- 9 Apr 2012
I only just found out about Bufferbloat.
When you're downloading/uploading, if your ping skyrockets and then when the download/upload finishes, it goes back to normal, you've got Bufferbloat.
QOS in the Gargoyle firmware didn't help (even though it is designed to reduce the ping when downloading/uploading) so I installed OpenWRT on my TP-Link WDR3600, after researching the issue. I also installed the SQM QoS package. It turns out I didn't really need the package as OpenWRT reduces bufferbloat so much anyway. I'm sure the package helps a bit however.
So if you're having issues with the ping when downloading, see if your router supports OpenWRT.
