Help - trouble overclocking drain cover!
Caporegime
13 Jan 2003
Dear GD,
I has problems, overclockin' mah drain - not sure if it's a flow rate issue but the cover's getting too hot!
Hailp!
Hmm - abject failure.. british summer isn't hot enough.. but tomorrow is even hotter .... hmmm a challenge!
Looks like it's almost on the verge of going for it.. (the slightly cloudy appearance). Recommend non-chilled egg.
OP, do you have a job?
Lol made redundant Nov. Currently waisting my own money (no sign on) in getting a new job.. had 3 interviews in the last two weeks, all feedback is positive, got second round F2F interview tomorrow. Job applications today...
I wonder what temp the car is..
What a waste of an egg. I would definitely smite you if I witnessed this.
Your cover has karked it, I'm afraid. I'd normally advise a simple reinstall, but that version of Manhole is no longer supported and wasn't intended to be compatible with your existing hardwear anyway.
I suggest you replace it with a Gatic F900.
Judging by the size of the cover on my monitor, a pringles tin cover should do. Sorted.
Good luck :)
Speaking as a certified sewerage technician, the heat transfer of the Pringles tin is grossly insufficient and would result in severe degredation, which presents a further risk from a health & safety perspective... never mind the idea of eating an egg cooked on such a rusted surface! :eek:
