UniFi Access Points - any good?
12 Feb 2004
Manchester
We have 3 floors at work and im sick of having random APs around the building with rubbish roaming across them lol
so been looking into the UniFi's, i know some have used them on here, what are they like?
do they give decent range? and are they reliable?
Thinking of going for the 3 pack, around £145 now for 3
Thanks
I really like them, we have a large deployment of them at work.
One thing to note, they use 24V PoE, not the standard 48V. So you either need..
-a switch them can do both
-an inline 48>24V converter (£10-15 from Ubiquiti) for each one
-use the provided mains PoE injector
The management software is fantastic, needs a server to run on, which unfortunatly relies on Java 7. (being worked on)
Many Thanks mate
so I need a widnows server for the central management?
There is software for Windows, Linux and Mac
https://www.ubnt.com/download/unifi/unifi-ap
We have the Unifi Pro access points installed in our Warehouse at work - seem to work fine, especially the zero hand-off so users can roam the whole area and not lose connection. Now looking to replace our office and other random access points (few draytek, few netgear), and manage it all via the single software.
EDIT: Just checked, and the Pro versions (which we have at work) use standard POE.
Yeah we've got a couple here too, using the management software on Mac. They work well, the administration is very simple and straightforward. Worth the money.
You can deploy the controller on AWS / Azure on a Linux instance, and then as long as you have control of your own DNS servers you can redirect the APs to your cloud controller.
I don't like the APs personally, but they seem to be popular.
I think the PoE injectors come with them, so you should be good to go.
The key drawback for me is that they are 2.4Ghz only, but the price is fantastic for the kit.
I had the same opinion but in fairness, 2.4G isn't too bad for just providing Internet access.
They are nice and cheap and do work however you get what you pay for. We recently pulled them out of our estate and installed Meraki MR32/34's.
Maybe it was the age of ours but they were forever dying
I got one for my flat following a router upgrade. I think my neighbors either love or hate me, because I seem to have drowned out everything in the surrounding area.
