Screen Crack Benq xl2411 *help plz*
12 Feb 2013
Hi everyone
Is it possible to fix my cracked monitor Benq Xl2411 and if so would I have to fix it myself or is there a company that could do this for me?? :confused: :confused:
The screen or the bezel?
House insurance probably best options mate or anything on ebay for spares/repair. Won't be the most difficult fix in the world but getting parts is probably tricky.
Sure you can fix it just, lcds are so easy to replace just take it apart remove the LCD, they simply just plug in,
Usually the hardest part will be splitting off the front surround. Just remove the screws at the back and unclip the front part
Easy peas, just make sure you get the correct LCD, somewhere on it there will probably be a part number, ill keep an eye out and help you if you want.
Just had a look on ebay cant see any lcds for it, they probably use an lcd from a different monitor, which is quite common. what I would do is contact a seller on ebay who sells replacement lcds, and ask them if they can get hold of one that will fit yours.
Honestly they are so easy to fix you've nothing to loose really just take it apart and have a look.
