- 5 Sep 2011
- Surrey
That video sounds like the pump, not coilwhine. And I hope that's an extreme case as that sounds clapped out. I have two D5s in my build and they aren't even a 1/4 as loud.
The Rainforest?![]()
Yup thats the issue, AMD have stated they worked with coolermaster so this isn't an issue with retail cards. Apparently the "initial batch" also included retail cards considering there's a good few of them showing up sounding like this. Yet ocuk are saying you cant send it back for this despite the fact amd stated it was an issue that shouldn't exist in the retail product? How does that work?
How much do you reckon this would cost?
Might get one with LambChop printed on it as he said his name would never be seen with an AMD product![]()
This RMA BS is one of the main reasons I try to buy as much as possible from a certain competitor, they will let you RMA pretty much anything within 30 days for a full refund for literally any reason as long as you haven't damaged it and still have the original box.
haven't you got 14 days to send an item back anyway as part of some sort of consumer act?
If that's the case then just return it as not wanted.
lol Can't be too few if this many people are reporting the issue. There weren't many available in the first place.
XFX here - the noise is......
pretty much silent
a slight pump purring
case is open and the card is around 2ft from my head.
http://www.overclock.net/t/1547314/...nano-x-x2-fiji-owners-club/1720#post_24106947Neon Lights: I also had the memory bug.
In the "Furry and Tessy" Test (1920x1080, 4xMSAA) in MSI Kombustor 2.5.0 600MHz memory clock (and standard core clock) gives me 57FPS instead of 49FPS.
People have just been whipped up into a frenzy and think because they can hear the faintest whisper with their ear up to the card they have a duff unit.
It's a phenomenon we've seen before, should probably give it a name by now.![]()
Am just going to buy one. All you guys on here reporting it to be running fine. Maybe it's just couple early batches that maybe shouldn't been sold?
