Hello,
Been looking at all the tasty 980Ti cards (it is that time 12 months after my last GPU upgrade when I get itchy...) and I have a question:
Will a cooler like the Asus strix / MSI Gaming / EVGA ACX etc... be a problem in such a small case?
I run only one card (no SLI or Crossfire) and have a reasonable airflow with 2x silent 80mm exhaust fans in the back and 2x silent 92mm intake fans in the front, with a low profile 80mm intake fan by the cpu. I took out unnecessary hard drive frames for better airflow and have routed my cables around the edges and under the motherboard. That said, there is only 1-2cm clearance between the edge of the GPU and the case so it is quite a confined space. My room gets quite hot even without the PC running (the plasma doesn't exactly help in this weather) but with the 780Ti reference blower my CPU and GPU overclock are stable.
I hear people say that the uprated coolers like those listed above enable better overclocks on the GPU with lower temperatures, but they also seem to generate more hot air inside the case as they leak the hot air in all directions, not just out the back.
Does anyone else have experience with an Htpc case and going from reference to aftermarket style cooler? (AMD or Nvidia, although I think the heat from the 290 and 390 would make this more if an issue). Did this cause you any problems with CPU or Motherboard temps going up?
Here are some pictures of the current setup:
https://www.dropbox.com/s/9vqqlf6d6a3ngp8/CagedBeast1.jpg?dl=0
https://www.dropbox.com/s/ddlw5kl6h9fddko/CagedBeast2.jpg?dl=0
https://www.dropbox.com/s/7qo4m9zh8jgxvhz/CagedBeast4.jpg?dl=0
