When does the In Win 805 release?
A question about this case, does anyone know if you have to use the HDD cages to mount 2x SSD drives? Since the HDD cage would restrict using a front radiator and bottom fans.
There is also a space for a 2.5" on top of the HDD cage. The HDD cage won't restrict the front rad, but it seems like it will prevent the use of fans at the bottom. Looking at the back of the motherboard tray, I think you can mount x2 SSD's there... it doesn't say explicity on the website, but you can see it has 2 shaped cut-outs that are identical to ones on the 909, and I saw from another video that these are SSD mounts. So I'm quite sure even if you remove the HDD cage, you could still mount x2 SSD's back there. Regardless, you can pretty much mount SSD's anywhere, no need to put them in cages or designated mounting points if you don't want to.
Yeah, I think it'll be fine. A good AIO with high SP fans will do the job nicely I am sure. If no AIO on GPU, a rear exhausting would be fine also, but even that's not essential. It's not a case for those obsessed with low temps though. Hopefully it should be fairly quiet with those glass panels... never had a case with those before, so I don't know how much better they are at sound proofing vs traditional steel.
First look at Inwin 805. Only thing is this is a Australian video. AU version will be different then the rest of the world it seems? Case looks good, but worried about hiding PSU cables?
I think it will require some careful, well planned and time consuming cable management for the best looking build. Perhaps an investment in a CableMod set would be prudent if tidyness is a priority.
I have Superflower 1000watt. They don't do cable for them yet :(
I hear you can barely see inside the case. maybe well placed LED lights will light up mobo , but leave bottom area dark. That's what I'm going to do at least.
