EVGA GeForce GTX 980 Ti Kingpin Edition Launched
Man of Honour
21 May 2012
Dalek flagship
http://www.techpowerup.com/214461/evga-geforce-gtx-980-ti-kingpin-edition-launched.html
Why do they bother spending so much money/effort on that cooler? The only reason to buy this card is to use a chiller, phase or LN2.
Are there really people out there that pay such a premium and run it on air?
Yep!
Its only money & you might as well spend it before the government take it off you in death & taxes... ;)
Just to shed more light on the overclocking with Maxwell here is a quote from Vince Lucido himself
Honestly speaking, I think most end users don't even realize how maxwell gpus are voltage capped at ambient type cooling. I can tell by many of the comments at OC.net, elsewhere, and also here in these card XOC bios threads. Especially compared to kepler. KP 780ti scaled great on voltage with air/water temps. Basically, more voltage = more clocks no matter what temperature.
With 980 and later gpus including titanX, the scaling on air/water has all but almost gone. I would say about 95% of all maxwell 980,titan-X, and 980ti gpus NO MATTER what vga brand pcb it is on, DO NOT SCALE with more voltage than 1.25v-1.275v at temps warmer than 25c or so. There is no magical bios that can effectively remove this.
This is exactly why almost every moderate-good asic titanX, 980, and yes 980ti clock around 1550mhz MAX AVERAGE at say 45-60C loading temps.
If you put 0c and colder on the card, you will see MUCH different behavior than what you see on air (green garbage all over screen when raising volts over 1.23-1.25vv or so)
Cards with very good ASIC value (75% and up) will tend to have the most "overclocking", but just like about every other maxwell gpu, they cannot overvolt past 1.23v-1.25v.
So highest asic cards like 80% +are almost always going to be the ones that can 1600+ on air/water, and again they do it pretty much WITHOUT overvolting over 1.23v-1.25v. Maxwell gpus with lower asic value like 65% will not be so great at air/water because these low asic gpus need voltage to scale compared to match the overclock of the high asic gpus( USING SAME USABLE VOLTAGE 1.23-1.25v)
The bios's I posted basically allow you to set a higher voltage on air/water. Some gpus can scale more, some cant, some actually will NEED more voltage than was previously needed to run same frequency. All different
http://www.overclock.net/t/1476455/official-galax-galaxy-kfa2-hof-owners-club/1850#post_24196028
Also just for the lolz
Holy crap they finally did it! You can buy the KPE with whatever ASIC % you want! No more Silicon Lottery!! This is PERFECT for maxwell OC because ASIC is what matters the most.
Nice, now everybody getting any other EVGA card can expect <72% Asic, even classified (there are with higher percentage, but that's the message they're giving).
Also its saying if you buy the cheap one you wont in all probability be getting one above a certain amount if you want the tops one you going to have to pay full dollar. Good and Bad in this.
So, you buy a lesser EVGA card knowing it's been pre-binned as a lesser card.
No thanks.
No thanks.
Aye seems pretty bad in that sense. Although i am sure its going to appeal to those who want 80% ASIC quality.
I would not be suprised if they fail with this as the people buying kingpin wont want to scrimp and will probably the vast majority be trying to get the 80% ASIC.
When they run out of the top ones can you see people happy knowing that they are buying a second grade KingPin ?
Good point, can't say I would - especially given the pricing.
Annoying knowing that when my hybrid eventually arrives it'll have a low ASIC... not a great marketing strategy to be honest. Either every card needs its rating specified or none should.
edit: That said, lower is supposedly better for water anyway isn't it? Surely anyone getting a kingpin will prefer lower if they intend to use water..
Not with maxwell no, low asic can mean good overclocking with added voltage, but what vince is saying is that adding voltage on water/air temps (anything over 25C) doesn't really help over 1.25v, so the only people "wanting" low asic are going to be LN2 benchers
