** INSANE LAPTOP DEAL, ONLY 7 UNITS LEFT, LUCKY FOR SOME!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Got a truly incredible deal for 7 lucky customers who are quick enough:
GIGABYTE P25X v2-CF2 Gamer 15.6" Full HD IPS Display, Intel Core i7-4710MQ, 16GB DDR3L, 2 x 256GB SSD & 1TB 7200TPM HDD, NVIDIA GTX880M 8192MB GDDR5 - Windows 8.1 @ £1,199.99 inc VAT
Unrivaled Performance with the all new Intel® Core™ Processor
Experience revolutionary battery life improvement, super-speed performance, ultra-fast image / graphics processing, and many other security protection capabilities with the Haswell platform 4th generation Intel® Core™ Processor. Built on the 22nm architectural process making use of the latest 3D Tri-Gate transistor technology allows for unrivaled performance.
Incredibly Powerful Gaming Discrete Graphics Revealed
Features a highest level NEW NVIDIA® GeForce® GTX 880M GDDR5 8GB graphics processor that supports NVIDIA® FXAA, Adaptive V-Sync technology! With the latest Ultra Boost technology you can easily choose the Extreme mode through an intuitive interface.
Vivid Visual Enjoyment with the 1080p Full HD IPS Matte Display
The 1080p Full HD matte display panel features a light scattering anti-glare layer, which diffuses light, eliminating reflections and delivering a sublime gaming experience. Adding IPS Wide Angle Display, it literally bring games to life from any direction you look at it
Electroluminescence Backlit Keyboard
The P25X epitomizes an automatic light sensing backlit keyboard. This significant feature adjusts the light to external conditions and makes typing and gaming in dimly lit rooms and dark conditions better and easier.
High Performance, Massive Storage System
The P25X is able to pack up to two mSATA 512GB SSD and 1 huge 1TB HDD. It provides massive storage options and delivers super fast performance of 1000MB/s and 850MB/s read/write rate for gamers with mSATA SSD super RAID 0 technology supported. Use the power of Raid 0 technology to your advantage for co-op or sharing games, giving gamers an experience like never before.
Dynamic Sound, Truly Amazing
The unique 4 Dual-channel Stereo Speakers are designed to provide dynamic and realistic sound effects, along with a subwoofer that boosts the deep, punchy bass. The result is a high-fidelity audio experience that is perfect for gaming and multimedia.
Rear Dual Air Vent Design Provides Effective Cooling
The P25W adopts a unique dual heat sink design with dual air vents (one for the CPU and the other for the GPU), increasing its gaming stability. The unique venting system is able to effectively keep the laptop from overheating despite the powerful features under the hood in this machine.
Specification
- Display: 15.6", 1920*1080 Full HD
- Processor Type: Intel Core i7 4710MQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.40GHz (3.40GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 256GB SSD x 2
- Hard Drive Speed: 7200RPM
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 16GB
- Operating System: Windows 8.1
- Graphics Chipset: NVIDIA GeForce GTX 880M
- Graphics Memory: 8GB GDDR 5
- Chipset: Intel HM87 Express
- Optical Drive: BluRay ReWritable Drive
- Microphone: Built-in
- LAN: 10/100/1000Mbps
- Wireless: 802.11 ac
- Bluetooth: v4.0
- USB 3.0 Port(s): 2
- eSATA/USB 2.0 Port(s): 1
- HDMI Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Web Camera:1.0MP
- Keyboard: Backlight LED
- Dimension: 392 x 263 x 32.1~38.3mm
- Battery: Li-ion 8-cell, 5700mAh, 86.18Wh
- Product Weight (g): ~2.6Kgs
- Warranty: 2 Years
Was [£1499.99] Inc. VAT
Only £1,199.99 inc VAT.
ORDER NOW
The original RRP on this unit was close to £2000, now it is £1199 for a laptop with GTX 880M 8GB which I believe outperforms GTX 970M, it features i7 processor, 16GB RAM and 2x256GB SSD and 1TB HDD. Making it the best value for money laptop we sell considering the specification and performance. :)
Says £1399.
Hi varkanoid,
Product has been at OcUK for a while and when first ranged it was £1,899...
It has varied in price between £1,899 and £1,499 whilst we gave support to OcuK on the price.
SO yes, the most recent price it has been at was £1,399 last week, so this is why the THIS WEEK ONLY price shows this as the discounted price, but as outlined here, the discount is actually far more substantial considering the spec.
Hope that clarifies.
Regards
Gigabyte UK NB Team
970M is actually a bit faster than the 880M I believe (and uses less power), but still strong performer :)
Hi Alexrose1uk,
You are correct this GPU is approx. 6% lower performance than GTX970m, but when considering the whole spec if the machine we believe this is the best value to performance ratio laptop on the market today.
Its actually very close,,,
ON 3dMark11 benchmark
GTX880M scores approx. 8,500
GTX970M scores approx. 9,000
So about 6% difference.
Regards,
Gigabyte UK NB Team
Oh yes no doubt. If I was in the market for a machine right now this would be right there in my hot list, I just wanted to make it clear on gpu performance contrary to the OP so no one was dissapointed. It's a lovely spec :)
As a past several time Clevo owner myself, they do some fantastic machines, BUT if you have any issues, you are completely dependant on the service centre local to you/supplier to resolve. And sometimes that can take a long time, dependant on how common the fault is, or what it is.
Can't imagine that's an issue with Gigabyte in the same way....
Shame OcUK isn't doing much in this (Clevo) line recently.
Doesn't seem like that great a deal stacked up against a Clevo to be honest.
Haven't kept up with Clevo specs in awhile but I'd have thought you'd struggle to get an all around spec that beats the price - its not a bad price at all for an i7, 16GB RAM and a couple of SSDs in a 15" chassis.
I've seen something based off a Clevo P650SE with similar specs, no SSDs, but with a 4K screen for less.
