Stick with your 980Ti. If you have a good clocker there's not much in it power wise. And you'd just be opening yourself up to SLI issues.
780ti SLI owner here, which are 'basically' 3gb Titan blacks. I'm pondering swapping to one 980ti.
Do itStick with your 980Ti. If you have a good clocker there's not much in it power wise. And you'd just be opening yourself up to SLI issues.
780ti SLI owner here, which are 'basically' 3gb Titan blacks. They are brilliant and powerful but occasional SLI issues, and stutter with gsync in some games frustrates me. I'm pondering swapping to one 980ti.
Yeah. People who say they've never had stutter must have some portion of their brain missing, or are just not receptive to it. For me its THE worst most distracting thing in any game.
Not saying SLI is terrible, far from it. When it works I love it! And Most games are fine, it's just when there are problems its very annoying.
Some 'stutter' is also so minor you probably think it's fine and wouldn't call it stutter. Until you play with one card only. Far cry 3 is the best example for me. In SLI you load it up and think, hey this is ok, it's running well. But play on one card only and it so smooth in comparison. It's subtle, but a massive difference to me.
I don't have any portion of my brain missing so ill go with the latter
Unless you don't have a big resolution and don't need to play games at max then we haven't got much choice in having more than one card
Titan blacks were the first time I went sli, and I honestly don't remember noticing and difference except for the huge fps increase.
The extra VRAM can help with stutter in some scenarios so that may be helping you.
Hey not having a pop at you/ your brain fellaIt's just a turn of phrase
I think I'm doomed to keep going SLI anyway. If I swap to one 980Ti, I will go 4k sooner than later, and then get another 980Ti. I know it will happen already.
Not to mention Maxwell has better GSYNC support.
