yeah your right but it just seems a lot of hassle tbh
@dowie ill have to look into it,the electric isn't too bad tbh but the gas in winter eats it up
I still feel more should be done for prepay customers
If you angle for a SMART meter with a separate LCD display you can plonk it in your home office or lounge it will show you your cost per day/hour etc. All you need to do is enter the prices.
Unfortunately the options are there but it depends on what you consider your time is worth. If you value your time more than the cheaper prices then there isn't much to say.
I don't mean to sound harsh but i hope you can see where I'm coming from.
