Done all but two and I've only sunk 100 odd hours in. Need to do Skolas and Crucible matches and I'm golden.
To be fair even if it was 2 days, you can get through both VoG and CE in a couple of hours. Skolas on the other hand is more difficult.
Golden chests are easy but skolasman that is going to a challenge to get.
Skolas this week can be done in about an hour and a half, on the boss try using thorn as small arms is on and thorn rips through the captains shields, its just a case of getting the route and damage right
its really not
Skolas is much easier since the change. You just play the encounter properly, work as a team, and don't try and rush it.
You damage him, clear the adds that spawn, go back to damaging him, clear the adds, and repeat until he's dead.
Only complication is negotiating the mines and taint while you do it. But it just needs a bit of team work.
1 hour 39 mins it took us last night from beginning to end of the entire Prison of Elders encounter (not just Skolas)
Ok so is the "triumphs" emblem different to the VIP one?
Only missing Skolas so I suppose I will have to do that in the next couple of months.
