Hello all, currently building my second build a HTPC build which is evolving of sorts into a gaming machine. I have couple of parts already such as the case, z97 mini-ITX board and Bitspower Full cover block for said motherboard (so it will also cover the PCH and capacitors which may add some more heat like so: http://www.overclock3d.net/gfx/articles/2014/10/27133015122l.jpg) so will be going down the custom cooling route.
My limitation is the case only has support for a single 240 mm radiator up to 60mm thickness including fans (so basically 40 mm)
Just pondering what GPU options I have available to me that will along with the CPU be okay on a 240 mm radiator. The two GPU's I am currently looking at is the Fury X and GTX 970 which may sounds like drastically different options but are both cards available on small PCB's (unless there are any others out there?). Would the Fury X which seems to run quiet warm be okay with a CPU on the 240mm loop?
Thanks in advance
Thanks in advance
