- 23 Mar 2011
As above found an 08 car 3L version, judt wondering if the autos are reliable etc
Thanks!
Thanks!
[TW]Fox;28307330 said:Is there really much difference between 07 and 08? It's not as if you were looking at an 11 and an 07 popped up is it.
An 08 is barley any newer than an 07, not enough to be categorised as 'too old' under criteria that allows an 08.
Noo sorry i was under the impression 08 onwards got a facelift etc? May be wrong then swear i heard that somewhere!
[TW]Fox;28306831 said:The boxes will be fine with that mileage - your main issue with that car will be the temperamental N53 stratified direct injection engine it has. The earlier 2.5 litre version is more reliable.
Check the indicators work, it's a common fault on BMWs.
