OcUK Staff
- 26 Nov 2014
- Stoke
That's correct, we have a new model in the Phanteks Primo range, the Black/White Special edition. This is similar to the other special editions, featuring a lovely white finish on the interior. Personally I think this looks the nicest out of all the Primo special editions. In stock now, but we have pretty limited stock on this one!
Phanteks Enthoo Primo Full Tower - Black/White @ £199.99 inc VAT
The bar has been set to a new standard with Phanteks’ release of their first Enthoo series case. Passionate about cooling and the one that brought you the world’s best air coolers, Phanteks enters the case arena with their functional design with exceptional cooling possibilities, the Enthoo Primo.
Accessibility and functionality is what sets the Enthoo Primo on a level of its own. It was constructed from a builder’s point of view with the closest attention to detail. This Enthoo Primo combines innovative design and rich styling that appeal to builders of any caliber. A glimpse through the split window side panel reveals the clean interior, capable of being water cooled, air cooled, or both.
Phanteks’ Enthoo Primo, unleash unlimited possibilities.
Specification
Case
- Colour: Black / White
- Form Factor: Full tower
- 5 Phanteks’ PH-F140SP premium 140 mm fans included
- Material(s): Aluminum faceplates, Steel chassis
- Motherboard support: ATX, EATX, mATX, SSI EEB
- Front I/O: 2x USB 3.0, 2x USB 2.0, Mic, Headphone, LED switch
- Side window: Yes, split-window design
- Expansion slots: 8
- Power Supply Slots: 2
- Dimension: 250(W) x 650(H) x 600(D) mm
- Warranty: 5 years
Drive Bays
- External 5.25” 5
- Internal 3.5” 6 (2x 3HDD cages)
- Internal 2.5” 12 (2x 3HDD cages + 2x doublestack SSD brackets *expandable to 3x)
Cooling (120mm fans)
- Front: 2x
- Top: 4x
- Side: 2x
- Rear: 2x
- Bottom: 4x
- HDD: 2x
- The PWM hub will enable PWM function to 3-pin fans. Total of 11 fans can be connected to the PWM hub.
Extensive water cooling support provides 5 different installation areas for slim and thick radiators varying from single to quad (120mm and 140mm form factors) with clearance for push-pull fan configurations.
Liquid Cooling Features
- Reservoir Brackets
- Pump Bracket
Radiator Support
- Front: Up to 240mm
- Top: Up to 480mm or 420mm
- Side without HDD Cages: Up to 240mm
- Rear: 120mm or 140mm
- Bottom: Up to 480mm or 280mm
Clearance
- CPU cooler 207mm
- Cable management 30mm
Only £199.99 inc VAT.
ORDER NOW
Specification
Case
- Warranty: 5 years
Drive Bays
- External 5.25” 5
- Front: 2x
- Top: 4x
- Side: 2x
- Rear: 2x
- Bottom: 4x
- HDD: 2x
- Pump Bracket
Radiator Support
Clearance
- CPU cooler 207mm
ORDER NOW
