OcUK Staff
- 26 Nov 2014
- Stoke
So it's close to payday and I've got some extra special deals for all you forumites! Deals will finish at around 9am Wednesday so get them ordered by then
XFX XTR 750W '80 Plus Gold' Fully Modular Power Supply @ £79.99 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 750W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
It's also been awarded the 80Plus Gold certification for its high power efficiency, and is also designed for NVIDIA SLI and AMD Crossfire multi-GPU systems, making it a perfect solution for hardcore gamers. Its modular design reduces cable clutter. And the large fan delivers silent cooling, so your computer and PSU can operate at peak performance.
Features
- EasyRail™ Plus Technology allowing plenty of wattage headroom to handle your devices
- Hybrid Fan Control allowing the power supply to operate silenty until it reaches 20% load or 25°C
- Ultra Quiet Fan Design
- Ultra Voltage Regulation Design
- Haswell Ready
- AMD Radeon CrossFire Ready
- NVIDIA GeForce SLI Ready
- Multiple PCI-E 6-Pin and 6+2Pin connectors
- True Wattage guarantee
- 80 Plus Gold certifying 90% power efficiency
- Extreme heat tested capacitors
Specifications
- +12V Rail Outputs : Single
- 100% Tested and Verified : Y
- ATX12V 2.2 & ESP12V 2.91 Compliant : Y
- Maximum Wattage (W) : 750
- Modular Cables : Y
- Performance Category : Enthusiast
- UPC Number : 778656058804
- CrossFire Ready : Y
- SLI Ready : Y
- AC Input Current (Arms) : 9.5A-4.5A
- AC Input Frequency (Hz) : 50/60 Hz
- AC Input Voltage (Vac) : 100-240
- Efficiency @ Typical Load : Up to 90%
- Energy-Efficiency : 80 Plus Gold Certified
- High Reliable 105°C Japanese Capacitors : Y
- Solid State Capacitors : Y
- Tight voltage regulation (±5%) : Y
- Max -12V Output Current (A) : 0.3
- Max +12V Output Current (A) : 62
- Max +3.3V Output Current (A) : 20
- Max +5V Output Current (A) : 20
- Max +5VSB Power (W) : 2.5
- Modular ATX12V / EPS12V : One 4+4-pin, One EPS 12V 8-pin
- Modular FDD : 1
- Modular Motherboard Connector : 20+4-Pin
- Modular Peripheral : Up to 6 Connectors
- Modular SATA : Up to 10 Connectors
- Active Power Factor Correction (PFC) : Y
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection (OTP), Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Y
- Cooling Fan Size (mm) : YES; 135mm Fluid dynamic Fan (Black)
- Master Carton Dimensions (cm) : 43.0 x 29.5 x 34.0
- Master Carton Dimensions (inch) : 16.93 x 11.6 x 13.39
- Master Carton Weight (Kg) : 11.72 est.
- Master Carton Weight (lb) : 25.84 est.
- Package Dimensions (cm) : 31.9 x 21.0 x 16.3
- Package Dimensions (inch) : 12.55 x 8.26 x 6.42
- Package Weight (Kg) : 2.76 est.
- Package Weight (lb) : 6.08 est.
- PSU Dimension (cm) : 8.6 x 15.0 x 17.0
- PSU Dimension (inch) : 3.4 x 5.9 x 6.7
- Units per Carton : 4
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
XFX XTR 850W '80 Plus Gold' Fully Modular Power Supply @ £89.99 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 850W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
Features
- Haswell Ready
- DC to DC Converter Design
- Conductive Polymer Aluminum Solid Electrolytic Capacitors
Specifications
- ATX12V 2.2 & ESP12V 2.91 Compliant : Yes
- Maximum Wattage (W) : 850
- UPC Number : 778656058811
- CrossFire Ready : Yes
- SLI Ready : Yes
- AC Input Current (Arms) : 11A - 5.5A
- AC Input Voltage (Vac) : 100 - 240
- Active Power Factor Correction (PFC) : >0.95 at full load
- DC Output Voltage Regulation : ±3%
- DC to DC Converters (+3.3 & +5V) : Yes
- EZ Grip Connectors : Yes
- High Reliable 105°C Japanese Capacitors : Yes
- Solid State Capacitors : Yes
- Max -12V Output Current (A) : 0.8
- Max -12V Power (W) : 6
- Max +12V1 Output Current (A) : 70
- Max +12V1 Power (W) : 840
- Max +3.3V & +5V Combined Power (W) : 125
- Max +3.3V Output Current (A) : 25
- Max +5V Output Current (A) : 25
- Max +5VSB Output Current (A) : 3
- Max +5VSB Power (W) : 15
- Max. +3.3V & +5V combined power (W) : 125
- Wattage(W) : 850W
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection, Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Yes
- Cooling Fan Size (mm) : 120
- Intake Fan: Airflow (CFM/min) : 80.5
- Intake Fan: Diameter (mm) : 120 x 120 x 25 mm
- PSU Dimension (cm) : 8.6 x 14.0 x 16.0
- PSU Dimension (inch) : 3.4 x 5.5 x 6.3
- RCM : Yes
- CB : Yes
- cTUVus : Yes
- TUV: Yes
- CCC: Yes
- FCC: Yes
- CE: Yes
Connectors
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 6x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was £99.95 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Antec EDGE 650w 80 Plus Gold Fully Modular Power Supply @ £77.99 inc VAT
Description
Antec's EDGE series is the pinnacle of power supplies. EDGE is fully modular with a revolutionary 18+10-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS® GOLD & ErP Lot 6: 2013 certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies.
EDGE's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. All cables are darkened and also flat (except MBU cable) to become Flat Stealth Wires and are thus nearly invisible in your chassis. 2 High Current Rails and a ~99% +12V output ratio maximize EDGE's capabilities to power the latest CPU's & GPU's.
CircuitShield™ makes EDGE safe and reliable in any environment with its 7 industrial-grade protections. Backed by a 5 year warranty and lifetime global 24/7 support, EDGE embodies everything a power supply can accomplish today.
Specifications
- 650W Continuous Power - Guaranteed 650W of Continuous Power from Antec
- 80 PLUS® GOLD certified - Up to 92% efficient, to reduce your electricity bill
- AQ5 - Antec Quality 5 year warranty and lifetime global 24/7 support
- 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
- 135 mm LED FDB Silence - Whisper-quiet high-quality LED fluid-dynamic bearing fan with long lifetime
- Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
- High Current Rails - 2 +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
- 98.2% +12V - Output for maximum CPU & GPU support
- 28(18+10)- pin MBU socket - For possible future MBU connectors
- CircuitShield™ - Full suite of industrial grade protections: Over Current Protection (OCP), Over Voltage Protection (OVP), No Load Operation (NLO), Short Circuit Protection (SCP), Over Power Protection (OPP), Over Temperature Protection (OTP) & Surge & Inrush Protection (SIP)
- Japanese Heavy- Duty Caps - High-performance Japanese capacitors ensure tightest DC stability and regulation
- Flat Stealth Wires - Flat and darkened wires for minimal visibility in chassis (except MBU cable)
- ATX12V 2.4 - Engineered according to the newest PSU guideline and compatible with the latest CPU generation
Connectors
- 1 x 20+4 Pin
- 1 x 8 Pin EPS
- 4 x 6+2 PCI-E
- 9 x SATA
- 6 x MOLEX
- 1 x Floppy
- 5 Year warranty
Was £89.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Antec EDGE 750w 80 Plus Gold Fully Modular Power Supply @ £86.99 inc VAT
Description
Specifications
- 750W Continuous Power - Guaranteed 750W of Continuous Power from Antec
Connectors
- 1 x 20+4 Pin
- 1 x 8 Pin EPS
- 6 x 6+2 PCI-E
- 9 x SATA
- 6 x MOLEX
- 1 x Floppy
- 1 x 4+4 Pin ATX/EPS
- 5 Year warranty
Was £99.99 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
BeQuiet Straight Power 10 500W '80 Plus Gold'' Power Supply @ £69.95 inc VAT
be quiet! Straight Power 10 provides a new level of silent performance for systems that demand whisper-quiet operation without compromising on power quality.
Features
- Virtually inaudible SilentWings 3 135mm fan with improved fan frame
- Big funnel-shaped fan opening of the PSU case induces high airflow intake
- 80PLUS Gold power efficiency (up to 93%)
- Four high-performance 12V-rails
- Power signal stability unmatched in its class
- Powerful GPU support with up to four PCI-Express connectors
- Premium 105°C-rated parts enhance stability and reliability
- ErP 2014 ready
- Product conception, design and quality control in Germany
- 5-year warranty
Specifications
- Model: 500W
- Partcode: BN231
- EAN: 4260052183649
- Voltage / Frequency: 100-240Vac / 50-60Hz
- ATX 12V 2.4 / EPS 12V 2.92: Yes
- Dimensions (L x W x D): 160 x 150 x 86
- SilentWings Fan: Yes
- Noise level (dB(A)) at 20 / 50 / 100% load: 10.2 / 10.9 / 15.5
- Efficiency (%) at 230V: Up to 93%
- 12V Rails: 4
- Active PFC: Yes
- OCP, OVP, UVP, SCP, OPP, OTP: Yes
- Certifications: 80 PLUS Gold
- Energy Star 6.0 compatible: Yes
- ErP2014 ready: Yes
- Lifetime of fan at 25°C (h): 100,000
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 9 x SATA
- 3 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £74.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
BeQuiet Power Zone 750W '80 Plus Bronze' Fully Modular Power Supply @ £89.99 inc VAT
The Power Zone series provides the winning combination of superior performance, rock-solid stability, and advanced cooling. Whether you are assembling a high power PC or multi-GPU gaming system, your build will benefit from the Power Zone features.
Features
- Massive 12V rail design is ideal for overclocking
- Full cable management supports maximum build flexibility
- COOL*OFF feature run fans for three minutes after system shutdown
- Connect up to three case fans for optimized system cooling
- Designed for powerful operation even at 50° C
- 135mm SilentWings fan with innovative 6-pole motor enables quiet operation
- 80PLUS Bronze efficiency (up to 90%)
- Up to six PCI express connectors (NVIDIA SLI, AMD CrossFireX)
- Compatible with Intel C6/C7
- Five-year warranty
- German product conception, design and quality control
Specifications
- Continuous power (W): 750
- Model: BN211
- Voltage / Frequency: 100–240Vac, 50–60Hz
- Dimensions (LxWxH): 86 x 150 x 175
- be quiet! fan (mm): 135mm Silentwings
- Noise level (dbA) at 20 / 50 / 100% load: 13.6 / 17.4 / 34.9
- Efficiency (%) at 230V: up to 90
- 12V Rails: 1
- PFC: Active
- Certifications: 80Plus Bronze, nVidia SLI, AMD CrossFireX
- Energy Star 5.2 Compatible: Yes
- ErP2013 ready: Yes
Connectors
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £99.95 Inc. VAT
ORDER NOW
BeQuiet Pure Power L8 730W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in @ £77.99 inc VAT
nonl2br
The Pure Power L8 series proves that true affordability means peerless dependability and best-in-class features — not cutting corners and settling for less. Whether you are assembling a very quiet higher-powered system, building a better multimedia or dual-GPU gaming system, or upgrading an existing PC, your build will benefit from the premium features be quiet's German team has designed into this PSU.
Features
- Silence-optimized 120mm be quiet! fan with durable Rifle-Bearing-Technology
- Certified 80PLUS Bronze efficiency (up to 88%)
- Modular Cable Management with sleeved cables for reduced clutter and better airflow. All-in-one cable with SATA, HDD and FDD connector
- Supports multi-GPU systems (400-700W)
- Meets energy-saving requirements of Intel C6/C7, ErP 2013 and Energy Star 5.2 guidelines.
- Ready for Intel ® Haswell TM platform
- Stronger +12V rails increase power stability
- Full suite of top safety protections defends against over-currents, over- and under-voltages, short circuits, overheating and overloads, thus safeguarding valuable components
- Three year warranty
Specifications
- Continuous power (W): 730
- Model: BN183
- ATX 12V 2.31 / EPS 12V 2.92: Yes
- Dimensions (LxWxH): 160 x 150 x 86
- be quiet! fan (mm): 120 Silent Wings
- Noise level (dbA) at 0 - 100% load: 15-29
- Efficiency (%) at 230V: up to 88
- 12V Rails: 2
- PFC: Active
- Certifications: 80Plus Bronze, AMD CrossFireX
- Energy Star 5.0 Compatible: Yes
Connectors
- 2 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 5 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 3yr
Was £86.99 Inc. VAT
ORDER NOW
Cougar GX V3 600W '80 Plus Gold' Modular Power Supply @ £62.99 inc VAT
New high-end series of power supplies specifically targeting demanding gamers, the COUGAR GX V3 series. The 80Plus Gold certified GX V3 series provides up to 93% peak efficiency. The advanced cable management solution allows users to only use those cables their peripherals actually need, thereby effectively reducing cable mess while at the same time improving air circulation and ventilation within the case.
The rugged black coating in combination with the gold vent grill add to the overall robust and aggressive appearance of these units, thereby effectively increasing the game-style looks. COUGAR GX power supply, your best choice.
Features
- 80-PLUS® GOLD CERTIFIED: Up to 93% of efficiency, compliant with 80-PLUS® GOLD efficiency requirement
- ULTRA-QUIET & TEMPERATURE-CONTROLLED 140mm FAN: 140mm double ball bearing fan deliver optimum air flow with extremely low noise level, the fan speed automatically governed based on the temperature
- ADVANCED MODULAR CABLE: The advanced modular cable management is further improved by utilizing new flat cables that simplify installation as well as reducing air friction in order to maximize airflow. This gives gamers the power they need, and flexibility of easy upgrades they demand
- COMPATIBLE WITH LATEST PC-TECHNOLOGY: Supports the newest specifications of ATX12V v2.31 and EPS 2.92 standards. Created for usage with current and next-generation multi-core CPU platforms
- SUPPORT MULTI-GPU TECHNOLOGY: Support PCI Express 2.0 next-generation graphic card with 8(6+2)pin PCI-E connector
- 105 °C JAPANESE CAPACITORS: Highest durable 105°C Japanese capacitors provide uncompromised performance and reliability, delivering 4 times the lifespan of conventional 85°C rated capacitors.
- HIGH PERFORMANCE AT 50°C: Non-stop high performance and full rated wattage at 50°C/122°F ambient temperature.
- DYNAMIC MULTI-12V: Automatic dynamic load distribution on multi-12V lines provide high voltage stability power separately to the GPU and the CPU. If you are not using all output lines, the PSU automatically reroutes needed power from unused lines. This improves the performance and safety of the 12V lines considerably for systems with high-end graphics cards in SLI® or CrossFire® mode
- COMPLIANT WITH THE LATEST ErP Lot6 2013: In Standby consumption is <0.3W, compliant with economy-friendly electrical equipment
- FULL PROTECTIONS WITH OCP, SCP, OVP, UVP, OPP & OTP
Specifications
- AC Input: 110-240Vac, 50-60Hz, 10-5A
- Output: 600W
- Certification: 80 Plus Gold Certified
- Dimensions (L x W x H): 160 x 150 x 86
- UVP (Under Voltage Protection): If the voltages fall below a certain tolerance value on the single lines, the PSU automatically switches off.
- OVP (Over Voltage Protection): If the voltages increase above a certain tolerance value on the single lines, the PSU automatically switches off.
- SCP (Short-Circuit Protection): In the case of a short-circuit this feature prevents damage to the core components of the PSU and its system components.
- OPP (Over Load Protection): If the system is over sized and requires more power from the PSU than it can perform, this protection function is activated.
- OCP (Over Current Protection): If the load on a single line is higher than indicated, the PSU automatically switches off.
- OTP (Over Temperature Protection): If the temperature is too high, the PSU automatically switches off.
Connectors
- 4x 6+2-Pin-PCIe
- 6x SATA
- 3x 4-Pin-Molex
- Warranty: 5yr
Was £69.95 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Cougar GX V3 800W '80 Plus Gold' Modular Power Supply @ £79.99 inc VAT
Features
Specifications
- Output: 800W
Connectors
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 4x 4-Pin-Molex
- Warranty: 5yr
Was £89.99 Inc. VAT
ORDER NOW
Here's some super special deals on SuperFlower, including some new models, just for the forum members!!!
SuperFlower Leadex Gold 1600W Fully Modular "80 Plus Gold" Power Supply - Black @ £184.99 inc VAT
SuperFlower, one of the worlds leading power supply manufacturers have added the Leadex 1600W Gold to their range, offering up to 90% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage Gold rated PSU's on the market.
The SuperFlower Leadex Gold 1600W Power Supply features a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 87% 90% 87% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 220 mm (W x H x D)
- Fan: 140 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 90% (115V), 80 Plus Gold certificate
- Active PFC
- Form Factor: ATX12V 2.2 / EPS12V 2.92
- Power: 1600W
- 3.3V: 24 A
- + 5V: 24 A
- + 3.3V & + 5V combined: 120 W
- + 12V: 1,599.6 W / 133.3 A
- -12V: 6 W / 0.5 A
- + 5VSB: 15 W / 3.0 A
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-1600F14HG
Connectors
- 1 x 8-Pin EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Was £224.99 Inc. VAT
Only £184.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 550W Fully Modular "80 Plus Platinum" Power Supply - Black @ £76.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed a full Leadex Platinum range, all with 80 Plus Platinum Certification, offering up to 92% efficiency with class leading features, as well as offering capacities from 550W - 2000W.
All Leadex Platinum Power Supplies feature a fully modular design, 135mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Platinum series are a brilliant choice for anyone who wants great performance and efficiency in their system, along with the flexibility of various wattages to suit everyones needs.
Features
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
Specifications
- Dimensions: 150 x 86 x 165 mm (W x H x D)
- Wattage: 550W
- Fan: 135 mm DBB(automatic control, semi-passive)
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Partcode: SF-550F14MP black (UK)
Connectors
- 3 x 6+2-Pin-PCIe
- 7 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
Was £86.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
SuperFlower Leadex Titanium 1000W Fully Modular "80 Plus Titanium" Power Supply - Black @ £179.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed the Leadex Titanium range, with full 80 Plus Titanium Certification, offering up to 94% efficiency with class leading features, as well as offering capacities from 750W - 1600W.
All Leadex Titanium Power Supplies feature a fully modular design, 140mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Titanium series are an uncompromising masterclass of design and functionality and should be the first choice for any gaming system that needs one of the most efficient power supplies on the market!
Features
- 80 PLUS ® Titanium Certified, 90% 92% 94% 90% Efficiency At 10% 20% 50% 100% Rated Load
Specifications
- Dimensions: 150 x 86 x 180 mm (W x H x D)
- Wattage: 1000W
- Efficiency: max. 94% (115V), 80 Plus Titanium certificate
- Active PFC
- Partcode: SF-1600F14HT
Connectors
- 2 x 4+4-Pin ATX12V/EPS12V
- 6 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 12 x SATA
- 6 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £199.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
AK Racing Octane Gaming Chair - Orange @ £199.99 inc VAT
AK Racing seats offer stylish esports looks alongside well considered ergonomics.
The new Octane series is a great looking new chair, with high-quality PU leather and a stripe design with fantastic style. The Octane series is also featuring the new shaped armrest to bring even more comfort when sitting in it; perfect for long gaming sessions.
This particular new chair model comes in 6 different colours: black, blue, white, red, green and orange. Boring office chairs are the last thing any gaming enthusiast wants! Don't suffer these boring solutions any longer, now you can have the same style chair that professional gamers use in tournaments around the world!
Perfect for office workers and gamers, AK Racing seats are a high quality and exciting solution to the various health disorders resulting from bad posture.
Styled after Race Car seats and implementing very high quality materials, AK Racing are the ultimate desk accessory and compliment your pro gamer attitude perfectly whilst being hard wearing and durable.
Featuring supportive seat bolsters, just like a real bucket seat, your posture will be perfect whilst at your desk.
All AK Racing seats come with multiple points of adjustability so that you can tailor the position of the seat perfectly.
Features
- Colour: Orange
- Quality upholstery material. OCTANE series uses PU Leather.
- Metal Construction: Each seat has a sturdy metal frame.
- High quality, comfortable hard foam, not prone to deformation over time.
- Adjustable Armrests.
- Adjustable Back Angle: 180-degree backrest adjustment allows you to adjust it to your needs.
- Adjustable tilt, height and back.
- Reinforced wheels: designed not to scratch hardwood or laminate floors.
- Very Strong Metal base with class 4 gas lift support up to 150KG.
- Cushions Included for optional lower back and head/neck support.
Dimensions
- Shoulder Width: 540mm
- Waist Width: 500mm
- Seat Width: 370mm
- Back Height: 920mm
- Seat Length: 560mm
- Seat Height: 500-420mm
- Armrest Heights: 340-270mm
Was £229.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
AK Racing Octane Gaming Chair - Blue @ £199.99 inc VAT
Features
- Colour: Blue
Dimensions
- Seat Width: 370mm
ORDER NOW
AK Racing Player Gaming Chair - Black / Blue @ £199.99 inc VAT
nonl2br
Features
- Colour: Blue & Black
- Quality upholstery material. PLAYER series uses PU Leather.
- Metal base with class 4 gas lift support up to 150KG.
Dimensions
- Shoulder Width: 565mm
- Waist Width: 550mm
- Seat Width: 365mm
- Back Height: 950mm
- Seat Height: 510-430mm
ORDER NOW
Arozzi Torretta XL Gaming Chair - Green @ £149.99 inc VAT
The Arozzi Torretta XL is one cool gaming chair, which has a racing inspired look. High quality, thick padding on the arm rests, seat and, back gives you the highest comfort.
The Torretta XL chair is one of the first chairs to be designed for people with the need of a larger and wider chair. With the same features and design as its precursor, but with wider seat and backrest this chair will bring supreme comfort without feeling tight.
Features
- Colour: Green & Black
- Metal frame construction.
- Thick padded seat and backrest.
- Ergonomic design.
- Fabric upholstery material.
- 360 Degree swivel rotation.
- Adjustable armrest (height and rotation)
- Adjustable height gas-spring, supports up to 180KG.
- Tiltable seat with lock function
- Lightweight construction for easy movement.
- Five twin wheel nylon casters.
- 7 different colour choices.
Technical Details
- Shoulder Width: 590mm
- Waist Width: 450mm
- Seat Width: 480mm
- Chair Height: 1280mm
- Seat Length: 460mm
- Seat Height: 400-330mm
- Armrest Heights: 370-270mm
Only £149.99 inc VAT.
ORDER NOW
Arozzi Torretta XL Gaming Chair - Orange @ £149.99 inc VAT
Features
- Colour: Orange & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
Arozzi Torretta XL Gaming Chair - Azure @ £149.99 inc VAT
Features
- Colour: Azure & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
Arozzi Torretta XL Gaming Chair - Red @ £149.99 inc VAT
Features
- Colour: Red & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
BitFenix Prodigy M MATX Cube Case - Blue @ £49.99 inc VAT
An evolution of a classic. The Prodigy revolutionised our perspective on small form factor case design and what a small computer was capable of. The Prodigy M takes this concept to the next level
Reimagined with micro ATX compatibility, Prodigy M enables users to install multiple expansion cards while maintaining the same compact dimensions and sleek look of the original Prodigy. Suspended with two FyberFlex Composite handles for shock absorption, Prodigy M can be easily transported to the next room or to the next LAN party.
The inside is incredibly flexible, offering space for SLI or Crossfire dual graphics technology, up to four 3.5" hard drives or five 2.5" SSDs, and even space for slim 240mm radiators. A magnetic heat shield is also included should you decide to fill the bottom with hard drives rather than fans. With BitFenix SofTouch Surface Treatment, a massive CPU cooler cutout, and rolled-edge cable pass-throughs, the small case that does it all returns with a vengeance.
Full MATX Compatibility
You asked, we delivered. Prodigy M now features full compatibility with micro-ATX motherboards, all while maintaining the same compact dimensions as the original award-winning Prodigy. Featuring an all-new layout, Prodigy M is truly flexibility reimagined.
Sleek and Compact
One thing that hasn't changed is the sleek and clean look of the original Prodigy. Sporting two exquisitely crafted handles that suspend the body, Prodigy M has the same modern yet elegant styling that made the original the small form factor case of choice for PC enthusiasts the world over.
Tremendous Flexibility
Of course, Prodigy M couldn't carry the Prodigy name without the flexibility to match. Aside from both micro ATX and mini-ITX compatibility, Prodigy M can be configured with up to four 3.5" HDDs or five 2.5" SSDs for excellent storage potential. Adding in a micro ATX motherboard gives you up to four expansion slots, perfect for additional expansion cards, or even SLI and Crossfire dual graphics capability.
Multiple Cooling Options
To keep things running frosty, Prodigy M can be outfitted with up to five fans for maximum cooling. Bolt a thin 240mm radiator on top, or perhaps a 120mm radiator on the rear. With the roomy interior, even tower CPU coolers up to 160mm will fit with ease. No matter how you prefer to cool your system, Prodigy M has you covered.
Specifications
- Materials: Steel, Plastic
- Colors (Int/Ext): Blue/Black
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Micro ATX, Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 4 (2 + 2)
- 2.5” Drive Bays: x 5 (3 + 2)
- Cooling Top: 120mm x 2 (optional)
- Cooling Bottom: 120mm x 2 (1 included) or 200mm x 1(optional) or 230mm x 1 (optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1 (optional)
- PCI Slots: x 5
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, heat shield
Was £64.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
BitFenix Shinobi XL Full Tower Gaming Case - Black @ £104.99 inc VAT
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts.
Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.
Specifications
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX
- 5.25” Drive Bays: x 5
- 3.5” Drive Bays: x 7
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)
- Cooling Bottom: 2 x 120mm (optional)
- PCI Slots: 9
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking
- Maximum CPU Cooler Height: 193mm
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)
- Maximum MB Tray Clearance (rear): 34.5mm
Was £124.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
NZXT HUE RGB LED Controller - Black @ £19.99 inc VAT
NZXT has expanded their bay devices with HUE; an LED configuration that is customizable to your liking. HUE grants you the power to select how you want to illuminate your chassis with infinite possibilities. Take charge of the RGB controls to adjust the color fade, pulsating light effects, and brightness levels of your internal LED sleeve. HUE is equipped with an on/off mode for times you may need to go stealth and possesses a unique semi-mesh design, blending flawlessly into any chassis with a mesh front panel.
- Infinite color options that you can customize to your heart’s content
- Three RGB controls to adjust the color settings, brightness level, and pulse speed of the internal LED sleeve
- On/off mode to completely disable the LEDs
- Effect modes: normal, fading, flashing, and pulsating of colors
- Internal LED sleeves that vibrantly illuminates and accents your chassis based on your liking
- Unique mesh design that blends flawlessly into any chassis with a mesh front panel
- 5.25" ODD
- 3 RGB dials
- 5 Brightness Levels
- Modes: NORMAL, FADING, FLASHING, COLOR FADING, AND COLOR FLASHING
Was £24.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
BitFenix Prodigy Mini-ITX Cube Case - Slime Green @ £49.99 inc VAT
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
Specifications
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- PCI Slots: x 2
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Was £64.99 Inc. VAT
ORDER NOW
Silverstone SST-FT05B-W Fortress Tower ATX - Windowed Black @ £121.99 inc VAT
The Fortress FT05 represent SilverStone’s continued dedication in improving and reinventing computer chassis design. Similar to the RAVEN RV05, it no longer has any 5.25” drive bay and utilizes SilverStone’s fame 90 degree rotated design. Previous full ATX SilverStone chassis with 90 degree layout often had to compromise on space efficiency due to fixed length of the motherboard in rotated orientation. So the elimination of 5.25” bays solves this issue naturally and enables FT05 to be not only more balanced in proportion but stunning in its design thanks to its thick wrap-around aluminum exterior.
With majority of wasted space eliminated, the FT05 is better optimized for components that affect performance the most such as CPU and GPUs. The result is an expertly-engineered ATX chassis that is just as capable in terms of compute power and heat dissipation as the first RAVEN chassis, the RV01, but in half the size. Equipped with latest revision Air Penetrator fans that include three speed switches and modern touches such as externally removable filters and tool-less panels, the FT05 has everything that PC enthusiasts could wish for in a compact, high performance computer chassis that is not only cool and quiet, but also easy to build and maintain. For those not wanting to constantly step up in chassis size to obtain top-level performance, the Fortress FT05 is perhaps the best and most beautiful solution.
Features
- Aluminum wrap-around exterior with classic SilverStone Fortress styling
- Revolutionary 90 degree motherboard mounting from RAVEN RV01
- Breakthrough 5.25 inch bay-free design for unprecedented power to size ratio
- Two Air Penetrator fans included for great performance and quietness
- Positive air pressure design for excellent cooling/quietness and dust-prevention
- Foam padded interior for advanced noise absorption
- Quick-release latch for fast side panel removal
- Exterior access to main filter for easy maintenance
- Support for various liquid cooling radiator sizes
Specification
- Model No: SST-FT05B-W (black + window)
- Material: Aluminum front, bottom, and rear panels, steel body
- Motherboard: SSI-CEB, ATX, Micro-ATX
- Drive Bay: External - Slim slot-loading optical x 1, Internal: 3.5" x 2, 2.5” x 2
- Cooling System: Front: -, Rear: -, Side: -, Top: 120mm fan slot x 1, Bottom: 180mm AP fan x 2, 600/900/1200rpm, 17/25/34dBA, Downward compatible with 120mm fan x 3, or 140mm fan x 2, Internal: -
- Expansion Slot: 7
- Front I/O Port: USB 3.0 x 2, Audio x 1, MIC x 1
- Power Supply: Optional PS2(ATX)
- Expansion Card: Compatible with 12.3” long, width restriction – 6.57”
- Limitation of CPU cooler: 162mm
Limitation of PSU: -
- Net Weight: 9.5kg
Dimension: 221mm (W) x 483mm (H) x 427mm (D), 46 liters
Was £144.99 Inc. VAT
Only £121.99 inc VAT.
ORDER NOW
Antec VPF550 550W '80 Plus Bronze' Power Supply @ £47.99 inc VAT
Get economical power today with the VPF BRONZE series, Antec's high-efficiency power supply solution. Featuring 80 PLUS® BRONZE certification, a quiet 120mm fan, and universal input with active power factor correction (PFC), the VPF BRONZE series gives you a cooler, quieter system all powered by Continuous Power. The VPF BRONZE series also features industrial safety protection, including short circuit and over voltage protection, for stable and reliable power no matter what.
Specifications
- 550W Guarenteed wattage of Continuous power from Antec
- Manufactured by Delta Electronics
- 80 Plus Bronze Certified
- Intel Haswell Ready
- 120mm Silence Fan; whisper-quiet high-quality bearing fan with long life
- Thermal Manager; An advanced low voltage fan control for optimal heat & noise management
- Multi PCI-E connectivity support
- Circuity Sheild: Full suite of industrial grade protections: OCP/OVP/UVP/SCP/OPP/OTP/SIP/NLO/BOP
- High Current Rails: Dual +12v rails with high load capacities to ensure maximum CPU & GPU compatibility
- > 93% +12V : 99.2% VPF550
- ATX12V 2.4
- Heavy Duty Caps: High performance capacitors ensure the tightest DC stability and regulation
- ErP Lot 6: 2013
Connectors
- 1 x 20+4 Pin
- 1 x 4+4 Pin
- 2 x 6+2 Pin PCI-E
- 5 x SATA
- 3 x MOLEX
- 1 x Floppy
- AQ3 : Antec 3 Year warranty and lifetime 24/7 Support
Was £52.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
Corsair Carbide 300R Mid Tower Case - Black (CC-9011014-WW) @ £59.99 inc VAT
The Carbide Series™ 300R is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5” SSD compatibility. There’s room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There’s room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
- Room for graphics cards up to 450mm long
- USB 3.0 front panel connectors
- Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need
- Keep your system cool with up to 7 fan mount locations
- Easily accessible dust filters keep the cool air flowing over your valuable components
- Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout
- Optimize airflow and keep your system neat and tidy using the intelligent cable management system
- Drive Bays: 3 x 5.25" Drive Bays and 4 x 3.5"/2.5" Drive Bays
- Cooling: 1 x 140mm intake fan and 1 x 120mm exhaust fan
- Expansion Slots: 7
- Motherboard Support: ATX & mATX
- Front I/O: 2 x USB3.0 and 2 x Audio
- Dimensions: 19.1" x 8.3" x 17.7"
Was £65.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
BitFenix Colossus Red LED Big Tower Windowed Case - Black @ £99.95 inc VAT
Introducing BitFenix Colossus – the PC chassis for the uncompromising enthusiast. Offering unmatched expandability, security, and cooling all wrapped up in a modern and elegant body, Colossus represents months of intensive research, product development, and meticulous design. The result is a chassis like no other; a chassis that serves as an ideal enclosure for the most colossal gaming rigs.
Ready for the Future
The next generation of USB connectivity is here. Equipped with two USB 3.0 ports, Colossus allows you to connect an ever-growing number of USB 3.0 devices and experience data transfer speeds up to ten times that of USB 2.0. With USB 3.0 already built-in, Colossus can last you several upgrades, further future-proofing your system.
At Your Command
Designed to be the center of your digital domain, Colossus puts you in command with a PWM fan controller and multimode light controls. Tune your fans down for silence or up for extra cooling. Select your desired lighting color or turn them off completely. With Colossus, control is always at your fingertips.
Advanced LED Lighting System
Perhaps the most striking feature of Colossus at first glance is the advanced LED lighting system. The Colossus includes front panel LED's and two internal LED fans, which like the front panel LED's can be turned on and off with the touch of a button
Unmatched Security with BitFenix S3
Colossus introduces a BitFenix exclusive – S3. S3 is a storage compartment and security system in one. Place your iPhone, hard disk, or other valuables in S3 and lock them away for safe keeping. S3 will even lock down peripherals like USB mice and keyboards plugged into it, and secure everything under lock and key. Simple, safe and secure – that’s BitFenix S3.
Complete Cable Management
Messy cables not only look bad, but they can also restrict airflow in a chassis. That’s why Colossus is designed to manage cables both inside and out. Keep cables from cluttering the inside of the chassis with Colossus' strategically-placed cable holes. Prevent cables from getting caught in opening optical drives with the unique cable-holding front bezel.
Epic Expandability
Colossus gives you the space to build your own supercomputer. Capable of accommodating eight PCI express devices and seven 2.5" SSDs or seven 3.5" hard disk drives, Colossus is ready for multiple upgrades – perfect for a rig of epic proportions.
Massive Cooling
When the action heats up, your system needs to keep its cool. Colossus can be outfitted with up to two 230mm fans, three 140mm fans, or three 120mm fans, meaning huge cooling potential for all system components.
Easy Installation
Big doesn't have to mean unwieldy. Featuring a motherboard CPU cooler cutout on the motherboard tray, specially-designed motherboard standoffs, and an almost completely tool-free design, getting your system up and running with Colossus is a joy. Large yet welcoming, if Colossus reminds you of a friendly giant, we wouldn’t blame you.
Specifications:
- Materials: SECC, ABS
- Color (Int/Ext): Black
- Dimensions (WxHxD): 245 x 558 x 582 mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, E-ATX
- 5.25" Drive Bays: x 5 (1 x external 3.5"; tool-free)
- 3.5" Drive Bays: x 7
- 2.5" Drive Bays: x 7 (using standard 3.5" drive bays)
- Cooling Front: 1 x 230mm included
- Cooling Rear: 1 x 140/120mm (not included)
- Cooling Side Panel: n/a
- Cooling Top: 1 x 230mm included (or 1 x 140/120mm not included)
- Cooling Bottom: 1 x 140/120mm (not included)
- PCI Slots: 8 (tool-free)
- I/O: 2 x USB3.0, 2 x USB2.0, eSATA, Audio
Only £99.95 inc VAT.
ORDER NOW
BitFenix Phenom MATX Cube Case - Arctic White @ £54.95 inc VAT
The latest BitFenix small form factor chassis, Phenom Micro-ATX combines an elegantly modern outlook with an incredibly flexible internal structure for a cube design like no other. The subtle curves coated in premium BitFenix SofTouch™ Surface Treatment offer a luxuriously matte finish, while the clean and uncluttered styling makes Phenom a perfect fit in virtually any environment.
Designed for Micro-ATX motherboards, Phenom Micro-ATX delivers superb flexibility with support for dual long graphics cards, tall CPU coolers, and even slim water cooling radiators. Users can install up to four hard disks or six SSDs, and two high-speed USB 3.0 ports ensure lightning-quick transfers of today's high-definition media. Along with a fully powder-coated interior, rolled cable pass-throughs, and unique heat shield, Phenom Micro-ATX delivers the quintessential BitFenix experience in an SFF form factor.
Features
Clean and Modern Styling - Phenom was engineered to be a sleek modern cube design that fits in any environment. Mesh accents on the sides strikingly compliment the clean and uncluttered top, front, and side panels, while the high-gloss BitFenix logo in front provides a perfect contrast to the luxuriously soft matte finish of the SofTouch™ Surface Treatment. These elements combine with the subtle contours of the panels to form a timeless design ideal for a modern décor.
MATX Compatibility - Featuring no less than five expansion slots, Phenom Micro-ATX accommodates micro-ATX motherboards to enable dual graphics capability such as SLI or Crossfire, or added expansion cards.
Superb Flexibility - Tiny but mighty, Phenom Micro-ATX delivers an exceedingly flexible interior. Install dual graphics cards up to 320mm in length, or opt for a single graphics card and a slim 240mm water cooling radiator up top. Those who prefer air cooling will be pleased to see that tall CPU coolers up to 160mm can be mounted with no fuss. When it comes to hardware compatibility, Phenom-MATX is truly phenomenal.
Specification
- Materials: Steel, Plastic, SofTouch™
- Colors (Int/Ext): White/White
- Dimensions (WxHxD): 250 x 330 x 374mm
- Motherboard Sizes: Micro-ATX, Mini-ITX
- 3.5” Drive Bays: x 5 (4 + 1 using included adapter)
- 2.5” Drive Bays: x 5 (2 + 2 + 1 using included adapter)
- PCI Slots: x 5
- Extras: SofTouch™ surface treatment, magnetic heat shield
</p>
Was £64.99 Inc. VAT
Only £54.95 inc VAT.
ORDER NOW
Raijintek Aeneas mATX Cube Case - White Windowed @ £54.95 inc VAT
AENEAS, Raijintek’s special type chassis – Cube Micro ATX, is developed with elegant design, super intake/outtake airflow, and spot catch LED bar. Not only AENEAS brought to you fashion and elegant style, but AENEAS also brings you a sturdy chassis body (0.8mm SGCC) and with surprising function and features.
With awesome fan installation function to provide cooling performing, AENEAS is bale to install Max. 8 fans, 200mm fan optional at front, 2 * 140mm fans pre-installed at rear, 2*120mm fans pre-installed at front, and additional to install 240mm radiator at front or top. Superior features includes Removable M/B plate for easy installation of coolers, Switch off button of LED lighting, Compatible wtih 180mm height CPU cooler, VGA card length to 310mm and Regular ATX PSU compatibility. What a awesome chassis enthusiasm is looking for, it must be AENEAS.
- Elegant LED light bar design (on/off switch)
- User Friendly design – removable M/B frame and tool-free screws
- Classic design with efficient and mass airflow
- Complete black coated interior
- Dust-control filters for all mesh area
- Sturdy and reliable chassis body Chassis body: 0.8mm SGCC
- Accommodate an internal 240 mm radiator at front ; an 280mm radiator at top
- Powerful fan systems pre-installed: two 140mm at rear; two 120mm at front.
- Supports to up to eight fan installation; 200mm fan option at front
- Supports to install four 3.5”HDD (or four 2.5” HDD) and five 2.5” HDD (optional cage)
- Fully supports Tool-free for ODDs & HDDs
- Two high speed USB3.0 and two USB2.0
- Supports VGA card up to 310mm
- Support CPU cooler height up to 180mm
Specfication:-
- Internal color Matt Black
- Dimension chassis body (D/W/H) 352*288*380mm
- Dimension chassis body (D/W/H) 380*288*430mm
- Body Weight (N.W.) Kg
- Material SGCC 0.8mm
- M/B Type MICRO-ATX?ITX
- Graphic Card Support yes
- Power Supply PS-2
- Power Supply Integration Internal Bottom PSU (vertical)
- 5.25" Drive Bays 1
- 3.5" Device 1 exposed +4 hidden
- 2.5" Device (option/removable) 5
- I/O Panel USB3.0 *2 + USB2.0*2
- Hot Swappable n/a
- PCI Slot 5
- PCI Slot Tool-free Yes
- ODD & HDD Tool-free Yes
- CPU Cooler Height 180mm max.
- Graphic Card Length 310mm
- Side Panel Style Flat / Vent
- Cable Management Regular
- Water Pipe holes 2
- Front Cooling Fan 120mm*4 (2pcs pre-installed) ; 200mm fan (option) or
- 240mm radiator (option)
- Rear Cooling Fan 140mm*2pcs (pre-installed)
- Left Side Cooling Fan Option
- Right Side Cooling Fan option
- Top Cooling Fan 140MM*2 (option)
- or 280mm radiator (option)
Was £65.99 Inc. VAT
ORDER NOW
Corsair Graphite 380T Portable Mini ITX Case - Yellow (CC-9011065-WW) @ £89.99 inc VAT
The Graphite Series 380T packs a powerful punch in a portable Mini-ITX PC case. A built-in carrying handle makes transport a breeze. It’s easy to build the road-ready computer of your dreams within a spacious, easy to access interior with room for an extra-long graphics card. You can keep things cool with mounts for up to six fans and a convenient front panel three-speed fan controller.
The Graphite Series 380T Mini-ITX PC case doesn’t make any comprises inside or out. The sleek design derives from Corsair’s most-celebrated computer cases -- featuring eye-catching rounded corners as well as multiple color options. A built-in carrying handle lets you take it anywhere with ease.
Fine-tune air-cooling performance with the three-speed fan controller. Visible through the windowed side panels, the roomy and easy to access interior delivers major real estate for your next rig with space for a full-length graphics card, six fans, and four drives. Plug in your USB 3.0 devices and headset through the front panel. Now you’re ready to hit the road in style.
Features:
- Aesthetics that impress: sleek design, rounded corners, and easy to remove windowed side panels
- Built-in carrying handle makes it a portable powerhouse
- Included 140mm LED intake fan and 120mm exhaust fan
- Control freak? Customize cooling and noise level with the convenient three-speed fan controller
- Swap drives easily -- without tools -- in and out of the two 3.5¡¨ and two 2.5¡¨ drive bays
- Built-in internal lighting with to show off your system
- Easy connectivity with front panel USB 3.0, headphone, and microphone ports
- Maximum CPU Cooler Height -150mm
- Maximum GPU Length - 290mm
- Maximum PSU Length - 160mm
- Mounts for 5 Fans
- Front fan mounts: 1 x 200/140mm, 2 x 120mm
- Side fan mounts: 2 x 120mm
- Rear fan mounts: 1 x 120mm
Radiator compatibility:
- Front - 140mm or 120mm
- Bottom - 240mm
- Rear - 120mm
Was £117.95 Inc. VAT
ORDER NOW
BitFenix Comrade Midi-Tower - White @ £25.99 inc VAT
Aimed squarely at builders on a budget, Comrade delivers high-end features at an incredibly competitive price point. Available in two classic colors, Comrade brings a sleek, no-nonsense design that's ideal for the first-time builder. Dedicated 3.5" and 2.5" drive racks offer ample expansion possibilities, as well as room for long graphics cards up to 30cm in length. Tool-free drive locking mechanisms make installing storage a breeze, while dual dust filters enable quick and easy cleanup. A high-speed USB 3.0 port has also been included to save you time during file transfers. Adorned with premium touches like a powder-coated interior and an aluminum-finish BitFenix badge, Comrade is a trusty mid-tower design and an unprecedented value.
Choose Your AllySleek and streamlined, Comrade's design appeals to those looking for an attractive, no-nonsense housing that fits in any modern environment. Available in both midnight black and arctic white models, users can choose the one that suits their own personal style.
Enhanced ExpansionComrade delivers a surprisingly roomy interior that accommodates a multitude of hardware options. The dedicated 3.5" and 2.5" drive racks provide ample storage, all while allowing room for long graphics cards up to 30cm in length. Along with seven PCI slots and three 5.25" bays, Comrade makes a great base for a modern system.
Easy to BuildYour PC should be your friend – not your foe. Comrade comes with multiple friendly features that make the building process a snap. Features like tool-free HDD trays and ODD retention mechanisms make installing your storage virtual child's play. Motherboard standoffs have already been built directly onto the motherboard tray, and the simple pull-off front panel with independent I/O module saves you even more time during installation.
Superspeed USB 3.0 ConnectivityWith the proliferation of HD media, files are not getting any smaller. Comrade comes equipped with a high-speed USB 3.0 port, perfect for quickly transferring files from external hard drives, thumb drives, and more.
Specifications:
- Colour (Int/Ext): White/White
- Dimensions (WxHxD): 185mm x 428.55mm x 470.5mm
- Motherboard Sizes: Mini-ITX, Micro-ATX, ATX
- 5.25” Drive Bays: x 3
- 3.5” Drive Bays: x 3
- Drive Bays: x 3
- Cooling Front: 120mm x 2 (optional)
- Cooling Rear: 120mm x 1 (1 included)
- PCI Slots: 7
- 1 x USB3.0, 1 x USB2.0, HD Audio
- Extras: Front Dust Filter, PSU Dust Filter, Tool-Free Drive Locking
Was £29.99 Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
Lian Li PC-A55A Aluminium Midi Tower Case - Silver @ £59.99 inc VAT
The new PC-A55 is a great Midi Tower case with a great front mounting PSU deisgn to enhance space and airflow. This chassis offers the usual amazing quality that you always expect from Lian Li with it's brilliant brushed aluminium panels.
- Dimensions: (W) 188mm x (H) 375mm x (D) 455mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): 1
- 3.5" drive bay (External): None
- HDD bay: 3.5-Inch HDD x2 / 2.5-Inch HDD x2
- Motherboard: ATX
- System Fan (Front): None
- System Fan (Top): 140mm Fan x 1
- System Fan (Rear): None
- System Fan(bottom): 140mm Fan x 1
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / HD Audio
- Maximum Compatibility: VGA Card length: 310mm / PSU length: 160mm / CPU cooler height: 150mm
Was £69.99 Inc. VAT
ORDER NOW
BitFenix Shadow Tower Case - Midnight Black @ £44.99 inc VAT
Featuring an incredibly clean design, Shadow brings modern BitFenix styling to a surprisingly affordable
ATX form factor. The magnetic door, coated in BitFenix SofTouch Surface Treatment, is underlined with
a selectable LED accent that can be easily switched to red, blue, or even turned off from the top control
panel. A terrific base for the modern PC, Shadow easily accommodates long graphics cards up to 320mm
in length, and CPU tower coolers up to 165mm tall. The ample storage capacity enables up to seven 3.5"
HDDs to be installed, along with a single 2.5" SSD. Two Superspeed USB 3.0 ports facilitate quick file
transfers, and removable dust filters help keep the insides dust free. Equipped with DIY friendly features
such tool-free drive locking, cable management locations, and a powder coated all black interior,
Shadow delivers a trifecta of style, function, and value.
Features
- Selectable LED Accent - Choose red or blue light, or turn the lights off with the press of a button
- Sleek and Modern- Wonderfully clean and uncompromisingly stylish
- Enhanced Hardware Compatibility- Fits long graphics cards and tall CPU coolers
- Multiple Cooling Options- Fits up to four 120mm fans with two Spectre. fans included
- Ample Storage Capacity- Install up to seven 3.5" HDDs and one 2.5" SSD
- Removable Dust Filters- Filters in front, bottom, and PSU area keeps system dust-free
- SuperSpeed USB 3.0- Two ports included for blazing file transfers and fast mobile device charging
- BitFenix SofTouch Surface Treatment - Luxurious matte finish and soft feel
- Trouble]free Installation - Large CPU cooler cutout, cable management, tool-free drive locking
Specifications
- Materials Steel: Plastic
- Colours (Int/Ext): Black/Black
- Dimensions: (WxHxD) 190 x 440 x 506mm
- Motherboard Sizes: ATX, Micro ATX, Mini]ITX
- 5.25" Drive Bays: x 3
- 2.5" Drive Bays: x 1
- Cooling Front 120mm: x 2 (1 included)
- Cooling Bottom 120mm: x 1 (optional)
- Cooling Rear 120mm: x 1 (included) or 92mm x 1 (optional) or 80mm x 1 (optional)
- PCI Slots: x 7
- I/O: USB 3.0 x 2, USB 2.0 x 2, HD Audio
- Extras: SofTouch. Surface Treatment, selectable red/blue LEDs, removable dust filters, tool-free drive locking mechanisms
Was £54.95 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - White @ £139.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage: Full Range - 100V~240V
- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
- Output: +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection: OVP/OCP/OPP/SCP/UVP
- Dimension: 200mm(L) x 150mm(W) x 86mm(H)
Connectors
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was £156.95 Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
BitFenix Pandora Micro-ATX Case w/ Icon Programmable Display - Silver @ £74.99 inc VAT
Pandora represents the next level of BitFenix chassis design. The soft curved design is surrounded by luxuriously brushed aluminium side panels that give the entire case a timelessly elegant look that melds perfectly with any modern décor. On the front of the case is another innovation dubbed BitFenix ICON™ - a programmable display that can be customized with a simple drag and drop interface, making it simple to personalize the look of your case whenever inspiration strikes. Despite its slim 160mm width, Pandora can accommodate high octane hardware, such as 240mm water cooling radiators, and expansion cards up to 350mm in length. Users are able to house up to two 3.5" HDDs or three 2.5" SSDs, and to keep all of this hardware running cool, a direct airflow design along with smart cable management features help ensure everything runs frosty. Friendly features like pre-installed standoffs and pop off screwless side panels help get your system up and running quickly, while magnetic dust filters allow for easy clean up.
Specifications:-
- Material: Aluminum, Steel, Plastic
- Dimensions: 160 x 420 x 465
- Form Factor: Micro ATX, Mini-ITX
- LCD: 2.4" TFT, 240 x 320
- 3.5" Driver Bays: 2
- 2.5" Driver Bays: 3
- Cooling top: 120mm x 1 (included)
- Cooling Front: 120mm x 2 (1 included)
- PCI Expansion slots: 5
- Front Panel: USB 3.0 x 2, HD Audio
- Power Supply Support: ATX, up to 180mm in length
- USB 3.0 x 2, HD Audio
Was £89.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
BitFenix Colossus M Micro ATX - Black @ £58.99 inc VAT
Colossus Micro-ATX adds Micro-ATX motherboard compatibility, which means added expansion possibilities including dual graphics setups such as SLI or Crossfire. The included bottom fan can be easily replaced with up to two 3.5" hard drives, and with the included removable hard drive rack, an additional two 3.5" HDDs or three 2.5" SSDs can be installed for excellent flexibility. Included magnetic heat shield prevents warm exhaust from the PSU from re-entering the case, and also looks great with its uniquely micro-textured surface. Users can also opt to install a single graphics card and a slim 240mm water cooling radiator at the same time. Users who require added PCI-express expansion are going to love Colossus Micro-ATX.
Features:-
- Futuristic Form – Bold lines with a compact design
- LiteTrak™ Technology – Smooth multimode lighting with three colours and an included pulse mode
- Maximum Storage Potential – Five 3.5" HDDs or eight 2.5" SSD locations available
- Friendly Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
Specification:-
- Extras: LiteTrak™ lighting system, SofTouch™ surface treatment, magnetic heat shield
- PCI Slots: x 5
Drives:-
- 5.25" Drive Bays: x 1
- 3.5" Drive Bays: x 4
- 2.5" Drive Bays: x 3
Cooling:-
- Top: 120mm x 2 (optional)
- Bottom: 120mm x 2 (1 included) or 200mm x 1(optional) or 230mm x 1 (optional)
- Rear: 120mm x 1 (included) or 140mm x 1 (optional)
I/O:-
Was £64.99 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv Micro ATX Case - Black @ £79.99 inc VAT
Enthoo EVOLV, an mATX/mITX chassis, sports a beautiful all aluminum exterior. The EVOLV’s unparalleled design features an all new tool free release system for the outer panels. The EVOLV supports many high end PC components while maintaining a minimalist design.
Functionalities:-
- 1x Drop-N-Lock SSD brackets included
- Multifunctional Side Bracket - (mounting for 2x SSD’s / 1x HDD)
- Removable HDD cage for installation of long PSU’s (>180mm) / waterpump
- Equiped with removable dustfilters (1x front, 1x bottom, top integrated)
- Phanteks’ PWM hub included
- Clean cable management
- Phanteks’ pre-installed Hoop-N-Loop cable ties
- Quick release panels for easy acces to fans and dustfilters
- Toolless sidepanel with swing door
Aircooling:-
- Optimal airflow - Direct airflow to CPU / GPU
- Comes with 2 Phanteks premium fans 1x PH-F200SP in front (200mm) 1x PH-F140SP in rear (140mm)
Watercooling:-
- 3 different installation areas for single or dual radiators (120mm and 140mm form factor).
- Reservoir mounting points on the Side Bracket
- Pump Bracket with vibration dampers - Mounted on Side Bracket/ HDD base
Specifications:-
- Dimension 230 mm x 450 mm x 400 mm (W x H x D)
- Form Factor Micro tower
- Material(s) Aluminum exterior, Steel chassis
- Motherboard support uATX, mITX
- I/O (side) 2x USB 3.0, Mic, Headphone
- Side window Yes
- Expansion slots 4
- External 5.25” 1 (modular)
- Internal 3.5” 3
- Internal 2.5” 5 (1 slot for upgrade)
Clearance:-
- Graphic card 318 mm
- CPU cooler 192 mm
- PSU 216 mm
- (remove Midplate cover for PSU longer than 180mm)
- Cable management 24 mm (216 mm below midplate)
- Radiator (TOP) 68 mm to motherboard (offset)
Was £89.99 Inc. VAT
ORDER NOW
Antec P380 Performance Series Windowed Tower Case - Black/Gun Metal @ £119.99 inc VAT
FULL SPEC HERE
Was £133.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Lian Li PC-Q08B USB3.0 Mini-ITX Case - Black @ £64.99 inc VAT
Mini-Q PC-Q08 is made in Taiwan, with the highest quality aluminum alloy panel. The Mini-Q PC-Q08 carries the standard of Lian Li’s quality requirement, all the sharp edges had been removed to protect user’s hand. The chassis is made of 1.5mm aluminum alloy panel to ensure product’s durability and all external parts are hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The clean shape of Mini-Q PC-Q08 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q08 is to be as simple as possible, the exterior of the case is also the structure of the chassis. To ensure you can put everything together easily, Lian Li design team decided to use only standard PC component inside the Mini-Q PC-O08, standard Mini-ITX motherboard, standard 5.25” optical drive, standard 3.5” hard drives, standard ATX PS/2 power supply units and standard graphics card.
- Dimensions: (W) 227mm x (H) 272mm x (D) 345mm
- 3.5" drive bay (Internal): 6
- Expansion Slot: 2
- Motherboard: Mini-ITX / Mini-DTX
- System Fan (Front): Black, Silver / 140mm Blue LED Fan x 1
- System Fan (Top): Black, Silver / 120mm Fan x 1
- I/O Ports: USB3.0 x 2 / HD Audio
- Maximum Video Card Size: 300mm
Was £84.95 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
BitFenix Prodigy M MATX Cube Case - Red @ £49.99 inc VAT
Sleek and Compact
Specifications
- Colors (Int/Ext): Red/Black
- PCI Slots: x 5
Was £64.99 Inc. VAT
ORDER NOW
Cougar MG100 Micro-ATX Gaming Case - Black @ £22.99 inc VAT
The Cougar MG100 Micro-ATX Case is a compact and professional looking gaming case. With a hair-line brushed aluminium effect front panel, black interior, 330mm VGA card support and USB3 as standard, the MG100 offers the perfect solution for anyone looking for a Micro-ATX gaming case on a budget.
Features
- Sleek cutting-edge with special hair-line surface front panel design
- Mini tower with superior capacity for longer high-end graphics cards up to 330mm
- High quality full black coating
- Advanced USB3.0 ports for maximum data transfer speed and high current smart phone and tablet charging
- Support for 4 fans: Front 80/90/120mm fan x 1, Rear 80/120mm fan x 1, Side 120mm fans x 2, Rear 120mm fan x 1 is pre-installed
- Screw-less design for 5.25" & HDD devices
- Support installing 2.5" HDD/SSD at bottom cover
Specifications
- Case Type: Mini Tower
- Motherboard Type: Micro ATX
- Dimension(WxHxD): 7.09x14.57x16.54( inch ), 180x370x420( mm )
- External 5.25" Drive Bays: 2
- External 3.5" Drive Bay: 1
- Internal 3.5" Drive Bays: 2
- Internal 2.5" Drive Bay: 1 (at bottom cover)
- I/O Panel: USB3.0 x1 & USB2.0 x1, Mic x1, Audio x1
- Cooling System: Front 80/90/120mm Fan x1pcs (optional), Rear 80/120mm Fan x1pcs (optional), Left Side 120mm Fans x2pcs (optional)
- COUGAR 120mm Fan (rear): 1 (pre-install)
- Expansion Slots: 4
- Maximum Graphics Card Length: 330mm
- Power Supply: Standard ATX PS2 (optional)
Was £27.95 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Deal requests taken on Cases/PSU's/Gaming Chairs
Not promising anything though!
XFX XTR 750W '80 Plus Gold' Fully Modular Power Supply @ £79.99 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 750W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
It's also been awarded the 80Plus Gold certification for its high power efficiency, and is also designed for NVIDIA SLI and AMD Crossfire multi-GPU systems, making it a perfect solution for hardcore gamers. Its modular design reduces cable clutter. And the large fan delivers silent cooling, so your computer and PSU can operate at peak performance.
Features
- EasyRail™ Plus Technology allowing plenty of wattage headroom to handle your devices
- Hybrid Fan Control allowing the power supply to operate silenty until it reaches 20% load or 25°C
- Ultra Quiet Fan Design
- Ultra Voltage Regulation Design
- Haswell Ready
- AMD Radeon CrossFire Ready
- NVIDIA GeForce SLI Ready
- Multiple PCI-E 6-Pin and 6+2Pin connectors
- True Wattage guarantee
- 80 Plus Gold certifying 90% power efficiency
- Extreme heat tested capacitors
Specifications
- +12V Rail Outputs : Single
- 100% Tested and Verified : Y
- ATX12V 2.2 & ESP12V 2.91 Compliant : Y
- Maximum Wattage (W) : 750
- Modular Cables : Y
- Performance Category : Enthusiast
- UPC Number : 778656058804
- CrossFire Ready : Y
- SLI Ready : Y
- AC Input Current (Arms) : 9.5A-4.5A
- AC Input Frequency (Hz) : 50/60 Hz
- AC Input Voltage (Vac) : 100-240
- Efficiency @ Typical Load : Up to 90%
- Energy-Efficiency : 80 Plus Gold Certified
- High Reliable 105°C Japanese Capacitors : Y
- Solid State Capacitors : Y
- Tight voltage regulation (±5%) : Y
- Max -12V Output Current (A) : 0.3
- Max +12V Output Current (A) : 62
- Max +3.3V Output Current (A) : 20
- Max +5V Output Current (A) : 20
- Max +5VSB Power (W) : 2.5
- Modular ATX12V / EPS12V : One 4+4-pin, One EPS 12V 8-pin
- Modular FDD : 1
- Modular Motherboard Connector : 20+4-Pin
- Modular Peripheral : Up to 6 Connectors
- Modular SATA : Up to 10 Connectors
- Active Power Factor Correction (PFC) : Y
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection (OTP), Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Y
- Cooling Fan Size (mm) : YES; 135mm Fluid dynamic Fan (Black)
- Master Carton Dimensions (cm) : 43.0 x 29.5 x 34.0
- Master Carton Dimensions (inch) : 16.93 x 11.6 x 13.39
- Master Carton Weight (Kg) : 11.72 est.
- Master Carton Weight (lb) : 25.84 est.
- Package Dimensions (cm) : 31.9 x 21.0 x 16.3
- Package Dimensions (inch) : 12.55 x 8.26 x 6.42
- Package Weight (Kg) : 2.76 est.
- Package Weight (lb) : 6.08 est.
- PSU Dimension (cm) : 8.6 x 15.0 x 17.0
- PSU Dimension (inch) : 3.4 x 5.9 x 6.7
- Units per Carton : 4
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
XFX XTR 850W '80 Plus Gold' Fully Modular Power Supply @ £89.99 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 850W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
Features
- Haswell Ready
- DC to DC Converter Design
- Conductive Polymer Aluminum Solid Electrolytic Capacitors
Specifications
- ATX12V 2.2 & ESP12V 2.91 Compliant : Yes
- Maximum Wattage (W) : 850
- UPC Number : 778656058811
- CrossFire Ready : Yes
- SLI Ready : Yes
- AC Input Current (Arms) : 11A - 5.5A
- AC Input Voltage (Vac) : 100 - 240
- Active Power Factor Correction (PFC) : >0.95 at full load
- DC Output Voltage Regulation : ±3%
- DC to DC Converters (+3.3 & +5V) : Yes
- EZ Grip Connectors : Yes
- High Reliable 105°C Japanese Capacitors : Yes
- Solid State Capacitors : Yes
- Max -12V Output Current (A) : 0.8
- Max -12V Power (W) : 6
- Max +12V1 Output Current (A) : 70
- Max +12V1 Power (W) : 840
- Max +3.3V & +5V Combined Power (W) : 125
- Max +3.3V Output Current (A) : 25
- Max +5V Output Current (A) : 25
- Max +5VSB Output Current (A) : 3
- Max +5VSB Power (W) : 15
- Max. +3.3V & +5V combined power (W) : 125
- Wattage(W) : 850W
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection, Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Yes
- Cooling Fan Size (mm) : 120
- Intake Fan: Airflow (CFM/min) : 80.5
- Intake Fan: Diameter (mm) : 120 x 120 x 25 mm
- PSU Dimension (cm) : 8.6 x 14.0 x 16.0
- PSU Dimension (inch) : 3.4 x 5.5 x 6.3
- RCM : Yes
- CB : Yes
- cTUVus : Yes
- TUV: Yes
- CCC: Yes
- FCC: Yes
- CE: Yes
Connectors
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 6x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was £99.95 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Antec EDGE 650w 80 Plus Gold Fully Modular Power Supply @ £77.99 inc VAT
Description
Antec's EDGE series is the pinnacle of power supplies. EDGE is fully modular with a revolutionary 18+10-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS® GOLD & ErP Lot 6: 2013 certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies.
EDGE's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. All cables are darkened and also flat (except MBU cable) to become Flat Stealth Wires and are thus nearly invisible in your chassis. 2 High Current Rails and a ~99% +12V output ratio maximize EDGE's capabilities to power the latest CPU's & GPU's.
CircuitShield™ makes EDGE safe and reliable in any environment with its 7 industrial-grade protections. Backed by a 5 year warranty and lifetime global 24/7 support, EDGE embodies everything a power supply can accomplish today.
Specifications
- 650W Continuous Power - Guaranteed 650W of Continuous Power from Antec
- 80 PLUS® GOLD certified - Up to 92% efficient, to reduce your electricity bill
- AQ5 - Antec Quality 5 year warranty and lifetime global 24/7 support
- 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
- 135 mm LED FDB Silence - Whisper-quiet high-quality LED fluid-dynamic bearing fan with long lifetime
- Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
- High Current Rails - 2 +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
- 98.2% +12V - Output for maximum CPU & GPU support
- 28(18+10)- pin MBU socket - For possible future MBU connectors
- CircuitShield™ - Full suite of industrial grade protections: Over Current Protection (OCP), Over Voltage Protection (OVP), No Load Operation (NLO), Short Circuit Protection (SCP), Over Power Protection (OPP), Over Temperature Protection (OTP) & Surge & Inrush Protection (SIP)
- Japanese Heavy- Duty Caps - High-performance Japanese capacitors ensure tightest DC stability and regulation
- Flat Stealth Wires - Flat and darkened wires for minimal visibility in chassis (except MBU cable)
- ATX12V 2.4 - Engineered according to the newest PSU guideline and compatible with the latest CPU generation
Connectors
- 1 x 20+4 Pin
- 1 x 8 Pin EPS
- 4 x 6+2 PCI-E
- 9 x SATA
- 6 x MOLEX
- 1 x Floppy
- 5 Year warranty
Was £89.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Antec EDGE 750w 80 Plus Gold Fully Modular Power Supply @ £86.99 inc VAT
Description
Specifications
- 750W Continuous Power - Guaranteed 750W of Continuous Power from Antec
Connectors
- 1 x 20+4 Pin
- 1 x 8 Pin EPS
- 6 x 6+2 PCI-E
- 9 x SATA
- 6 x MOLEX
- 1 x Floppy
- 1 x 4+4 Pin ATX/EPS
- 5 Year warranty
Was £99.99 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
BeQuiet Straight Power 10 500W '80 Plus Gold'' Power Supply @ £69.95 inc VAT
be quiet! Straight Power 10 provides a new level of silent performance for systems that demand whisper-quiet operation without compromising on power quality.
Features
- Virtually inaudible SilentWings 3 135mm fan with improved fan frame
- Big funnel-shaped fan opening of the PSU case induces high airflow intake
- 80PLUS Gold power efficiency (up to 93%)
- Four high-performance 12V-rails
- Power signal stability unmatched in its class
- Powerful GPU support with up to four PCI-Express connectors
- Premium 105°C-rated parts enhance stability and reliability
- ErP 2014 ready
- Product conception, design and quality control in Germany
- 5-year warranty
Specifications
- Model: 500W
- Partcode: BN231
- EAN: 4260052183649
- Voltage / Frequency: 100-240Vac / 50-60Hz
- ATX 12V 2.4 / EPS 12V 2.92: Yes
- Dimensions (L x W x D): 160 x 150 x 86
- SilentWings Fan: Yes
- Noise level (dB(A)) at 20 / 50 / 100% load: 10.2 / 10.9 / 15.5
- Efficiency (%) at 230V: Up to 93%
- 12V Rails: 4
- Active PFC: Yes
- OCP, OVP, UVP, SCP, OPP, OTP: Yes
- Certifications: 80 PLUS Gold
- Energy Star 6.0 compatible: Yes
- ErP2014 ready: Yes
- Lifetime of fan at 25°C (h): 100,000
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 9 x SATA
- 3 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £74.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
BeQuiet Power Zone 750W '80 Plus Bronze' Fully Modular Power Supply @ £89.99 inc VAT
The Power Zone series provides the winning combination of superior performance, rock-solid stability, and advanced cooling. Whether you are assembling a high power PC or multi-GPU gaming system, your build will benefit from the Power Zone features.
Features
- Massive 12V rail design is ideal for overclocking
- Full cable management supports maximum build flexibility
- COOL*OFF feature run fans for three minutes after system shutdown
- Connect up to three case fans for optimized system cooling
- Designed for powerful operation even at 50° C
- 135mm SilentWings fan with innovative 6-pole motor enables quiet operation
- 80PLUS Bronze efficiency (up to 90%)
- Up to six PCI express connectors (NVIDIA SLI, AMD CrossFireX)
- Compatible with Intel C6/C7
- Five-year warranty
- German product conception, design and quality control
Specifications
- Continuous power (W): 750
- Model: BN211
- Voltage / Frequency: 100–240Vac, 50–60Hz
- Dimensions (LxWxH): 86 x 150 x 175
- be quiet! fan (mm): 135mm Silentwings
- Noise level (dbA) at 20 / 50 / 100% load: 13.6 / 17.4 / 34.9
- Efficiency (%) at 230V: up to 90
- 12V Rails: 1
- PFC: Active
- Certifications: 80Plus Bronze, nVidia SLI, AMD CrossFireX
- Energy Star 5.2 Compatible: Yes
- ErP2013 ready: Yes
Connectors
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £99.95 Inc. VAT
ORDER NOW
BeQuiet Pure Power L8 730W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in @ £77.99 inc VAT
nonl2br
The Pure Power L8 series proves that true affordability means peerless dependability and best-in-class features — not cutting corners and settling for less. Whether you are assembling a very quiet higher-powered system, building a better multimedia or dual-GPU gaming system, or upgrading an existing PC, your build will benefit from the premium features be quiet's German team has designed into this PSU.
Features
- Silence-optimized 120mm be quiet! fan with durable Rifle-Bearing-Technology
- Certified 80PLUS Bronze efficiency (up to 88%)
- Modular Cable Management with sleeved cables for reduced clutter and better airflow. All-in-one cable with SATA, HDD and FDD connector
- Supports multi-GPU systems (400-700W)
- Meets energy-saving requirements of Intel C6/C7, ErP 2013 and Energy Star 5.2 guidelines.
- Ready for Intel ® Haswell TM platform
- Stronger +12V rails increase power stability
- Full suite of top safety protections defends against over-currents, over- and under-voltages, short circuits, overheating and overloads, thus safeguarding valuable components
- Three year warranty
Specifications
- Continuous power (W): 730
- Model: BN183
- ATX 12V 2.31 / EPS 12V 2.92: Yes
- Dimensions (LxWxH): 160 x 150 x 86
- be quiet! fan (mm): 120 Silent Wings
- Noise level (dbA) at 0 - 100% load: 15-29
- Efficiency (%) at 230V: up to 88
- 12V Rails: 2
- PFC: Active
- Certifications: 80Plus Bronze, AMD CrossFireX
- Energy Star 5.0 Compatible: Yes
Connectors
- 2 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 5 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 3yr
Was £86.99 Inc. VAT
ORDER NOW
Cougar GX V3 600W '80 Plus Gold' Modular Power Supply @ £62.99 inc VAT
New high-end series of power supplies specifically targeting demanding gamers, the COUGAR GX V3 series. The 80Plus Gold certified GX V3 series provides up to 93% peak efficiency. The advanced cable management solution allows users to only use those cables their peripherals actually need, thereby effectively reducing cable mess while at the same time improving air circulation and ventilation within the case.
The rugged black coating in combination with the gold vent grill add to the overall robust and aggressive appearance of these units, thereby effectively increasing the game-style looks. COUGAR GX power supply, your best choice.
Features
- 80-PLUS® GOLD CERTIFIED: Up to 93% of efficiency, compliant with 80-PLUS® GOLD efficiency requirement
- ULTRA-QUIET & TEMPERATURE-CONTROLLED 140mm FAN: 140mm double ball bearing fan deliver optimum air flow with extremely low noise level, the fan speed automatically governed based on the temperature
- ADVANCED MODULAR CABLE: The advanced modular cable management is further improved by utilizing new flat cables that simplify installation as well as reducing air friction in order to maximize airflow. This gives gamers the power they need, and flexibility of easy upgrades they demand
- COMPATIBLE WITH LATEST PC-TECHNOLOGY: Supports the newest specifications of ATX12V v2.31 and EPS 2.92 standards. Created for usage with current and next-generation multi-core CPU platforms
- SUPPORT MULTI-GPU TECHNOLOGY: Support PCI Express 2.0 next-generation graphic card with 8(6+2)pin PCI-E connector
- 105 °C JAPANESE CAPACITORS: Highest durable 105°C Japanese capacitors provide uncompromised performance and reliability, delivering 4 times the lifespan of conventional 85°C rated capacitors.
- HIGH PERFORMANCE AT 50°C: Non-stop high performance and full rated wattage at 50°C/122°F ambient temperature.
- DYNAMIC MULTI-12V: Automatic dynamic load distribution on multi-12V lines provide high voltage stability power separately to the GPU and the CPU. If you are not using all output lines, the PSU automatically reroutes needed power from unused lines. This improves the performance and safety of the 12V lines considerably for systems with high-end graphics cards in SLI® or CrossFire® mode
- COMPLIANT WITH THE LATEST ErP Lot6 2013: In Standby consumption is <0.3W, compliant with economy-friendly electrical equipment
- FULL PROTECTIONS WITH OCP, SCP, OVP, UVP, OPP & OTP
Specifications
- AC Input: 110-240Vac, 50-60Hz, 10-5A
- Output: 600W
- Certification: 80 Plus Gold Certified
- Dimensions (L x W x H): 160 x 150 x 86
- UVP (Under Voltage Protection): If the voltages fall below a certain tolerance value on the single lines, the PSU automatically switches off.
- OVP (Over Voltage Protection): If the voltages increase above a certain tolerance value on the single lines, the PSU automatically switches off.
- SCP (Short-Circuit Protection): In the case of a short-circuit this feature prevents damage to the core components of the PSU and its system components.
- OPP (Over Load Protection): If the system is over sized and requires more power from the PSU than it can perform, this protection function is activated.
- OCP (Over Current Protection): If the load on a single line is higher than indicated, the PSU automatically switches off.
- OTP (Over Temperature Protection): If the temperature is too high, the PSU automatically switches off.
Connectors
- 4x 6+2-Pin-PCIe
- 6x SATA
- 3x 4-Pin-Molex
- Warranty: 5yr
Was £69.95 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Cougar GX V3 800W '80 Plus Gold' Modular Power Supply @ £79.99 inc VAT
Features
Specifications
- Output: 800W
Connectors
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 4x 4-Pin-Molex
- Warranty: 5yr
Was £89.99 Inc. VAT
ORDER NOW
Here's some super special deals on SuperFlower, including some new models, just for the forum members!!!
SuperFlower Leadex Gold 1600W Fully Modular "80 Plus Gold" Power Supply - Black @ £184.99 inc VAT
SuperFlower, one of the worlds leading power supply manufacturers have added the Leadex 1600W Gold to their range, offering up to 90% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage Gold rated PSU's on the market.
The SuperFlower Leadex Gold 1600W Power Supply features a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 87% 90% 87% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 220 mm (W x H x D)
- Fan: 140 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 90% (115V), 80 Plus Gold certificate
- Active PFC
- Form Factor: ATX12V 2.2 / EPS12V 2.92
- Power: 1600W
- 3.3V: 24 A
- + 5V: 24 A
- + 3.3V & + 5V combined: 120 W
- + 12V: 1,599.6 W / 133.3 A
- -12V: 6 W / 0.5 A
- + 5VSB: 15 W / 3.0 A
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-1600F14HG
Connectors
- 1 x 8-Pin EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Was £224.99 Inc. VAT
Only £184.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 550W Fully Modular "80 Plus Platinum" Power Supply - Black @ £76.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed a full Leadex Platinum range, all with 80 Plus Platinum Certification, offering up to 92% efficiency with class leading features, as well as offering capacities from 550W - 2000W.
All Leadex Platinum Power Supplies feature a fully modular design, 135mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Platinum series are a brilliant choice for anyone who wants great performance and efficiency in their system, along with the flexibility of various wattages to suit everyones needs.
Features
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
Specifications
- Dimensions: 150 x 86 x 165 mm (W x H x D)
- Wattage: 550W
- Fan: 135 mm DBB(automatic control, semi-passive)
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Partcode: SF-550F14MP black (UK)
Connectors
- 3 x 6+2-Pin-PCIe
- 7 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
Was £86.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
SuperFlower Leadex Titanium 1000W Fully Modular "80 Plus Titanium" Power Supply - Black @ £179.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed the Leadex Titanium range, with full 80 Plus Titanium Certification, offering up to 94% efficiency with class leading features, as well as offering capacities from 750W - 1600W.
All Leadex Titanium Power Supplies feature a fully modular design, 140mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Titanium series are an uncompromising masterclass of design and functionality and should be the first choice for any gaming system that needs one of the most efficient power supplies on the market!
Features
- 80 PLUS ® Titanium Certified, 90% 92% 94% 90% Efficiency At 10% 20% 50% 100% Rated Load
Specifications
- Dimensions: 150 x 86 x 180 mm (W x H x D)
- Wattage: 1000W
- Efficiency: max. 94% (115V), 80 Plus Titanium certificate
- Active PFC
- Partcode: SF-1600F14HT
Connectors
- 2 x 4+4-Pin ATX12V/EPS12V
- 6 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 12 x SATA
- 6 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £199.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
AK Racing Octane Gaming Chair - Orange @ £199.99 inc VAT
AK Racing seats offer stylish esports looks alongside well considered ergonomics.
The new Octane series is a great looking new chair, with high-quality PU leather and a stripe design with fantastic style. The Octane series is also featuring the new shaped armrest to bring even more comfort when sitting in it; perfect for long gaming sessions.
This particular new chair model comes in 6 different colours: black, blue, white, red, green and orange. Boring office chairs are the last thing any gaming enthusiast wants! Don't suffer these boring solutions any longer, now you can have the same style chair that professional gamers use in tournaments around the world!
Perfect for office workers and gamers, AK Racing seats are a high quality and exciting solution to the various health disorders resulting from bad posture.
Styled after Race Car seats and implementing very high quality materials, AK Racing are the ultimate desk accessory and compliment your pro gamer attitude perfectly whilst being hard wearing and durable.
Featuring supportive seat bolsters, just like a real bucket seat, your posture will be perfect whilst at your desk.
All AK Racing seats come with multiple points of adjustability so that you can tailor the position of the seat perfectly.
Features
- Colour: Orange
- Quality upholstery material. OCTANE series uses PU Leather.
- Metal Construction: Each seat has a sturdy metal frame.
- High quality, comfortable hard foam, not prone to deformation over time.
- Adjustable Armrests.
- Adjustable Back Angle: 180-degree backrest adjustment allows you to adjust it to your needs.
- Adjustable tilt, height and back.
- Reinforced wheels: designed not to scratch hardwood or laminate floors.
- Very Strong Metal base with class 4 gas lift support up to 150KG.
- Cushions Included for optional lower back and head/neck support.
Dimensions
- Shoulder Width: 540mm
- Waist Width: 500mm
- Seat Width: 370mm
- Back Height: 920mm
- Seat Length: 560mm
- Seat Height: 500-420mm
- Armrest Heights: 340-270mm
Was £229.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
AK Racing Octane Gaming Chair - Blue @ £199.99 inc VAT
Features
- Colour: Blue
Dimensions
- Seat Width: 370mm
ORDER NOW
AK Racing Player Gaming Chair - Black / Blue @ £199.99 inc VAT
nonl2br
Features
- Colour: Blue & Black
- Quality upholstery material. PLAYER series uses PU Leather.
- Metal base with class 4 gas lift support up to 150KG.
Dimensions
- Shoulder Width: 565mm
- Waist Width: 550mm
- Seat Width: 365mm
- Back Height: 950mm
- Seat Height: 510-430mm
ORDER NOW
Arozzi Torretta XL Gaming Chair - Green @ £149.99 inc VAT
The Arozzi Torretta XL is one cool gaming chair, which has a racing inspired look. High quality, thick padding on the arm rests, seat and, back gives you the highest comfort.
The Torretta XL chair is one of the first chairs to be designed for people with the need of a larger and wider chair. With the same features and design as its precursor, but with wider seat and backrest this chair will bring supreme comfort without feeling tight.
Features
- Colour: Green & Black
- Metal frame construction.
- Thick padded seat and backrest.
- Ergonomic design.
- Fabric upholstery material.
- 360 Degree swivel rotation.
- Adjustable armrest (height and rotation)
- Adjustable height gas-spring, supports up to 180KG.
- Tiltable seat with lock function
- Lightweight construction for easy movement.
- Five twin wheel nylon casters.
- 7 different colour choices.
Technical Details
- Shoulder Width: 590mm
- Waist Width: 450mm
- Seat Width: 480mm
- Chair Height: 1280mm
- Seat Length: 460mm
- Seat Height: 400-330mm
- Armrest Heights: 370-270mm
Only £149.99 inc VAT.
ORDER NOW
Arozzi Torretta XL Gaming Chair - Orange @ £149.99 inc VAT
Features
- Colour: Orange & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
Arozzi Torretta XL Gaming Chair - Azure @ £149.99 inc VAT
Features
- Colour: Azure & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
Arozzi Torretta XL Gaming Chair - Red @ £149.99 inc VAT
Features
- Colour: Red & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
BitFenix Prodigy M MATX Cube Case - Blue @ £49.99 inc VAT
An evolution of a classic. The Prodigy revolutionised our perspective on small form factor case design and what a small computer was capable of. The Prodigy M takes this concept to the next level
Reimagined with micro ATX compatibility, Prodigy M enables users to install multiple expansion cards while maintaining the same compact dimensions and sleek look of the original Prodigy. Suspended with two FyberFlex Composite handles for shock absorption, Prodigy M can be easily transported to the next room or to the next LAN party.
The inside is incredibly flexible, offering space for SLI or Crossfire dual graphics technology, up to four 3.5" hard drives or five 2.5" SSDs, and even space for slim 240mm radiators. A magnetic heat shield is also included should you decide to fill the bottom with hard drives rather than fans. With BitFenix SofTouch Surface Treatment, a massive CPU cooler cutout, and rolled-edge cable pass-throughs, the small case that does it all returns with a vengeance.
Full MATX Compatibility
You asked, we delivered. Prodigy M now features full compatibility with micro-ATX motherboards, all while maintaining the same compact dimensions as the original award-winning Prodigy. Featuring an all-new layout, Prodigy M is truly flexibility reimagined.
Sleek and Compact
One thing that hasn't changed is the sleek and clean look of the original Prodigy. Sporting two exquisitely crafted handles that suspend the body, Prodigy M has the same modern yet elegant styling that made the original the small form factor case of choice for PC enthusiasts the world over.
Tremendous Flexibility
Of course, Prodigy M couldn't carry the Prodigy name without the flexibility to match. Aside from both micro ATX and mini-ITX compatibility, Prodigy M can be configured with up to four 3.5" HDDs or five 2.5" SSDs for excellent storage potential. Adding in a micro ATX motherboard gives you up to four expansion slots, perfect for additional expansion cards, or even SLI and Crossfire dual graphics capability.
To keep things running frosty, Prodigy M can be outfitted with up to five fans for maximum cooling. Bolt a thin 240mm radiator on top, or perhaps a 120mm radiator on the rear. With the roomy interior, even tower CPU coolers up to 160mm will fit with ease. No matter how you prefer to cool your system, Prodigy M has you covered.
Specifications
- Colors (Int/Ext): Blue/Black
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Micro ATX, Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 4 (2 + 2)
- 2.5” Drive Bays: x 5 (3 + 2)
- Cooling Top: 120mm x 2 (optional)
- Cooling Bottom: 120mm x 2 (1 included) or 200mm x 1(optional) or 230mm x 1 (optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1 (optional)
- PCI Slots: x 5
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, heat shield
Was £64.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
BitFenix Shinobi XL Full Tower Gaming Case - Black @ £104.99 inc VAT
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts.
Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.
Specifications
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX
- 5.25” Drive Bays: x 5
- 3.5” Drive Bays: x 7
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)
- Cooling Bottom: 2 x 120mm (optional)
- PCI Slots: 9
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking
- Maximum CPU Cooler Height: 193mm
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)
- Maximum MB Tray Clearance (rear): 34.5mm
Was £124.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
NZXT HUE RGB LED Controller - Black @ £19.99 inc VAT
NZXT has expanded their bay devices with HUE; an LED configuration that is customizable to your liking. HUE grants you the power to select how you want to illuminate your chassis with infinite possibilities. Take charge of the RGB controls to adjust the color fade, pulsating light effects, and brightness levels of your internal LED sleeve. HUE is equipped with an on/off mode for times you may need to go stealth and possesses a unique semi-mesh design, blending flawlessly into any chassis with a mesh front panel.
- Infinite color options that you can customize to your heart’s content
- Three RGB controls to adjust the color settings, brightness level, and pulse speed of the internal LED sleeve
- On/off mode to completely disable the LEDs
- Effect modes: normal, fading, flashing, and pulsating of colors
- Internal LED sleeves that vibrantly illuminates and accents your chassis based on your liking
- Unique mesh design that blends flawlessly into any chassis with a mesh front panel
- 5.25" ODD
- 3 RGB dials
- 5 Brightness Levels
- Modes: NORMAL, FADING, FLASHING, COLOR FADING, AND COLOR FLASHING
Was £24.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
BitFenix Prodigy Mini-ITX Cube Case - Slime Green @ £49.99 inc VAT
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
Specifications
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- PCI Slots: x 2
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Was £64.99 Inc. VAT
ORDER NOW
Silverstone SST-FT05B-W Fortress Tower ATX - Windowed Black @ £121.99 inc VAT
The Fortress FT05 represent SilverStone’s continued dedication in improving and reinventing computer chassis design. Similar to the RAVEN RV05, it no longer has any 5.25” drive bay and utilizes SilverStone’s fame 90 degree rotated design. Previous full ATX SilverStone chassis with 90 degree layout often had to compromise on space efficiency due to fixed length of the motherboard in rotated orientation. So the elimination of 5.25” bays solves this issue naturally and enables FT05 to be not only more balanced in proportion but stunning in its design thanks to its thick wrap-around aluminum exterior.
With majority of wasted space eliminated, the FT05 is better optimized for components that affect performance the most such as CPU and GPUs. The result is an expertly-engineered ATX chassis that is just as capable in terms of compute power and heat dissipation as the first RAVEN chassis, the RV01, but in half the size. Equipped with latest revision Air Penetrator fans that include three speed switches and modern touches such as externally removable filters and tool-less panels, the FT05 has everything that PC enthusiasts could wish for in a compact, high performance computer chassis that is not only cool and quiet, but also easy to build and maintain. For those not wanting to constantly step up in chassis size to obtain top-level performance, the Fortress FT05 is perhaps the best and most beautiful solution.
Features
- Aluminum wrap-around exterior with classic SilverStone Fortress styling
- Revolutionary 90 degree motherboard mounting from RAVEN RV01
- Breakthrough 5.25 inch bay-free design for unprecedented power to size ratio
- Two Air Penetrator fans included for great performance and quietness
- Positive air pressure design for excellent cooling/quietness and dust-prevention
- Foam padded interior for advanced noise absorption
- Quick-release latch for fast side panel removal
- Exterior access to main filter for easy maintenance
- Support for various liquid cooling radiator sizes
Specification
- Model No: SST-FT05B-W (black + window)
- Material: Aluminum front, bottom, and rear panels, steel body
- Motherboard: SSI-CEB, ATX, Micro-ATX
- Drive Bay: External - Slim slot-loading optical x 1, Internal: 3.5" x 2, 2.5” x 2
- Cooling System: Front: -, Rear: -, Side: -, Top: 120mm fan slot x 1, Bottom: 180mm AP fan x 2, 600/900/1200rpm, 17/25/34dBA, Downward compatible with 120mm fan x 3, or 140mm fan x 2, Internal: -
- Expansion Slot: 7
- Front I/O Port: USB 3.0 x 2, Audio x 1, MIC x 1
- Power Supply: Optional PS2(ATX)
- Expansion Card: Compatible with 12.3” long, width restriction – 6.57”
- Limitation of CPU cooler: 162mm
Limitation of PSU: -
- Net Weight: 9.5kg
Dimension: 221mm (W) x 483mm (H) x 427mm (D), 46 liters
Was £144.99 Inc. VAT
Only £121.99 inc VAT.
ORDER NOW
Antec VPF550 550W '80 Plus Bronze' Power Supply @ £47.99 inc VAT
Get economical power today with the VPF BRONZE series, Antec's high-efficiency power supply solution. Featuring 80 PLUS® BRONZE certification, a quiet 120mm fan, and universal input with active power factor correction (PFC), the VPF BRONZE series gives you a cooler, quieter system all powered by Continuous Power. The VPF BRONZE series also features industrial safety protection, including short circuit and over voltage protection, for stable and reliable power no matter what.
Specifications
- 550W Guarenteed wattage of Continuous power from Antec
- Manufactured by Delta Electronics
- 80 Plus Bronze Certified
- Intel Haswell Ready
- 120mm Silence Fan; whisper-quiet high-quality bearing fan with long life
- Thermal Manager; An advanced low voltage fan control for optimal heat & noise management
- Multi PCI-E connectivity support
- Circuity Sheild: Full suite of industrial grade protections: OCP/OVP/UVP/SCP/OPP/OTP/SIP/NLO/BOP
- High Current Rails: Dual +12v rails with high load capacities to ensure maximum CPU & GPU compatibility
- > 93% +12V : 99.2% VPF550
- ATX12V 2.4
- Heavy Duty Caps: High performance capacitors ensure the tightest DC stability and regulation
- ErP Lot 6: 2013
Connectors
- 1 x 20+4 Pin
- 1 x 4+4 Pin
- 2 x 6+2 Pin PCI-E
- 5 x SATA
- 3 x MOLEX
- 1 x Floppy
- AQ3 : Antec 3 Year warranty and lifetime 24/7 Support
Was £52.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
Corsair Carbide 300R Mid Tower Case - Black (CC-9011014-WW) @ £59.99 inc VAT
The Carbide Series™ 300R is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5” SSD compatibility. There’s room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There’s room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
- Room for graphics cards up to 450mm long
- USB 3.0 front panel connectors
- Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need
- Keep your system cool with up to 7 fan mount locations
- Easily accessible dust filters keep the cool air flowing over your valuable components
- Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout
- Optimize airflow and keep your system neat and tidy using the intelligent cable management system
- Drive Bays: 3 x 5.25" Drive Bays and 4 x 3.5"/2.5" Drive Bays
- Cooling: 1 x 140mm intake fan and 1 x 120mm exhaust fan
- Expansion Slots: 7
- Motherboard Support: ATX & mATX
- Front I/O: 2 x USB3.0 and 2 x Audio
- Dimensions: 19.1" x 8.3" x 17.7"
Was £65.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
BitFenix Colossus Red LED Big Tower Windowed Case - Black @ £99.95 inc VAT
Introducing BitFenix Colossus – the PC chassis for the uncompromising enthusiast. Offering unmatched expandability, security, and cooling all wrapped up in a modern and elegant body, Colossus represents months of intensive research, product development, and meticulous design. The result is a chassis like no other; a chassis that serves as an ideal enclosure for the most colossal gaming rigs.
Ready for the Future
The next generation of USB connectivity is here. Equipped with two USB 3.0 ports, Colossus allows you to connect an ever-growing number of USB 3.0 devices and experience data transfer speeds up to ten times that of USB 2.0. With USB 3.0 already built-in, Colossus can last you several upgrades, further future-proofing your system.
At Your Command
Designed to be the center of your digital domain, Colossus puts you in command with a PWM fan controller and multimode light controls. Tune your fans down for silence or up for extra cooling. Select your desired lighting color or turn them off completely. With Colossus, control is always at your fingertips.
Advanced LED Lighting System
Perhaps the most striking feature of Colossus at first glance is the advanced LED lighting system. The Colossus includes front panel LED's and two internal LED fans, which like the front panel LED's can be turned on and off with the touch of a button
Unmatched Security with BitFenix S3
Colossus introduces a BitFenix exclusive – S3. S3 is a storage compartment and security system in one. Place your iPhone, hard disk, or other valuables in S3 and lock them away for safe keeping. S3 will even lock down peripherals like USB mice and keyboards plugged into it, and secure everything under lock and key. Simple, safe and secure – that’s BitFenix S3.
Complete Cable Management
Messy cables not only look bad, but they can also restrict airflow in a chassis. That’s why Colossus is designed to manage cables both inside and out. Keep cables from cluttering the inside of the chassis with Colossus' strategically-placed cable holes. Prevent cables from getting caught in opening optical drives with the unique cable-holding front bezel.
Epic Expandability
Colossus gives you the space to build your own supercomputer. Capable of accommodating eight PCI express devices and seven 2.5" SSDs or seven 3.5" hard disk drives, Colossus is ready for multiple upgrades – perfect for a rig of epic proportions.
Massive Cooling
When the action heats up, your system needs to keep its cool. Colossus can be outfitted with up to two 230mm fans, three 140mm fans, or three 120mm fans, meaning huge cooling potential for all system components.
Easy Installation
Big doesn't have to mean unwieldy. Featuring a motherboard CPU cooler cutout on the motherboard tray, specially-designed motherboard standoffs, and an almost completely tool-free design, getting your system up and running with Colossus is a joy. Large yet welcoming, if Colossus reminds you of a friendly giant, we wouldn’t blame you.
Specifications:
- Materials: SECC, ABS
- Color (Int/Ext): Black
- Dimensions (WxHxD): 245 x 558 x 582 mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, E-ATX
- 5.25" Drive Bays: x 5 (1 x external 3.5"; tool-free)
- 3.5" Drive Bays: x 7
- 2.5" Drive Bays: x 7 (using standard 3.5" drive bays)
- Cooling Front: 1 x 230mm included
- Cooling Rear: 1 x 140/120mm (not included)
- Cooling Side Panel: n/a
- Cooling Top: 1 x 230mm included (or 1 x 140/120mm not included)
- Cooling Bottom: 1 x 140/120mm (not included)
- PCI Slots: 8 (tool-free)
- I/O: 2 x USB3.0, 2 x USB2.0, eSATA, Audio
Only £99.95 inc VAT.
ORDER NOW
BitFenix Phenom MATX Cube Case - Arctic White @ £54.95 inc VAT
The latest BitFenix small form factor chassis, Phenom Micro-ATX combines an elegantly modern outlook with an incredibly flexible internal structure for a cube design like no other. The subtle curves coated in premium BitFenix SofTouch™ Surface Treatment offer a luxuriously matte finish, while the clean and uncluttered styling makes Phenom a perfect fit in virtually any environment.
Designed for Micro-ATX motherboards, Phenom Micro-ATX delivers superb flexibility with support for dual long graphics cards, tall CPU coolers, and even slim water cooling radiators. Users can install up to four hard disks or six SSDs, and two high-speed USB 3.0 ports ensure lightning-quick transfers of today's high-definition media. Along with a fully powder-coated interior, rolled cable pass-throughs, and unique heat shield, Phenom Micro-ATX delivers the quintessential BitFenix experience in an SFF form factor.
Features
Clean and Modern Styling - Phenom was engineered to be a sleek modern cube design that fits in any environment. Mesh accents on the sides strikingly compliment the clean and uncluttered top, front, and side panels, while the high-gloss BitFenix logo in front provides a perfect contrast to the luxuriously soft matte finish of the SofTouch™ Surface Treatment. These elements combine with the subtle contours of the panels to form a timeless design ideal for a modern décor.
MATX Compatibility - Featuring no less than five expansion slots, Phenom Micro-ATX accommodates micro-ATX motherboards to enable dual graphics capability such as SLI or Crossfire, or added expansion cards.
Superb Flexibility - Tiny but mighty, Phenom Micro-ATX delivers an exceedingly flexible interior. Install dual graphics cards up to 320mm in length, or opt for a single graphics card and a slim 240mm water cooling radiator up top. Those who prefer air cooling will be pleased to see that tall CPU coolers up to 160mm can be mounted with no fuss. When it comes to hardware compatibility, Phenom-MATX is truly phenomenal.
Specification
- Materials: Steel, Plastic, SofTouch™
- Colors (Int/Ext): White/White
- Dimensions (WxHxD): 250 x 330 x 374mm
- Motherboard Sizes: Micro-ATX, Mini-ITX
- 3.5” Drive Bays: x 5 (4 + 1 using included adapter)
- 2.5” Drive Bays: x 5 (2 + 2 + 1 using included adapter)
- PCI Slots: x 5
- Extras: SofTouch™ surface treatment, magnetic heat shield
</p>
Was £64.99 Inc. VAT
Only £54.95 inc VAT.
ORDER NOW
Raijintek Aeneas mATX Cube Case - White Windowed @ £54.95 inc VAT
AENEAS, Raijintek’s special type chassis – Cube Micro ATX, is developed with elegant design, super intake/outtake airflow, and spot catch LED bar. Not only AENEAS brought to you fashion and elegant style, but AENEAS also brings you a sturdy chassis body (0.8mm SGCC) and with surprising function and features.
With awesome fan installation function to provide cooling performing, AENEAS is bale to install Max. 8 fans, 200mm fan optional at front, 2 * 140mm fans pre-installed at rear, 2*120mm fans pre-installed at front, and additional to install 240mm radiator at front or top. Superior features includes Removable M/B plate for easy installation of coolers, Switch off button of LED lighting, Compatible wtih 180mm height CPU cooler, VGA card length to 310mm and Regular ATX PSU compatibility. What a awesome chassis enthusiasm is looking for, it must be AENEAS.
- Elegant LED light bar design (on/off switch)
- User Friendly design – removable M/B frame and tool-free screws
- Classic design with efficient and mass airflow
- Complete black coated interior
- Dust-control filters for all mesh area
- Sturdy and reliable chassis body Chassis body: 0.8mm SGCC
- Accommodate an internal 240 mm radiator at front ; an 280mm radiator at top
- Powerful fan systems pre-installed: two 140mm at rear; two 120mm at front.
- Supports to up to eight fan installation; 200mm fan option at front
- Supports to install four 3.5”HDD (or four 2.5” HDD) and five 2.5” HDD (optional cage)
- Fully supports Tool-free for ODDs & HDDs
- Two high speed USB3.0 and two USB2.0
- Supports VGA card up to 310mm
- Support CPU cooler height up to 180mm
Specfication:-
- Internal color Matt Black
- Dimension chassis body (D/W/H) 352*288*380mm
- Dimension chassis body (D/W/H) 380*288*430mm
- Body Weight (N.W.) Kg
- Material SGCC 0.8mm
- M/B Type MICRO-ATX?ITX
- Graphic Card Support yes
- Power Supply PS-2
- Power Supply Integration Internal Bottom PSU (vertical)
- 5.25" Drive Bays 1
- 3.5" Device 1 exposed +4 hidden
- 2.5" Device (option/removable) 5
- I/O Panel USB3.0 *2 + USB2.0*2
- Hot Swappable n/a
- PCI Slot 5
- PCI Slot Tool-free Yes
- ODD & HDD Tool-free Yes
- CPU Cooler Height 180mm max.
- Graphic Card Length 310mm
- Side Panel Style Flat / Vent
- Cable Management Regular
- Water Pipe holes 2
- Front Cooling Fan 120mm*4 (2pcs pre-installed) ; 200mm fan (option) or
- 240mm radiator (option)
- Rear Cooling Fan 140mm*2pcs (pre-installed)
- Left Side Cooling Fan Option
- Right Side Cooling Fan option
- Top Cooling Fan 140MM*2 (option)
- or 280mm radiator (option)
Was £65.99 Inc. VAT
ORDER NOW
Corsair Graphite 380T Portable Mini ITX Case - Yellow (CC-9011065-WW) @ £89.99 inc VAT
The Graphite Series 380T packs a powerful punch in a portable Mini-ITX PC case. A built-in carrying handle makes transport a breeze. It’s easy to build the road-ready computer of your dreams within a spacious, easy to access interior with room for an extra-long graphics card. You can keep things cool with mounts for up to six fans and a convenient front panel three-speed fan controller.
The Graphite Series 380T Mini-ITX PC case doesn’t make any comprises inside or out. The sleek design derives from Corsair’s most-celebrated computer cases -- featuring eye-catching rounded corners as well as multiple color options. A built-in carrying handle lets you take it anywhere with ease.
Fine-tune air-cooling performance with the three-speed fan controller. Visible through the windowed side panels, the roomy and easy to access interior delivers major real estate for your next rig with space for a full-length graphics card, six fans, and four drives. Plug in your USB 3.0 devices and headset through the front panel. Now you’re ready to hit the road in style.
Features:
- Aesthetics that impress: sleek design, rounded corners, and easy to remove windowed side panels
- Built-in carrying handle makes it a portable powerhouse
- Included 140mm LED intake fan and 120mm exhaust fan
- Control freak? Customize cooling and noise level with the convenient three-speed fan controller
- Swap drives easily -- without tools -- in and out of the two 3.5¡¨ and two 2.5¡¨ drive bays
- Built-in internal lighting with to show off your system
- Easy connectivity with front panel USB 3.0, headphone, and microphone ports
- Maximum CPU Cooler Height -150mm
- Maximum GPU Length - 290mm
- Maximum PSU Length - 160mm
- Mounts for 5 Fans
- Front fan mounts: 1 x 200/140mm, 2 x 120mm
- Side fan mounts: 2 x 120mm
- Rear fan mounts: 1 x 120mm
Radiator compatibility:
- Front - 140mm or 120mm
- Bottom - 240mm
- Rear - 120mm
Was £117.95 Inc. VAT
ORDER NOW
BitFenix Comrade Midi-Tower - White @ £25.99 inc VAT
Aimed squarely at builders on a budget, Comrade delivers high-end features at an incredibly competitive price point. Available in two classic colors, Comrade brings a sleek, no-nonsense design that's ideal for the first-time builder. Dedicated 3.5" and 2.5" drive racks offer ample expansion possibilities, as well as room for long graphics cards up to 30cm in length. Tool-free drive locking mechanisms make installing storage a breeze, while dual dust filters enable quick and easy cleanup. A high-speed USB 3.0 port has also been included to save you time during file transfers. Adorned with premium touches like a powder-coated interior and an aluminum-finish BitFenix badge, Comrade is a trusty mid-tower design and an unprecedented value.
Choose Your AllySleek and streamlined, Comrade's design appeals to those looking for an attractive, no-nonsense housing that fits in any modern environment. Available in both midnight black and arctic white models, users can choose the one that suits their own personal style.
Enhanced ExpansionComrade delivers a surprisingly roomy interior that accommodates a multitude of hardware options. The dedicated 3.5" and 2.5" drive racks provide ample storage, all while allowing room for long graphics cards up to 30cm in length. Along with seven PCI slots and three 5.25" bays, Comrade makes a great base for a modern system.
Easy to BuildYour PC should be your friend – not your foe. Comrade comes with multiple friendly features that make the building process a snap. Features like tool-free HDD trays and ODD retention mechanisms make installing your storage virtual child's play. Motherboard standoffs have already been built directly onto the motherboard tray, and the simple pull-off front panel with independent I/O module saves you even more time during installation.
Superspeed USB 3.0 ConnectivityWith the proliferation of HD media, files are not getting any smaller. Comrade comes equipped with a high-speed USB 3.0 port, perfect for quickly transferring files from external hard drives, thumb drives, and more.
Specifications:
- Colour (Int/Ext): White/White
- Dimensions (WxHxD): 185mm x 428.55mm x 470.5mm
- Motherboard Sizes: Mini-ITX, Micro-ATX, ATX
- 5.25” Drive Bays: x 3
- 3.5” Drive Bays: x 3
- Drive Bays: x 3
- Cooling Front: 120mm x 2 (optional)
- Cooling Rear: 120mm x 1 (1 included)
- PCI Slots: 7
- 1 x USB3.0, 1 x USB2.0, HD Audio
- Extras: Front Dust Filter, PSU Dust Filter, Tool-Free Drive Locking
Was £29.99 Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
Lian Li PC-A55A Aluminium Midi Tower Case - Silver @ £59.99 inc VAT
The new PC-A55 is a great Midi Tower case with a great front mounting PSU deisgn to enhance space and airflow. This chassis offers the usual amazing quality that you always expect from Lian Li with it's brilliant brushed aluminium panels.
- Dimensions: (W) 188mm x (H) 375mm x (D) 455mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): 1
- 3.5" drive bay (External): None
- HDD bay: 3.5-Inch HDD x2 / 2.5-Inch HDD x2
- Motherboard: ATX
- System Fan (Front): None
- System Fan (Top): 140mm Fan x 1
- System Fan (Rear): None
- System Fan(bottom): 140mm Fan x 1
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / HD Audio
- Maximum Compatibility: VGA Card length: 310mm / PSU length: 160mm / CPU cooler height: 150mm
Was £69.99 Inc. VAT
ORDER NOW
BitFenix Shadow Tower Case - Midnight Black @ £44.99 inc VAT
Featuring an incredibly clean design, Shadow brings modern BitFenix styling to a surprisingly affordable
ATX form factor. The magnetic door, coated in BitFenix SofTouch Surface Treatment, is underlined with
a selectable LED accent that can be easily switched to red, blue, or even turned off from the top control
panel. A terrific base for the modern PC, Shadow easily accommodates long graphics cards up to 320mm
in length, and CPU tower coolers up to 165mm tall. The ample storage capacity enables up to seven 3.5"
HDDs to be installed, along with a single 2.5" SSD. Two Superspeed USB 3.0 ports facilitate quick file
transfers, and removable dust filters help keep the insides dust free. Equipped with DIY friendly features
such tool-free drive locking, cable management locations, and a powder coated all black interior,
Shadow delivers a trifecta of style, function, and value.
Features
- Selectable LED Accent - Choose red or blue light, or turn the lights off with the press of a button
- Sleek and Modern- Wonderfully clean and uncompromisingly stylish
- Enhanced Hardware Compatibility- Fits long graphics cards and tall CPU coolers
- Multiple Cooling Options- Fits up to four 120mm fans with two Spectre. fans included
- Ample Storage Capacity- Install up to seven 3.5" HDDs and one 2.5" SSD
- Removable Dust Filters- Filters in front, bottom, and PSU area keeps system dust-free
- SuperSpeed USB 3.0- Two ports included for blazing file transfers and fast mobile device charging
- BitFenix SofTouch Surface Treatment - Luxurious matte finish and soft feel
- Trouble]free Installation - Large CPU cooler cutout, cable management, tool-free drive locking
Specifications
- Materials Steel: Plastic
- Colours (Int/Ext): Black/Black
- Dimensions: (WxHxD) 190 x 440 x 506mm
- Motherboard Sizes: ATX, Micro ATX, Mini]ITX
- 5.25" Drive Bays: x 3
- 2.5" Drive Bays: x 1
- Cooling Front 120mm: x 2 (1 included)
- Cooling Bottom 120mm: x 1 (optional)
- Cooling Rear 120mm: x 1 (included) or 92mm x 1 (optional) or 80mm x 1 (optional)
- PCI Slots: x 7
- I/O: USB 3.0 x 2, USB 2.0 x 2, HD Audio
- Extras: SofTouch. Surface Treatment, selectable red/blue LEDs, removable dust filters, tool-free drive locking mechanisms
Was £54.95 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - White @ £139.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage: Full Range - 100V~240V
- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
- Output: +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection: OVP/OCP/OPP/SCP/UVP
- Dimension: 200mm(L) x 150mm(W) x 86mm(H)
Connectors
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was £156.95 Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
BitFenix Pandora Micro-ATX Case w/ Icon Programmable Display - Silver @ £74.99 inc VAT
Pandora represents the next level of BitFenix chassis design. The soft curved design is surrounded by luxuriously brushed aluminium side panels that give the entire case a timelessly elegant look that melds perfectly with any modern décor. On the front of the case is another innovation dubbed BitFenix ICON™ - a programmable display that can be customized with a simple drag and drop interface, making it simple to personalize the look of your case whenever inspiration strikes. Despite its slim 160mm width, Pandora can accommodate high octane hardware, such as 240mm water cooling radiators, and expansion cards up to 350mm in length. Users are able to house up to two 3.5" HDDs or three 2.5" SSDs, and to keep all of this hardware running cool, a direct airflow design along with smart cable management features help ensure everything runs frosty. Friendly features like pre-installed standoffs and pop off screwless side panels help get your system up and running quickly, while magnetic dust filters allow for easy clean up.
Specifications:-
- Material: Aluminum, Steel, Plastic
- Dimensions: 160 x 420 x 465
- Form Factor: Micro ATX, Mini-ITX
- LCD: 2.4" TFT, 240 x 320
- 3.5" Driver Bays: 2
- 2.5" Driver Bays: 3
- Cooling top: 120mm x 1 (included)
- Cooling Front: 120mm x 2 (1 included)
- PCI Expansion slots: 5
- Front Panel: USB 3.0 x 2, HD Audio
- Power Supply Support: ATX, up to 180mm in length
- USB 3.0 x 2, HD Audio
Was £89.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
BitFenix Colossus M Micro ATX - Black @ £58.99 inc VAT
Colossus Micro-ATX adds Micro-ATX motherboard compatibility, which means added expansion possibilities including dual graphics setups such as SLI or Crossfire. The included bottom fan can be easily replaced with up to two 3.5" hard drives, and with the included removable hard drive rack, an additional two 3.5" HDDs or three 2.5" SSDs can be installed for excellent flexibility. Included magnetic heat shield prevents warm exhaust from the PSU from re-entering the case, and also looks great with its uniquely micro-textured surface. Users can also opt to install a single graphics card and a slim 240mm water cooling radiator at the same time. Users who require added PCI-express expansion are going to love Colossus Micro-ATX.
Features:-
- Futuristic Form – Bold lines with a compact design
- LiteTrak™ Technology – Smooth multimode lighting with three colours and an included pulse mode
- Maximum Storage Potential – Five 3.5" HDDs or eight 2.5" SSD locations available
- Friendly Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
Specification:-
- Extras: LiteTrak™ lighting system, SofTouch™ surface treatment, magnetic heat shield
- PCI Slots: x 5
Drives:-
- 5.25" Drive Bays: x 1
- 3.5" Drive Bays: x 4
- 2.5" Drive Bays: x 3
Cooling:-
- Top: 120mm x 2 (optional)
- Bottom: 120mm x 2 (1 included) or 200mm x 1(optional) or 230mm x 1 (optional)
- Rear: 120mm x 1 (included) or 140mm x 1 (optional)
I/O:-
Was £64.99 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv Micro ATX Case - Black @ £79.99 inc VAT
Enthoo EVOLV, an mATX/mITX chassis, sports a beautiful all aluminum exterior. The EVOLV’s unparalleled design features an all new tool free release system for the outer panels. The EVOLV supports many high end PC components while maintaining a minimalist design.
Functionalities:-
- 1x Drop-N-Lock SSD brackets included
- Multifunctional Side Bracket - (mounting for 2x SSD’s / 1x HDD)
- Removable HDD cage for installation of long PSU’s (>180mm) / waterpump
- Equiped with removable dustfilters (1x front, 1x bottom, top integrated)
- Phanteks’ PWM hub included
- Clean cable management
- Phanteks’ pre-installed Hoop-N-Loop cable ties
- Quick release panels for easy acces to fans and dustfilters
- Toolless sidepanel with swing door
Aircooling:-
- Optimal airflow - Direct airflow to CPU / GPU
- Comes with 2 Phanteks premium fans 1x PH-F200SP in front (200mm) 1x PH-F140SP in rear (140mm)
Watercooling:-
- 3 different installation areas for single or dual radiators (120mm and 140mm form factor).
- Reservoir mounting points on the Side Bracket
- Pump Bracket with vibration dampers - Mounted on Side Bracket/ HDD base
Specifications:-
- Dimension 230 mm x 450 mm x 400 mm (W x H x D)
- Form Factor Micro tower
- Material(s) Aluminum exterior, Steel chassis
- Motherboard support uATX, mITX
- I/O (side) 2x USB 3.0, Mic, Headphone
- Side window Yes
- Expansion slots 4
- External 5.25” 1 (modular)
- Internal 3.5” 3
- Internal 2.5” 5 (1 slot for upgrade)
Clearance:-
- Graphic card 318 mm
- CPU cooler 192 mm
- PSU 216 mm
- (remove Midplate cover for PSU longer than 180mm)
- Cable management 24 mm (216 mm below midplate)
- Radiator (TOP) 68 mm to motherboard (offset)
Was £89.99 Inc. VAT
ORDER NOW
Antec P380 Performance Series Windowed Tower Case - Black/Gun Metal @ £119.99 inc VAT
FULL SPEC HERE
Was £133.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Lian Li PC-Q08B USB3.0 Mini-ITX Case - Black @ £64.99 inc VAT
Mini-Q PC-Q08 is made in Taiwan, with the highest quality aluminum alloy panel. The Mini-Q PC-Q08 carries the standard of Lian Li’s quality requirement, all the sharp edges had been removed to protect user’s hand. The chassis is made of 1.5mm aluminum alloy panel to ensure product’s durability and all external parts are hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The clean shape of Mini-Q PC-Q08 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q08 is to be as simple as possible, the exterior of the case is also the structure of the chassis. To ensure you can put everything together easily, Lian Li design team decided to use only standard PC component inside the Mini-Q PC-O08, standard Mini-ITX motherboard, standard 5.25” optical drive, standard 3.5” hard drives, standard ATX PS/2 power supply units and standard graphics card.
- Dimensions: (W) 227mm x (H) 272mm x (D) 345mm
- 3.5" drive bay (Internal): 6
- Expansion Slot: 2
- Motherboard: Mini-ITX / Mini-DTX
- System Fan (Front): Black, Silver / 140mm Blue LED Fan x 1
- System Fan (Top): Black, Silver / 120mm Fan x 1
- I/O Ports: USB3.0 x 2 / HD Audio
- Maximum Video Card Size: 300mm
Was £84.95 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
BitFenix Prodigy M MATX Cube Case - Red @ £49.99 inc VAT
Sleek and Compact
Specifications
- Colors (Int/Ext): Red/Black
- PCI Slots: x 5
Was £64.99 Inc. VAT
ORDER NOW
Cougar MG100 Micro-ATX Gaming Case - Black @ £22.99 inc VAT
The Cougar MG100 Micro-ATX Case is a compact and professional looking gaming case. With a hair-line brushed aluminium effect front panel, black interior, 330mm VGA card support and USB3 as standard, the MG100 offers the perfect solution for anyone looking for a Micro-ATX gaming case on a budget.
Features
- Sleek cutting-edge with special hair-line surface front panel design
- Mini tower with superior capacity for longer high-end graphics cards up to 330mm
- High quality full black coating
- Advanced USB3.0 ports for maximum data transfer speed and high current smart phone and tablet charging
- Support for 4 fans: Front 80/90/120mm fan x 1, Rear 80/120mm fan x 1, Side 120mm fans x 2, Rear 120mm fan x 1 is pre-installed
- Screw-less design for 5.25" & HDD devices
- Support installing 2.5" HDD/SSD at bottom cover
Specifications
- Case Type: Mini Tower
- Motherboard Type: Micro ATX
- Dimension(WxHxD): 7.09x14.57x16.54( inch ), 180x370x420( mm )
- External 5.25" Drive Bays: 2
- External 3.5" Drive Bay: 1
- Internal 3.5" Drive Bays: 2
- Internal 2.5" Drive Bay: 1 (at bottom cover)
- I/O Panel: USB3.0 x1 & USB2.0 x1, Mic x1, Audio x1
- Cooling System: Front 80/90/120mm Fan x1pcs (optional), Rear 80/120mm Fan x1pcs (optional), Left Side 120mm Fans x2pcs (optional)
- COUGAR 120mm Fan (rear): 1 (pre-install)
- Expansion Slots: 4
- Maximum Graphics Card Length: 330mm
- Power Supply: Standard ATX PS2 (optional)
Was £27.95 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Deal requests taken on Cases/PSU's/Gaming Chairs
