Hi everyone,
I just wanted to check if this was a sensible setup for what is required for basic photo editing using Photoshop Elements for my dad? I haven't built a PC in over 5years and frankly CBA - the extra cost in getting in built elsewhere + warranty is worth it in my book. He has a track record of buying duds from supermarkets or PC world so I want this to be the last he requires and I can manage internal upgrades as he needs them.
Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail
Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard
8GB Kingston DDR3 1600MHz
1GB NVIDIA GEFORCE GT 720 - cut from GTX 750 for a £50 saving
1TB HDD - overkill but only £3 less for 500GB
Corsair 450W VS PSU
Basic DVD - could save £15 if an old one I dig out works..
CPU cooler - £19, figured this could help longevity.
COOLERMASTER ELITE 311 BLUE CASE - £35
Total is £512 currently but as above can cut some corners or beef it up slightly to help with longevity. Was tempted to go for 16GB RAM but I don't think he'd require it with his use and I'm confident I can pickup another stick cheap down the line. Any glaring faults or smart improvements to be made? No perhipherals required, i'll try and use my hand-me-downs
thank you!
Corsair 450W VS PSU
thank you!
) , Dx0 and Lightroom CC, there are occasions that the more cores the better. (i.e processing noise reduction using Prime on a RAW file)
