NZXT Kraken in a ANTEC 1200?
I have used an H80 in an antec 1200 - tight fit at the back but doable. Fits easily if you remove one of the existing 120mm exhaust fans.
Looking at spending £50 max on an AIO can get an X41 for £40, Is it worth it/can i fit?
For what its worth looking at specs on the Antec 1200 its 120mm so you would be better suited to the Kraken X31. That said there is a 200mm fan up top so if they provide other mounts the X41 would work.
Personally I would not risk a X41 unless you know for sure it fits! :cool:
