- 14 Jul 2005
- Bristol
My car currently had a wing mounted AM/FM aerial which has (prior to my ownership) been snapped off just above the base meaning I don't really get a good signal.
I have a head unit with DAB coming and whilst that isn't the reason I'm buying the unit I figure I should address my aerial situation and fit one that allows me to use all of the HU's features.
Ideally I want to remove the wing mount entirely and have an internally mounted aerial but want some opinions on the available ones, mostly glass mounted ones.
There are loads of glass mounted options varying from £20 to £100 or so but I'm wondering if they can also be mounted to metal? My thinking is that I can mount of them them behind the headlining on the roof skin so that it's out of sight but I've not been able to find anything on google if this will work or not. Anyone know if there would be issues mounting one to metal, I mean they just stick to the glass normally?
Alternatively, anyone know of a half decent but not silly priced wing mount AM/FM & DAB one? I've seen some at £80+ which seems excessive given there isn't a great DAB take up in the UK.
And as a lazy option, anyone know what's a half decent AM/FM wing mounted one?
) Am/Fm & DAB aerial for £40 on the famous auction site.
