So ive had this fan controller hooked up to 9 noctua industrial ppc fans since last September and i love it ascetically however i cant have the rpm below 1080 or the fans will just go off next time i turn on my pc or go off if i bring it below 800 while the pc is on, this issue has always been there but the noise of the fans from 1090 - 1200 rpm hasnt bothered me too much however with the new 750d front panel with ventilation holes the noise is a little higher and unnecessary if the case will be the same temperature with the fans at 1200 or 800 rpm which is what id like them to be at, nice and silent.
Is there a solution to this problem ? like an adapter i can attach to them to reduce the voltage ?
if i had been smart at the beginning i would have just connected them all to the psu with a and a cable connected to the mobo to control them, but id like to still use the fan controller if possible for the internal temperature sensors.
