Sorry if this is in the wrong place. Please do remove it, if it is!
I need some advice/help, am looking for extra fan screws for the Raijintek Triton Core Edition AIO Water Cooling Solution.
So I can add the pull fans, however it uses M3x30mm Fan screw X 8. However I am unsure what screw thread type to get and where from really. I seen the ones on OCUK ( link here ) but not sure if they are just the same. As I do not really want to bugger up the rad threads on it self by using the wrong ones or going into the radiator fins. Install guide here, if any one else wants to check. http://www.raijintek.com/images/InstallationGuide-Triton-v2.pdf
