ghz.
My precious...
Folks, question about this card and surround on my 980 TI, Im not able to get one of my 3 monitors to work.
Im using as follows:
Back of Monitor -> Back of GFX card
DVI -> DVI
HDMI -> HDMI
HDMI -> Displayport via active convertor
Not sure what Im doing wrong here, any advice appreciated.
thanks.my msi gaming i just got hits 80c in the witcher 3 after 5 mins and the fans are quite loud, a lot more than the 980 gaming i had..
is it set to a custom fan profile in MSI afterburner if not it will get hotter. I have 2 MSI 980ti's in SLI and the top one is cooler than 80c 100% maxed out. It has been a very hot day aswell.
The coil whine is damn annoying. Anyone else have it too?
