- 14 Jun 2004
- Newcastle U/T
[TW]Fox;28271642 said:My girlfriend had a Corsa which was replaced with a Mini a few years ago.
Ah that makes more sense
Yuk no. Avoid.
As has been said focus is a good bet. It's a bit bigger. More reliable. Cheap to fix if it does go wrong. Good range of engines. Good range of equipment.
Obviously it's down to what you like at the end of the day but keep in mind things like the focus and golf are very common for a reason. They're good.
They are very common, which is why theres a lot more claims for them and from what I'm lead to believe this could lead to higher premiums.
At the end of the day it's a number theyve pulled out of thin air
