It's a nzxt hale82n bronze certified.
Plan on replacing for a well know psu brand in a few weeks.
It's 650w and has a 50 amp 12v rail.
In that it won't matter which cables you use to run your GPU, they're all powered from the same 12V rail anyway. The only reason to use different cables rather than one is if you're concerned the manufacturer skimped so much on the internal cabling that one cable will melt if you push all your graphics card's power through it - but this only tends to be an issue on really dodgy no-brand name PSUs that come from auction sites or free with very cheap cases!
just don't buy cheap brands as suggested alreadySo two completely separate cables? I've seen some use one cable with two 8 pin heads and others do it separate. Slightly confused!
Or, just use 2 separate cables as a rule of thumb and that way you can't go wrong... Like I said earlier, there's not much reason not to.
Well reasons not to would just be aesthetics/convenience, but yeah I was just explaining why they give you two 6+2pin connectors when your not supposed to use both.
