3DMark API OVERHEAD TEST
25 Nov 2011
The KOP
Lets see how we compare now that AMD has improved there Draw Calls for DX11 over the past couple months.
DX11 Multi-threaded draw calls per second 1,045 829
DX11 Single-threaded draw calls per second 1,062 395
DX11 Multi-threaded draw calls per frame 35,328
DX11 Single-threaded draw calls per frame 35,328
i7 3770k @4.2 290 @1030/1250 Driver 15.7 - 1440p
http://www.3dmark.com/aot/42647
DX11 Multi-threaded draw calls per second 1,044 619
DX11 Single-threaded draw calls per second 1,113 866
DX11 Multi-threaded draw calls per frame 36,864
DX11 Single-threaded draw calls per frame 38,400
i7 3770k @4.2 290 @1030/1250 Driver 15.7 - 720p
http://www.3dmark.com/aot/42800
Thats 720p Should have said am running 1440p
I'm adding DX11 to this but removing all resolutions above 720P.
As we found out higher resolutions make no difference to scores.
its also far too cluttered with so many resolutions.
Its better to make room for DX11 and clean it up so that people can actually see whats going on.
i will post back when i have made the changes. thanks :)
Hi!
Humbug am seeing different results, based on different Resolutions..
Your results on post #1?
It looks like you have about a 10% difference in DX11 Single threaded. And maybe Multi threaded, a bit. is that consistent?
The results i found at the time
Win8.1 - Mantle - FX-9590 @ 4.7Ghz - 290 @ 1180/1375.
720P: 14,405,912. http://www.3dmark.com/3dm/6411636
1080P: 14,306,375. http://www.3dmark.com/3dm/6411993
1440P: 14,159,114. http://www.3dmark.com/3dm/6411686
4K: 13,890,447. http://www.3dmark.com/3dm/6411705
5K: 13,408,873. http://www.3dmark.com/3dm/6411731
8K: 12,106,05. http://www.3dmark.com/3dm/6411752
above 4K it starts to drop but thats because it starts to become GPU bound
Its what everyone else also found, thats why i changed it, that and it was so cluttered no one could make sense of it.
What do you suggest? i mean your results look pretty consistent apart from DX11 single thread.
If they is a difference to be had then I feel all bench results should have there own section.
Sectioned by Driver? it looks like the Driver is better. Run that first one again at 720P
720p
DX11 Multi-threaded draw calls per second 1,076 296
DX11 Single-threaded draw calls per second 1,081 032
ok I see what you might be getting at here.. Now my 720p test is much worst then it was before.
Your getting more DrawCalls in the Frame at higher res because the Frame is bigger, it has more information in it, when you crunch it down its still the same number of DrawCalls at any given time, thats why your DrawCalls per second are the same. :)
Edit: I.E the latency in calls is still the same.
Ok whats the most important result. Per Frame or Per Second?
Per Second, as a completely inaccurate but practical example: if the API with one thread takes 20ms to call an object then it will take 100ms to call 5 objects. so if there are more objects to call it will call more objects but take longer, so at any given time the amount of objects called is the same.
I7-3770k @ 4.3GHz
7970 @ 1100/1500MHz
W7
15.6
DX11 MT 907 441
DX11 ST 921 565
1036:
DX11 MT 1 091 712
DX11 ST 1 184 316
1038:
DX11 MT 1 121 610
DX11 ST 1 184 317
1023.5
DX11 MT 1 137 720
DX11 ST 1 193 648
1040.0
DX11 MT 1 203 383
DX11 ST 1 252 605
1023.10
DX11 MT 1 216 165
DX11 ST 1 290 934
15.15
DX11 MT 1 185 952
DX11 ST 1 201 633
15.7
DX11 MT 1 223 682
DX11 ST 1 284 336
Shanks, resolution doesn't really matter in 3dmark api test as gpu is running on low usage.
