OcUK Staff
After a long wait, we are happy to introduce a new range of SuperFlower Leadex models, including two new eagerly awaited Titanium models. SuperFlower and OcUK are the FIRST to market with 850W and 1000W 80+ Titanium units, and FIRST to market with a comprehensive 80+ Platinum range with the addition of 550W - 850W units, giving us a range from 430W all the way up to the 8Pack 2000W beast. Lets not forget the competitively priced 550W Leadex Gold too, which provides the excellent quality of the Leadex range at a lower price. All PSU's are in stock and ready to go. Expect to see a slew of reviews for these in the coming weeks, SuperFlower once again proving why they are among the best in the business!
SuperFlower Leadex Titanium 850W Fully Modular "80 Plus Titanium" Power Supply - Black @ £174.95 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed the Leadex Titanium range, with full 80 Plus Titanium Certification, offering up to 94% efficiency with class leading features, as well as offering capacities from 750W - 1600W.
All Leadex Titanium Power Supplies feature a fully modular design, 140mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Titanium series are an uncompromising masterclass of design and functionality and should be the first choice for any gaming system that needs one of the most efficient power supplies on the market!
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Titanium Certified, 90% 92% 94% 90% Efficiency At 10% 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 180 mm (W x H x D)
- Wattage: 850W
- Fan: 140 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 94% (115V), 80 Plus Titanium certificate
- Active PFC
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-1600F14HT
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 2 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 10 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Only £174.95 inc VAT.
ORDER NOW
SuperFlower Leadex Titanium 1000W Fully Modular "80 Plus Titanium" Power Supply - Black @ £199.99 inc VAT
Features
Specifications
- Wattage: 1000W
- Active PFC
Connectors
- 6 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 12 x SATA
- 6 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Only £199.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 550W Fully Modular "80 Plus Platinum" Power Supply - Black @ £86.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed a full Leadex Platinum range, all with 80 Plus Platinum Certification, offering up to 92% efficiency with class leading features, as well as offering capacities from 550W - 2000W.
All Leadex Platinum Power Supplies feature a fully modular design, 135mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Platinum series are a brilliant choice for anyone who wants great performance and efficiency in their system, along with the flexibility of various wattages to suit everyones needs.
Features
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
Specifications
- Dimensions: 150 x 86 x 165 mm (W x H x D)
- Wattage: 550W
- Fan: 135 mm DBB(automatic control, semi-passive)
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Partcode: SF-550F14MP black (UK)
Connectors
- 1 x 4+4-Pin ATX12V/EPS12V
- 3 x 6+2-Pin-PCIe
- 7 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
Only £86.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 650W Fully Modular "80 Plus Platinum" Power Supply - Black @ £103.99 inc VAT
Features
Specifications
- Wattage: 650W
- Active PFC
- Partcode: SF-650F14MP black (UK)
Connectors
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Only £103.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - Black @ £117.95 inc VAT
Features
Specifications
- Wattage: 750W
- Active PFC
- Partcode: SF-750F14MP Black
Connectors
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Only £117.95 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 850W Fully Modular "80 Plus Platinum" Power Supply - Black @ £136.99 inc VAT
nonl2br
Features
Specifications
- Wattage: 850W
- Active PFC
- Partcode: SF-850F14MP Black
Connectors
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Only £136.99 inc VAT.
ORDER NOW
SuperFlower Leadex Gold 550W Fully Modular '80 Plus Gold' Power Supply @ £71.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 13.5cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features
- 80 PLUS ® Gold Certified, 87%, 90%, 87% Efficiency At 20% 50% 100% Rated Load
- Small Size PC Case Friendly (165mm length PSU chassis)
Specification
- Type: ATX
- Maximum Power: 550W
- Fans: 1 x 13.5cm Two Ball Bearing Fan (automatic control, semi-passive)
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage: Full Range - 100V~240V
- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
- Protection: OVP/OCP/OPP/SCP/UVP
- Dimensions: 165mm(L) x 150mm(W) x 86mm(H)
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 3x 6+2-Pin-PCIe
- 7x SATA
- 4x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £71.99 inc VAT.
ORDER NOW
Features
Specifications
- Wattage: 850W
- Active PFC
Connectors
- 4 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 10 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
ORDER NOW
Features
Specifications
- Wattage: 1000W
- Active PFC
Connectors
- 6 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 12 x SATA
- 6 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
ORDER NOW
Features
Specifications
- Wattage: 550W
- Active PFC
Connectors
- 3 x 6+2-Pin-PCIe
- 7 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
ORDER NOW
Features
Specifications
- Wattage: 650W
- Active PFC
Connectors
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
ORDER NOW
Features
Specifications
- Wattage: 750W
- Active PFC
Connectors
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
ORDER NOW
nonl2br
Features
Specifications
- Wattage: 850W
- Active PFC
Connectors
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
ORDER NOW
Features
Specification
- Type: ATX
- PFC: Active
- +12V Rails: 1
Connectors
- 3x 6+2-Pin-PCIe
- 7x SATA
- 4x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
