7870 dead. Best band per buck for £200
24 Nov 2006
Altrincham
Hey guys
While playing WoW last night it appears my 7870 died. Each time I tried to reboot I would get past the bios and then my pc would green screen and then nothing until I used the power button to shutdown.
What would be the best card at the moment to replace it with and should I go AMD again?? The budget isn't set in stone but couldn't afford to go much higher.
regards
Gen
380 is the best card for that price new, they are about £175. You MIGHT be able to get a EOL R9 290 for that (I nabbed one on ebay for £191 earlier today), but you would have to be lucky. 780Ti maybe, good luck finding one, 970/R9 390 new for around £250.
Really don't want to take the risk with a B Grade item ( the 1440p thread above hasn't eased my worries either).
I'm getting on a bit in life and have a family....spending £200 on a graphics card is selfish enough so I want as small a risk as possible with it.
Of the 380s, is there any that stand out as being a killer deal?
Regards
Gen
I bought one of the B-Grade KFA2 GTX960 cards which was delivered yesterday and within a few hours it died. They had 10x in stock too.I would just buy a new card TBH.
What PSU do you have?
Regards
Gen
Not sure sorry mate, I know the Sapphire Nitro cooler on the 390 is amazing, but the 380 looks like it has a cut down version, same with most of the other coolers, maybe the MSI card? check some reviews I guess.
Yeah I saw the Asus card but the reviews put me off a bit.
What increase in performance would I get over my old MSI 7870?
It will double the performance, its more than twice the GPU.
7870 1280 Shaders
290X 2816 Shaders
7870 32 ROP's
290X 64 ROP's
7870 256Bit
290X 512Bit.
If you look around google today for the 290x vapor x it can be found for £215 new on a special.
that https://www.overclockers.co.uk/showproduct.php?prodid=GX-289-MS&groupid=701&catid=56&subcat=3059
Core: 1060MHz, Memory: 8192MB 6100MHz GDDR5, Stream Processors: 2560, DirectX 12 Support, AMD CrossFireX Ready, AMD Eyefinity, AMD Mantle, Dolby TrueHD, GCN, 3 Year Warranty.
is a very good buy looked at price comparing sites and that offer from OC is very good, even though my mate calls OC "overcharges" lol
Price at £259.99 inc VAT
