5930k temp check?
25 Jun 2015
Using a 5930k with H100i cooling.
Got an overclock of 4.4 idle around 42-45c max load 80-85c just checking is 85c too hot? Its mainly on the core 2 that one seems to run abit hotter than the others.
when the cpu is under full load running prime or xtu 85c is ok. if its getting that hot in games then it isn't so good.
Thanks for all the help, managed to sort it. It was my fault I had messed with the noise/fan settings in Corsair Link too much and the case fan settings. After some adjustments at max it reaches 70c - 75c when room temp is hot, like it is at the moment with this hot weather.
85C is way too hot, that sort of temp is doing stress testing when using a high overclock and volts on a less than adequate cooler.
Case and point my i5 2500k was doing 4.7ghz and it never went over 72C in games, and that wasn't even liquid cooling
