Hi Guys
some really nice looking mice launching today. Cougar have really pulled something special out with these products.
The colours and specs are all top level. Pricing is brilliant too!
Cougar 500M Optical Gaming Mouse - Black @ £27.95 inc VAT
500M is one of the finest gaming tools you can currently purchase. With an excellent sensor, good components and rich functionality, owning a 500M will significantly enhance your gaming experience.
BORN FOR GAMING
COUGAR 500M becomes one with your hand and allows you to unleash your full power. This gaming mouse's design is based on sound ergonomics, and goes a step further from mere comfort: it helps you enhance your control of the mouse. COUGAR 500M, a superb gaming mouse that brings you the best ergonomic design.
ACCURATE AND RELIABLE
A good gaming mouse has to have a good sensor, and COUGAR 500M brings you one of the best sensors on the market: ADNS-3090. This 4000 DPI optical sensor brings you all the accuracy you need for your games, and allows you to adjust the DPI level on the fly. Adding to this, COUGAR 500M's 1000Hz Polling Rate provides a 1ms response time that will bring your commands almost instantly to the game.
A WORLD OF FUNCTIONS
COUGAR 500M brings you all the functionality you will ever need for gaming. Its 6 fully configurable buttons allow you to access, using only the mouse, up to 21 different functions, including macros, shortcuts and more. With carefully located buttons, including the distinctive Trigger Button, using all this extended functionality will become natural, almost instinctive. All this goes a step further with UIX System. COUGAR's gaming device management system allows you to easily and intuitively manage all this power. COUGAR 500M's internal memory will allow you to store up to 3 full configuration profiles and bring them with you anywhere you go.
Specification:
- Sensor: ADNS-3090 Optical gaming sensor
- Resolution: 400/800/1200/1600/2000/2400/3200/4000 DPI
- Game type: FPS / MMORPG / MOBA / RTS
- Polling rate: 1000Hz / 1ms
- On-board memory: YES
- Software: COUGAR UIX™ SYSTEM
- Programmable buttons: 6
- Switching: OMRON gaming switches
- Profile LED backlight: 16.8 million colors
- Frame rate: 6400 FPS
- Maximum tracking speed: 60 IPS
- Maximum acceleration: 20 G
- Interface: USB plug
- Cable length: 1.8m Braided
- Dimension: 135(L) X 70(W) X 45(H) mm
- Weight: 115g
Only £27.95 inc VAT.
ORDER NOW
Cougar 500M Optical Gaming Mouse - White @ £27.95 inc VAT
BORN FOR GAMING
Specification:
- Weight: 115g
ORDER NOW
Cougar 550M Optical Gaming Mouse - Iron Grey @ £41.99 inc VAT
Let's get this straight: If you engage in online gaming or are interested in it, if you love serious gaming and need appropriate gaming gear, 550M is what you're looking for. COUGAR 550M is the best professional level gaming mouse. Let us tell you why.
BORN FOR GAMING
COUGAR 550M becomes one with your hand and allows you to unleash your full power. This gaming mouse's design is based on sound ergonomics, and goes a step further from mere comfort: it helps you enhance your control of the mouse. COUGAR 550M, the best gaming mouse that brings you the best ergonomic design.
COUGAR 550M brings you all the functionality you will ever need for gaming. Its 6 buttons allow you to access, using only the mouse, up to 21 different functions, including macros, shortcuts and more. With carefully located buttons, including the distinctive Trigger Button, using all this extended functionality will become natural, almost instinctive. All this goes a step further with UIX System. COUGAR's gaming device management system allows you to easily and intuitively manage all this power. COUGAR 550M's 512 Kb internal memory will allow you to store up to 3 full configuration profiles and bring them with you anywhere you go.
Specification:
Sensor: SDNS-3988 Optical gaming sensor
Resolution: 50-6400 DPI
On-board memory: 512KB
Software:COUGAR UIX™ SYSTEM
Profile LED backlight: 2 ZONE 16.8 million colors
Frame rate: 12500 FPS
Maximum tracking speed: 200 IPS
Maximum acceleration: 50 G
Interface: Golden-plated USB plug
Weight: 120g
Only £41.99 inc VAT.
ORDER NOW
Cougar 550M Optical Gaming Mouse - Metallic Blue @ £41.99 inc VAT
BORN FOR GAMING
Specification:
Weight: 120g
ORDER NOW
BORN FOR GAMING
Specification:
- Weight: 115g
ORDER NOW
BORN FOR GAMING
Specification:
- Weight: 115g
ORDER NOW
BORN FOR GAMING
Specification:
Weight: 120g
ORDER NOW
BORN FOR GAMING
Specification:
Weight: 120g
ORDER NOW
