EK Naked Ivy i5 3570k temp 16c between core ?
19 Jan 2011
So my temp has dropped from 98c to 73c but some cores are 16c hotter !
Do i need to remount? as its stupid hard due to my micro atx loop:(
Was it working ok before or is this new? What RAD size do you have? What fans?
What are the temps like for the GPU?
I had the same problem with a friends 4790k naked mount , re pasted a few times and still the same issues. Put the lid back on with some Clu and problem solved. Naked die cooling especially without a shim is just a pain and not worth it imho.
Rad is a 240 ek ex + vadar
Gpu 980ti gets to 1480 on boost playing pCars gets to about 41c
about 2 hours of pCars cpu is 50 56 59 58
edit: yer was working before with on just air but temps were 92 93 99 98 and 85 on gpu.
I see, yes its a pain I did get the ivy cpu standoffs from ek. If it was only like 6-8c on ITB i feel ok but 16c seems a bit much ??, but 10c between hottest and coldest on prime95 and my games do you think that's livable,
I really should have made a drain port.:rolleyes:
Well it was a faff but i remounted it.
57 65 73 70 --> 55 63 65 64 so thats down even more 2c 2c 9c 6c
So worth doing.
