Water & Airflow Advice needed
22 Jun 2015
Ok, i've just finished designing my loop and air flow. I just wanted to make sure I was heading in the right direction.
Is the fan set-up ok and also the water flow.
We would need to know full loop spec to detemine whether waterflow will be fine. It probably will be though.
Airflow looks negative though, might be worth flipping the rear fan around or changing the bottom rad to intake.
Koolance RP-401X2 Single 5.25 Reservoir for 1-2 PMP-400 Pumps
XSPC / Laing DDC-1T Plus Ultra 3.2 (18W) - MOTOR
EK Supremacy MX (CPU Waterblock)
EK-Thermosphere – Nickel (GPU Waterblock)
EK-RAM Monarch x2 Nickel (RAM Waterblock)
EK-RAM Monarch black plates
2 x Magicool G2 Slim Radiator 16 FPI - 240mm
4 x EK-Vardar F2-120 (1450rpm) Radiator fans
Loop flow is fine, but you should change the direction of the bottom rad fans to act as intakes rather than exhausts (to increase positive pressure).
Leave the rear as exhaust and swap the bottom rad to intake. If you have it as a exhaust the warm air is only going to be sucked back in by the psu and front fans.
Good luck!
Lookin at your diagram,would you not be better swapping the top rad round,so the fittings are on the righthand side rather than the left,for a cleaner look with your tubing?
Or is the diagram to scale and would be too tight a bend?
why not just put the bottom rad in the front as intake, and top rad as intake and forget about using the bottom mounts?
also, why ram blocks? (they dont add much performance-wise, and cooling-wise. ie just a waste of money)
Good luck!
Thank you for that. That is so obvious, how i didn't see that before, i don't know :o
Plus that's given me a great idea, cheers :)
Purely aesthetics tbh. Once you factor in the fittings, ram plates and of course the actual block, it only added an extra £80 to my build! For me it isn't just about the cooling/overclocking. Plus I would have only regretted it later, and i would hate to have to open it up so soon.
Once it's done, i will be posting up some images :p
