MSI AB or Trixx
6 Jan 2013
Yorkshire
Hello, just a quick question, does anyone know if theres a way of getting the OSD monitoring and keybound profiles from AB, and the overclocks from Trixx?
In trixx i can get much higher overclocks because it seems to allow higher settings for volts and clock settings, but i love using the AB profiles and OSD to monitor everything.
Cheers.
I like AB myself, you can unlock voltage etc in the settings. :)
Yeah, if i could unlock the voltage and settings on these cards i would definately use AB, but unfortunately it doesnt go high enough. Im guessing i would have to edit the bios to set higher limits, as i assume AB is taking its max settings from there. Trixx just seems to give you unlimited max overclock settings, as you raise hte bar higher it also raises the limit along side it.
