Caporegime
- 18 Oct 2002
Was funny once, boring twice, and getting annoying after that...![]()
Okok I'll stop being an arse
Okok I'll stop being an arse![]()
If after voltage unlock it does not overclock well, then it will be well deserved. Hate all that lying crap.
Agreed! Although I personally think the guy just blurted it out without any real solid info (except the cooler being great) and now everyone has taken it to heart...
It's obvious that they're running it near to the ragged edge as it is!
I don't think with voltage being able to be applied we will be seeing big overclocks. With stock voltage mine isn't very good but I do hope I am wrong.
Fiji’s ROP performance is getting turbocharged for two major reasons. The first is GCN 1.2’s delta color compression, which significantly reduces the amount of memory bandwidth the ROPs consume. Since the ROPs are always memory bandwidth bottlenecked – and this was even more true on Hawaii as the ROP/bandwidth ratio fell relative to Tahiti – anything that reduces memory bandwidth needs can boost performance.
At this point R9 Fury X’s ROPs are pushing more than 40 billion pixels per second, a better than 2x improvement over the R9 290X despite the identical ROP count, and an important reminder of the potential impact of the combination of compression and HBM’s very high memory bandwidth. AMD’s ROPs are reaching efficiency levels simply not attainable before.
Very interesting how OCing the mem makes the diff this time, is there any word on a GPU-Z update to read it properly?
I do wish people would leave Furmark alone. It isn't good to use.
Agreed, I think now that clock throttling is baked into to new cards it means Furmark does not represent a true max TDP anyway.
So it has become a pointless potentially risky test for temps etc.
A long run of Heaven Valley can provide a good indication of temps. Would recommend that over Furmark.
Dirt Rally Fury X Vs Titan X (prefer max quality set in the NCP) 1080P bench.
My point bringing furmark in discussion was a test where they used oc'ed (power limit 50% increase) and stock fury x. They both consumed same amount of wats. So my real point here is: Is increasing power limit from ccc actually even working atm? So that might be limiting fury's performance when you try to overclock it.
