H440 140MM exhaust fan
I haven't replaced the intake fans yet but replacing 3 of them is going to be costly.....
Any good budget ones to replace them with
The H440 isn't the greatest air cooling case unfortunately. Sorry probably stating the obvious.
Would their be much difference between the akaska and the silverstone considering their is a £15 difference
Hard to say without testing both but judging by the specs the apache should be better, in real terms that might be a few degrees difference.
If you don't mind the color then you can grab the following for much cheaper than the black version
YOUR BASKET
1 x Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM £6.66
Total : £8.94 (includes shipping : £1.90 Ex.VAT).
Them two cases are both designed for something other than cooling... Silence. You are not going to get great airflow from either as it's hard to keep silence and give good airflow.
I'm sure you can add fans to the top of the h440. Try sticking another exhaust there. Although I can imagine exhausts are not the problem.
As the front is restricted for airflow you should look for some fans with good static pressure.
