- 18 May 2010
Wheels can be changed though if it meets all other criteria.
They can but the thing is I dont want to spend money on my next car unless its included in the £8/9K or are related to running costs. As the Ecoboost is at the very top end of my budget it makes it more difficult to find the spec I want
There's horror stories about most cars if you look hard enough. I'm no expert in the TSIs - I have a 2.0TFSI myself. I do frequent the skoda forums though and most of the horror stories I see are with the diesels. I don't think I've read any horror stories about the 1.4 actually. Remember neither are the twin charger that VW used in older golfs - they're just turbo petrols as far as I'm aware. The 1.8 AFAIK is just a smaller displacement version of the 2.0 in the VRS - this does have an issue with the tensioner as I mentioned but budgeting a few hundred quid to replace it with a revised part for peace of mind negates that. Some have a bit of a thirst for oil but otherwise I don't believe they're unreliable.
If they appeal - and they would be very good value for money - then head over to briskoda and ask on there, plenty knowledgeable people who'll tell you exactly what issues they might have and how to avoid them if possible.
They do seem like good value, I would like to avoid spending my entire budget if possible but (again with the buts
As much as I hate to say it, on paper the Civic 1.8 is the sensible choice but I would want a Pan roof to avoid the rusty roof issue limiting my choice once again
