What sort of air compressor do I need to dust my PC? Would a cake/nails decoration one work?
29 Sep 2013
London
Hi guys,
So I'm pretty fed up with decades of dusting the inside of my PC. Cans of compressed air are expensive in the long run, but the air compressors I've seen for sale are crazy expensive, all above £60!!!
I've been checking ebay and there are some cheap items also called "air compressors", which can be used on nails and cake decoration. Would one of these be good enough for a PC? I mean, it would go down great with the missus if this is a gift for her and her cakes (she loves to bake cakes!), and which I can borrow every now and again for dusting.
Here's an example:
http://www.ebay.co.uk/itm/Air-Brush...t-for-Cake-Nail-Art-Make-Up-Set-/311397603613
But let's be honest here, will a thing like this have enough air pressure to be suited for a PC Master Race? A guy has standards you know. :D
Your experience is most welcome.
You sneaky git. :D:p:D One way of getting something past the wife I suppose.
I believe that would work fine. It says delivery of 15-50psi so that would be more than enough to blow dust out of a pc. I would buy some dust filters to stop the dust getting in there in the first place though.
:D
Where can I buy those dust filters? Where do I put them?
Thank you for your input, I have no idea if 50 psi is good enough, so thanks for clarifying that!
:D
Dust filters are available here:
https://www.overclockers.co.uk/productlist.php?groupid=701&catid=2331&subid=795
If you are using dust filters, I'd advise that you ensure your fans have a higher static pressure so the temperature inside your case doesn't get too high, as the filters will obviously restrict air flow. But 1-2c more will probably be tolerable.
Paddling pool pump works great i will try find a link to one i use. Buying cans of air is just stupid go to argos and search high performance electric air pump
I wouldnt buy the ebay pump as its not as good
For £5 more, the Datavac Electric Duster looks much more powerful. But I still wouldn't be able to justify spending £85 on it.
It'll take you forever to dust your case with the airbrush. You can get an 'air duster' attachment (It's actually what I use paired with my model paint air compressor). However I doubt very much you'll get a high enough PSI/steady enough output from that tiny compressor. Mine just about does the job but mine has a 3L tank built in so pressure is constant.
It'll work but won't be as effective as you'd like.
Datavac is a good choice or a shop compressor (Which normally cost around £100).
What a waste of money the air bed pump works a treat.
http://www.ebay.co.uk/itm/Mains-Elec...item2a4d16adc2
You say **Mine just about does the job but mine has a 3L tank built in so pressure is constant.**
If thats the case what a waste of money indeed, the air pressure is constant on my pump.
