- 9 Apr 2012
We have an intermittently dropping FTTC connection, a long with a loss of downstream sync since FTTC was installed two months ago (it dropped from 52Mb to 30Mb - it's now recovered a bit likely due to G.INP being applied yesterday).
TalkTalk were being useless so we contacted the CEO's office.
We're now in contact with TalkTalk's UK engineering team who are being very helpful but the issue still has not been resolved.
We've had four engineer visits and each time their tests pass and they leave - because there is nothing for them to fix.
The issue is intermittent, hence why their tests pass. Trying to get them to do something (a D-side change and then a lift and shift would the best solution as that would eliminate everything) based on what I'm telling them is difficult as when their tests pass they're told to go.
I've done some research on it and there's an Openreach product called an SFI2. Supposedly this service will essentially mean TalkTalk can "pay" Openreach to replace the D-side. Has anybody used this service?
