Dual Boot Windows 7 and 10 with same key?
I don't think so; once a key is registered on an installation, it has to be deregistered to be used on another install. Even simply reinstalling Windows 7, will require another activation request to be sent to MSFT.
If that is the case Microsoft can keep Windows 10.
if you upgrade to 10 you can go back to 7 if you don't like W10 but the key can only be active in one or the other not dual booting as it uses the same key
