24 Jul 2015 at 21:42 #1 The_One The_One Soldato Joined 27 Dec 2003 Posts 18,918 Just put my new rig together and trying to install windows 8.1 oem from an external usb 2 cd drive Cant get my msi gaming z97 to boot from it i do have it connected to a usb 2.0 port on motherboard Any ideas?
24 Jul 2015 at 22:15 #4 The_One The_One Soldato OP Joined 27 Dec 2003 Posts 18,918 Should i have usb set to uefi or legacy and uefi
24 Jul 2015 at 22:40 #7 fobose fobose Soldato Joined 6 Dec 2005 Posts 5,198 Location Cambridge, UK. I had this problem a few years ago, tried everything. I ended up using the windows 7 USB/DVD tool to make a bootable USB drive and that worked perfect
24 Jul 2015 at 22:44 #8 fobose fobose Soldato Joined 6 Dec 2005 Posts 5,198 Location Cambridge, UK. Maybe this can help you: http://windows.microsoft.com/en-GB/windows-8/create-reset-refresh-media *ah on further reading, I don't think this will work with windows OEM licenses. Sorry Last edited: 24 Jul 2015
24 Jul 2015 at 23:25 #9 The_One The_One Soldato OP Joined 27 Dec 2003 Posts 18,918 fobose said: Maybe this can help you: http://windows.microsoft.com/en-GB/windows-8/create-reset-refresh-media *ah on further reading, I don't think this will work with windows OEM licenses. Sorry Click to expand... Just used above method and it worked with my windows 8.1 oem license Thanks
24 Jul 2015 at 23:30 #10 fobose fobose Soldato Joined 6 Dec 2005 Posts 5,198 Location Cambridge, UK. Sweet! NP P.S make sure you use a USB 2 port. I couldn't get my gigabyte Z97 to boot from the USB 3 port. You can use a USB 3 memory stick though
25 Jul 2015 at 19:13 #11 akua akua Permabanned Joined 22 Jul 2015 Posts 16 interesting thread, I too was having the same problem Last edited by a moderator: 26 Jul 2015
