Radeon 295x2 Issues
OP
11 May 2010
Yeah I tried that and it didn't make a difference.
Uhhm well I got the 295x2 for £400 so something around that area I guess, which puts me out of 980ti prices I know. I might have to just wait a bit.
12 Mar 2005
Kings Norton, Birmingham
I'm not sure about your case but mine (haf x) came with a gpu support bracket (currently holding 2 of 3 7950's). Those ards are huge and as you tried previously, supporting it did help. Personally I'd send the card back as sloshing and gurgling in a closed loop means there's air trapped.
Good luck and hope you get it sorted.
SP
19 Jul 2011
Reading
Send it back , there is probably a hair line crack/ broken solder joint in the pci-e connector or board. propping it up will only be a solution to the symptom and eventually it will die.
I imagine it was probably on a test bench when it was checked before going into B-grade stock which is why the issue wasn't spotted.
OP
11 May 2010
Nearly bought that very card,glad I didn't this time. Nothing like a fault finding
mission.
It was probably the worst 5 days of my life lol. I spent all day every day reinstalling windows or AMD drivers. I was in denial for most of that time. I didn't want to accept that it was broken :(
I have no idea if its fixable. I've been looking on the b-grade section to see if they re-list it but it hasn't gone up yet so it must have failed for them too during testing.
14 Apr 2009
Cheshire
Shame to suffer such difficulties. I wonder if ocuk knew of the issue of return and tested it.
I don't mind getting stuff that doesn't work in principle. But when you spend.so much of your own time it becomes expensive.
27 Sep 2013
Reinstalling a system and trying all ideas is a big stress. My lady puts her head in her hands when i buy something she worries it will go wrong.
