***The Vapers Lounge*** 2.0
Status
Not open for further replies.
I haven't posted on here for a while. Whilst I have been away I have quit my job for a job in........ You guess it a vape shop. We (owner and me) could have our very own line of juices too.
Anywho can I ask if anyone has a Sigelei 75w?
If so, do the up and down buttons rattle like crazy.
Got mine through today. The buttons don't rattle if you shake the mod but do if you run you fingers over them. Very happy with it so far came with a silicon sleeve as well which I didn't know about.
Mines defiantly not like that. Did you manage to get a black one? Was up at half 6 and they had sold out so ended up with silver.
What settings are you using? Not entirely sure what I'm doing with temp control but got a Kanger TC coil set at 480F and 45W and happy with the results so far.
Yea the 510 is pretty much just flush with the 510 threads due to the spring loaded mod connector, so no need for it to be out much more than that - ive probably got the coil wrong somewhere judging by your experience and that it works for you no problem, ill give a 2.5mm coil a go like yours.
Give it a go also keep the coil legs at the bottom when you install it in the deck it seems to keep the coil a bit more tighter .
Cheers all
Picked up my vaipmail today from the post office. Have been vaping my epoch D1 all day so i thought i would share a cobbled together little review with you all.
The tank came with a few small burrs around the window frame of the tank itself, they didn't take long to clean off and the over all cleanliness of the parts was good with little machine oil to be found. the package comes with a plethora of o rings, a small double ended screw driver and a extra top cap that accepts a standard driptip, this is to replace the installed one piece top cap/drip tip and both are delrin. Unfortunately a spare pyrex tank is not included which is a shame, most if not all tanks in this end of the market these days come with this.
The plethora of o rings are needed as this tank has a total of 8 installed, quite a few i think you would agree.
The D1 is dual coil tank and it's your standard 3 post design with a center T post that is fixed in place by the copper 510 center pin, the pin is non adjustable but is pronounced though i wouldn't feel comfortable using the tank on a hybrid mod. The capacity of the tank is small, 2.5ml capacity is all you have but with it's top fill design refilling on the move is no issue so i think it may be a minor downside some, including me, are willing to overlook.
On the deck you will find some nice little features unique to the Epoch D1 one of which being the juice feed system, around the deck are 4 holes that taper from large to small and connect the upper deck to a cavity underneath, the system requires you to just push your cotton into these small holes and be done with it, it really is that simple.
Another nice little feature of the deck is the offset air holes, the offset of these makes installing coils a dream and really lets you direct that airflow over any size coil without the unwanted and added resistance of long coil legs.
The upper and lower decks are separated using one of the multitude of O rings to seal the one piece chimney, once installed this chimney doubles as your 'flow control' but how much control this method provides is not clear to me yet, vaping max vg i find it fine just opening it fully and have had no leaking or gurgling from normal use.
The top of the chimney is notched, this notch is keyed to the inner section of both delrin top caps, this provides the connection from the chimney section to the outside of the device and turning the delrin top cap opens and closes the feed system. Removing the push fit cap grants access to the tank for top filling but be warned the feed system must be fully closed before removing the top cap to prevent flooding.
Once filled push the delrin cap back on, you will feel resistance form the pressure in the tank, i have found the best thing to do now is invert the tank and allow the air to rise to the deck, now unscrew the flow control to allow the air to escape. your tank is now filled!
The tolerances on the machining of this tank are tight, a little to tight if i am honest and when first dismantled for cleaning i found it very stiff to remove some of the parts. Removal of the bottom ring from the tank section was most tricky as there is a complete absence of any knurling to assist you but i found once e liquid was introduced all the threading became much more usable.
The airflow is slightly less than the subtank mini and anything less than wide open results in a pronounced whistle though i have not used it on any other setting than wide open so a non issue for me. The movement on the AFC is smooth with a firm feel.
Flavor is fantastic on this tank, the vape is warm and flavorful and it produces a great amount of vapor and handles decent watts to boot. I currently have dual 26awg 7 wrap 2.5mm coils reading 0.36ohm vaping at 30w, 40 is fine but flavor of my jam rolly polly juice falls off after 33w, custard on the same coils tasted great at 40w.
All in i like the tank a lot, sure 2.5ml isn't great but top fill and superb flavor make up for this in droves, machining and materiel quality are great for the price but i would like to see more air flow options and the loss of that whistle.
Would i buy it again? yes, my subtank mini is now relegated, this is superior in every way bar capacity and the easiest tank i have ever coiled with no dry hits to be found.
I really can't wait to chuck some clapton coils in and really get that flavor booming
If a high end tank was released in the £120+ bracket with this wicking system and a more refined fit to the parts i would buy it in a flash.
I too got the silver one but then I did prefer it to the 2 tone black and silver.
I stupidly purchased ni200 ribbon instead of round from stealth vape. I must have snapped the legs 3 times just attaching it to a Magma. If I had bought the right type I would have just twisted a few strands.
I personally don't see me buying the pre built nickel coils for subtanks as I see temperature control as a great way for me to enjoy the 4 or 5 drippers I have accrued.
Ok heres one for the TC boffins in here, following on from my previous post about my Squape and the VT40, ive managed to get a coil that doesnt heat up the atomiser at all...but here comes another one, set to 400F and at 12watts it hits the protection in about 2 seconds, and if you watch the temp, it randomly jumps upto 1000f and goes down etc..have i got a duff chip in the VT40 i wonder.
Edit- like for exmaple it works for the first hit, but thereafter it doesnt work and just goes into temp protection mode no matter what i do.
To those that DIY
I've mixed my first couple of 10ml bottles of juice. I'm using FA Velvet Cloud base and mixing 30/70 PG/VG 3MG Nicotine.
I've mixed a second attempt at a strawberry cream (first one was quite subtle on flavour) a blackcurrant cream and a custard cream.
My first 10ml of strawberry cream was left 3/4 days to steep and I'm currently vaping it in my Lemo2 and its good other than needing a little more flavour for my taste (Does it just need more time to steep to release the flavour?). I've just tried my fresh 3 mixes on my Velocity RDA (26Gauge Clapton 0.21ohm on a Nemesis Clone) and they're very very harsh and have more or less flavour.
Is this just because they need some time to steep or is there something wrong with my mixes percentages below for flavours
Strawberry/Blackcurrant/Custard 4%
Fresh Cream 2%
Vienna Cream 2%
Marshmellow 1.5%
Meringue 1.5%
custard needs 2 weeks minimum to get any sort of creamy taste, fruits need less but i would say a week.
When they are mixed shake very very well, plenty of space in the bottles, around half full and introduce lots of oxygen in to them,. leave with the top off for a day in the dark and squeeze out the air to replace it with fresh morning and night,
you are vaping vg heavy and list 11%, vg doesn't carry flavor as well as pg so i dont mix less than 15% and usually 20%, custard i have gone as high as 23%
Have you go another attay to test it with? The pin on the squape is loose and will cause the ohms to flux slightly, coupled that with the DNA chip and a weak spring in the mod and it's a mare. As the temp control will kick in as soon as the ohm level changes.
I've spoke to Christian the maker of the squape, and by design the pin is adjustable by finger nail, as you can turn the pin in and out with just your finger nail.. He has said that the number of "faulty" decks and pin uses that they received back because of the rdna and the flask... The issue has never been with the attay but the spring in the mod being loose also.
I've not got a VT40 so I don't know how hard the spring is.. But my squape reads perfectly fine on all my mods expect for my rdna.
Also depending on the age of the attay, you may want to remove the pin and use a pipe cleaner or dentist brush to clean the threads of where in screws into.. A few people said that fixed their issues when it comes to ohm reads and changes..
In that case I'll forget about them for a week of two and see what how they are then, I assume the lack of steeping is also why they are harsh and making me cough? I usually vape a variety of 3&6 nic in anything from 50/50 to 20/80
Spring in the Vt40 is very stiff on mine, i get that the adjustable 510 could cause issues, its just confusing that the ohms are the same and dont appear to be changing at all - like i say ive got rid of the hot atty issue, but its just the Temp hitting the limit very fast now - i have a Kayfun 4 i can try on, or an origen v2 dripper or igo-l -w.
Try it on one of your RDAs mate.. The kf4 is another nightmare when it comes to temperature control, they released an upgraded spring for it to help; I gave up with kf4 totally.
Alrighty ill try one of the RDA's and ive got the gold spring in my kayfun 4, it did stop kanthal coils flucuations it had, i agree its a nightmare hence why i bought the squape, i tell you what its a monster in flavour compared to the kayfun and just edges it against my old rose v2..wish i had bought a squape a long time ago.
To those that DIY
Fresh Cream 2%
Vienna Cream 2%
Marshmellow 1.5%
Meringue 1.5%
Leave them for a couple days in a dark place (shoebox) and the flavours should marry together mate.
Good to see a fellow FA concentrate user!
There's an hour ish long video on YouTube which explains the DNA 40 and which tanks work better than which and why. It's by some Dutch (I think) bloke and it's actually a rdna 40 review but explains the chip well.
Even PB who's the worlds biggest KF fan boi says the vape from a KF is hot compared to others. I'm just not a fan of the dna40 chip, I brought it when it was version 2 or 3.. The one with the big screen, when it first come out and haven't brought another since, we are now on version 5 or 6 and the issues are still there. It is worth trying a factory made coil, if you have a tank that supports it so you can see what the vape is like of ni200.
Just had my first mod auto firing on me....
I was just in my living room, PJs on.. re-coiling a few atties, like I do every Sunday morning... and heard a hissing sound coming from the locations where I keep my mods.
Anyway; it was my egrip which I had since november-ish and it was just firing for no reason. button would not work on it. So I just unscrewed the attomizer cap, wasn't hot or anything and I was in the living room for a good hour before it started to do this. I did wash it out last night and only pop the atty base back on to it just before I went to bed and the tank was empty.
I've pop the atty base back into the unit, and it was ok again; but the button and charger didn't work. so I just left it on the table and it started autofiring again after 30 odd mins.
Just tired taking it apart, no water in the electronics as far as I can see, I was too weedy to take the full thing apart, as the top base seems well on there and I'd managed to damage a few tools trying. anyway I've just blasted contact cleaner over the button and it seems like the button is now working and so is the charger port.
Odd thing was that coil and atty base was still dam...
I've taken the atty base back out of it and it's in a charge bag in my bathtub at the moment just in case it decides that it's still broken, as I need to do my weekly food shop and I'll test fully when I back.
Got my new juices, fared a bit better this time!
Penguin - Rockhopper - Gross. Tastes like mould. Smell of the liquid is pretty rank too. Bin pile.
Captain's Reserve - Starboard. Says it's Apple, Kiwi, Lime and Mango. To be honest all i can taste is the apple. There is something else on the exhale, seems a bit like cinnamon though. This is quite a nice vape, i like it, nice and refreshing. Vapour production is ok.
Think it's 50/50 mix. Only got a 10ml and used half as it went in my Subtank. Have ordered some more and another flavour from the range.
NJOY - Samba Sun - I must admit i've never heard of this companies actual e-cig products so was going into this new. It's billed as Clementine, Marshmallow, Peach & Apricot. It's very good, the clementine is very strong but not sickly. Get a little peach and something creamy on the exhale. Great vapour too, 60/40 i think. Was a bit apprehensive as they only sell in 30ml bottles but will get through it no problem.
Must Vape - Handlebar. Billed as Peach & Pineapple but i'm not sure what the actual flavour is, i don't get either really. It's sweet but not too much, very refreshing. Nice clouds too as it's a 65/35 mix.
Cheers slinxy, i did find a find a few videos last night, and the thing that i didnt know or didnt understand was the 'baseline' setting the dna uses on the first press - all the time i had been coiling the squape i had been using the dna, which in turn made that warm, so with a cold atty on it it was using the wrong baseline, so this morning they were both cold i whacked it on, selected new coil and it seems to be working perfectly well, no temp protected so far.
Edit - Only thing its doing, is everynow and then it jumps out of TC mode and goes into normal mode, but a simple press of the button again and its back to firing in TC - Not sure i like the vape though, its totally different
Status
