I originally had the XSPC Raystorm EX280 kit I put in my PC, this was done for my first watercool build last year and at the time did not consider putting a valve on to drain the coolant. Well long story short after a few months I decided to sell it and go back to air, maybe in another year or so I will invest more time and money and do a proper custom watercool build.
The air cooler I have like most is covering the first ram slot (which in turn made me sell two sticks of ram pretty much at the same time I sold the EX280). As I decided to go for a AIO liquid cooler now I thought I may aswell fill the two empty ram slots.
Anyway, which AIO liquid cooler can any of you folks recommend? My tower is the Corsair 750D and it will be to cool my i7-4770K so like before, one with two 140mm fans to sit at the top will work well.
Looking at OCUK the usual names spring up, like:
Corsair Hydro H110 280mm High Performance Liquid CPU Cooler
Corsair Hydro H110i GT 280mm Extreme Performance Liquid CPU Cooler
Corsair Hydro Series H110i GTX High Performance 280mm Liquid CPU Cooler
Of course there are probably more, those are just the first few that popped up on the website.
For style wise, I would prefer whichever cooler I go for to be able to change to colour of the center logo on the actual cooler bit.
Cheers
Cheers
