I've spoken to three people today and they are all seeing the same thing.
It cant be a temp issue as I am custom water and my temps are below 40c. I just find it strange that as soon as the gpu hits any sort of load the voltage limit flags up with a 1 on Afterburner? At first I was wondering if it was only my card but it seems not. If anyone else could check Afterbuner or shed some light on this that would be great.![]()
Yeah that is odd do you have a full cover block? Could still be a vrm temp issue if you dont. Voltage regulators getting too hot would reduce their performance and to maintain good function i could see the card dropping voltage to keep the vrms happy.
What is your voltage at ful load? Mines 1205mv. Bios allows for max 1250mv but i never see it applied to the card even using kboost on precision. Another theory i have is 1250mv is max for a crappy chip but good chips that require low voltage to hit stock speeds then cant hit the max because that would be adding more than 87mv. We might be seeing a lower max voltage because our starting voltage is lower. Just a thought anyway not sure all gpus have the same starting voltage.
Could still be afterburner bug. Post on guru3d unwinder might answer.
Afterburner is slightly out on power limit. If you set 110% the power graph never shows 110%.
Suspect this is just measuring error.
