Gigabyte Z170 shown at Computex.
Caporegime
17 Jan 2010
weston-super-mare
New Z170 Gigabyte boards shown at Computex.
Skylake is due in a month or two and so many Z170 boards were shown off at this years Computex.
Gigabyte had some killer looking boards shown off such as,
GA-Z170 Gaming G1
11351290_10153331744253695_5274512125655558054_n_zpsixd57mb2.jpg~original
11391321_10153331744263695_5591295166564840079_n_zpszf7dccqg.jpg~original
This will be one of the top end boards and fully loaded.
LED trace paths feature seven colour choices.
11406704_10153331744298695_6169554072723004243_o_zpsshc9fj1t.jpg~original
Sound is via Creative ZxRi, three OP-AMPS it seems and it has the high-end audio grade Nichicon capacitors you would expect.
11411151_841650589251017_6127340560276790033_o_zpsmh5e5jui.jpg~original
Expansion slots have these metal supports for extra heavy/large GFX cards (and help reduce signal noise apparently) and two 32Gb/s M.2 slots
11143287_841650539251022_6365129575318275154_o_zpsty0ljrp0.jpg~original
Lots of SATAIII and SATA express.
11125255_10153331744273695_5930639695856993405_o_zpseelreqkr.jpg~original
PLX chip so it supports 4way SLI+Crossfire, Turbo Bclock could be an extra clock generator a bit like the Z97 SOC Force had.
1465410_1078427465504232_8181613047334367466_n_zpsz1mku9hg.jpg~original
Threaded holes for water cooling barbs and underneath what looks like a huge phase count to provide good clean power to the CPU.
11270330_841650559251020_8801894240509818213_o_zps9ko2fdwg.jpg~original
Two USB3.0 internal headers, ECO mode slows CPU to conserve power/heat.
11289652_10153331744233695_5779183424932012805_o_zpsralyen1z.jpg~original
Rear I/O is fully loaded with USB3.1 typeC, Dual NICs and WiFi.
GA-Z170X Gaming 7
11415483_10153331744293695_8149500040586040463_o_zpsb2mm53rh.jpg~original
Still a well featured board.
11080768_1056702711024931_6440268296048170154_o_zpslxmvtldy.jpg~original
2 way SLI and maybe 3 way Crossfire and still two 32Gb/s M.2 slots
11252550_1056702837691585_3583767011119363093_o_zps1lhkgg72.jpg~original
Creative sound chip, still has the fancy audio capacitors and OP-AMP upgrade option.
11402472_1056702694358266_6695847859897107003_o_zpsvnqnd0oe.jpg~original
Still a lot of power phases it seems hiding under the heatsinks.
11406291_1056702681024934_6923698732121935745_o_zpsivx4opxn.jpg~original
Rear I/O looking good including USB3.1 TypeC and gold plated connectors.
GA-Z170X Gaming 5.
11329756_1078426892170956_8621411611114105675_n_zpsron0fjsf.jpg~original
Killer NIC, USB3.1 typeC, 32Gb/s M.2 slot, 3 SATA Express, possibly Realtek Sound chip on this board due to costs.
GA-Z170X Gaming 3
996143_1078426598837652_7744956650870070976_n_zpspsv19tpl.jpg~original
Killer NIC, USB3.1 typeC, 2way SLI and 3way Crossfire I'm guessing.
GA-Z170X UD5 TH
11390092_10153331783073695_8694521128973832496_n_zpsvmkje3fi.jpg~original
A nice looking board and the gold is tastefully done, the metal slot covers could do with being black.
GA-Z170X UD3.
11390167_10153331783078695_3945324949272300845_n_zpswc98yt7e.jpg~original
All that Ultra Durable goodness in a budget friendly board.
So overall an impressive looking line up, nice to see legacy PCI expansion slots have been killed off on these ones (although do make an appearance on some lesser boards that if seen on the web). Also note a lack of mATX Gaming board and of course an orange+black overclcoking option or two as per previous chipsets which I can't wait to see and which are surely coming.
Looks like all of them apart from the UD5 have 2x m.2 slots. Wonder if they are all ultra speeds this time round from GB.
I personally think the Asrock Extreme 7 is the nicest looking board so far, might have to try and pull together some pennies for an upgrade to build an editing machine. Be interesting to compare z170 to x99.
Prefer the look of the UD boards in Tha lineup. The G series look a bit over the top. Cracking good boards I suspect though.
I think the ultra-durables look better than the gaming boards, so I suspect I'll be getting one of them for white, black and yellow/gold build when skylake comes out.
Any board that isn't white or red and black
ANY BOARD
its so annoying that motherboard manufacturers have gone away from the stealth look. now everyone and his dog is doing red and black
why do they always put the pci-e x4 at the bottom? For multi card setups, would it not be better to put a x16 at the top (as normal), and another x16 furthest away at the bottom to create a nice big space in between for sli/crossfire?
I can feel a new build coming along. That gaming G1 board is just gorgeous :eek:
It must be something to do with the way the board gets power or something? I don't know.
I just noticed most of them have twin M.2 slots, wonder if they are the turbo version like on the MSI board that can be put into Raid0 for close to 64gb/s
One of the best boards I've had was the gigabyte sniper, but man that was ugly, why put ammo magazines on a mobo..... Hope they fired whoever did that!
The z97 and z170 boards all seem ugly and slimmed down features wise.
Where's all the good quality heatsinks and copper pcb's ? to me all these boards look like bottom end boards for a medium to high price ? they look flimsy and cheap.
What happened to mid range boards having dual lan ports as standard for example ? also they seem to be still messing up the design of the spacing and especially pciex1 slots, I've never used a pciex1 slot for my soundcard I always used the bottom gpu slot because the spacing and clearance is never enough.
Just feels like they are reducing the quality of the parts and capacitors but keeping the prices the same.
Do they even have dual bios and bios profile saving ability ? ddr4 seems overpriced as well so no upgrade for me I will never pay more than £40-£50 for 8gb ram.
Sorry to be a moany old git but until ddr4 2x 4gb = £40-£50 I shant be upgrading to it.
They have messed up here people are more savvy now they aren't going to pay these silly prices for DDR4 for no performance gain.
I quite like the look of the boards, still tempted to upgrade but will wait for proper reviews and pricing.
The PCBs have 2oz of copper in them, its part of their ultra durable 4/5 spec, yes they have dual BIOS and the ability to save BIOS profiles to a USB stick for example.
The capacitors are Nippon chemicon and super long life and high quality.
Certainly not flimsy either;)
