Built my goblin mini
2x 10x 28 awg @ 2.5mm = 1 ohm
Quite an impressive little atty
looks wise, I'm a sucker for bellcaps, this is very similar in looks. There's far too much writing on it, max/min on the afc doesn't need to be there or could be replaced by symbols. The chamber has UD and goblin mini on it.. it should have one, the other or either and the should be placed underneath where it's currently blank.
Build wise, the deck is small.. very small for a four post system and it will have it's limits to how thick the wire can be be with the holes, so your really limited to higher ohms, as your need so many wraps to get to the lower subs it won't fit on the deck. The screws are tiny, making them wire snappers.
use wise, the afc is good! very good. Adjustable for both MTL and DTL vaping.. and can be adjusted on the istick 50w without a tool (I have some nails) as it sits just on the curve of the mod but my be harder on bigger mods.
It wicks like a champ, and can be chain vaped, I've used the pancake method but with loads of cotton. I've been vaping it at 17w mtl and 25w dtl without issues on the same coil setup and just adjusting the afc.
the 510 adapter looks silly on it and the glass drip tip build up water condensation like nothing else I have.
My main worry of it flooding and leaking over the mod, doesn't seem to be an issue with this build.. it did leak when I first put it on, but I did fill it and screw it on the mod without closing the afc... after that it just been water condensation again.
Flavor is good and clouds a big-ish and thick. Well impressed so far with a 30 pound atty. a thumbs up..
