TV stopped working, Thunderstorm!!!
14 Dec 2008
UK
Hi,
Woke up this morning after that thunderstorm to find my Sony kdlw905 standby light flashing 3 times then a 2 second pause.
I had a surge protector fitted and other appliances fitted are still working.. anyone knows what's happened?
Have you tried Google? Quick Sony kdlw flashing red light brought up some info.
Yeah, it seems to be mainboard, or DC alert!
Crazy though as sony tv's seems to go down easy in thunderstorm from what I can see on a quick google search.
Surge protectors have done nothing to save my tv :mad:
Could try Sony direct, if its completely gone out of warranty perhaps ask them for a repair cost could get lucky.....
ebay/amazon are usual places to find mainboards I typed in Sony kdlw905 board and some entries popped up but it sounds like you would need to know the exact part number.
Perhaps a complete long shot ? if your surge protector check the site I recall belkin and other brands having a up to £10,000 claim if products still go bad due to surge and spikes.
I have had a similar thing accept no thunder just backlight died, next tv will be from richer sounds or john lewis and with a 5 year warranty!
Surge protectors will do very little for direct strikes - they handle (especially with the uprated mains systems these days) downstream strikes fine but if it gets in locally they are far from any guarantee. Also the guarantee covering equipment that comes with them often doesn't cover (direct) lightning.
Colleague at work (who lives in Dorset) had similar happen - TV dead almost everything else still working except for the router and TV.
Think im going to try and replace psu board myself.. Seen one for £30 costs around that for a local repair specialist just to take a look... If its not the power supply board then according to codes its the main board...
Oh what fun the next week will be...
So many have damage even when spending money on obscenely profitable protectors. Fixing your Sony and averting future damage starts by understanding why damage happened - the electrical path.
Lightning seeks earth ground. To be damaged, a Sony must have both an incoming and a completely different outgoing path to earth. A direct lightning strike to AC mains far down the street is incoming to every househould appliance. So all are damaged? Of course not. Damage is an appliance that also makes a best, outgoing path. Inoming on AC mains. Outgoing maybe via its coax connection or HDMI port.
The naive assume damage means that was an incoming path. More often, the outgoing path is damaged. Those connections are often a best outgoing path because a TV cable already (should) has effective protection - a low impedance connection to earth.
Surge passed through everything between an incoming and outgoing path. But only the weakest part in that path fails. It is the only way to estimate what is damaged.
Plug-in (adjacent protectors) simply give a surge even more incoming paths into the TV. No adjacent protector claims to protect from the other and destructive surge. If you did not have 'whole house' protection, then the Sony (and all other household appliances) were and are at risk.
Damage is defined by how a surge connected to earth - the destructive electrical path. Protection is also about how a surge connects to earth WITHOUT entering a building. Two problems to solve: current damage and to avert future damage. That magic box protector did exactly what manufacturer specifications said it would do. And may have made damage easier.
