I installed a Raijintek AIO cooler to my 750D a couple of weeks ago and once or twice a day I hear a really horrible buzzing sound coming from it caused by the radiator mounted to the top of the case. I think the screws I used (the ones that came with the AIO) are to blame as I could never quite get them all screwed in tight. I think the rubber grommets might actually be a problem too as they get in the way of tightening down the screw. I've included a (crappy) picture in case you're interested.
My question really is what type of screw should I buy to firmly mount the radiator to the case?
Thanks
Thanks
